Old 10-16-2019, 02:57 PM   #15
LLW
LLW's Avatar
Drives: FRS, 13 A/T
Originally Posted by Project_1796 View Post
The automatic trans is going to shift using calculations from MAF, engine load, tps, have you raised your engine load limits A & B?
http://www.ft86club.com/forums/showp...postcount=2510
Well now Ive digged and not kinda realized those tables arent exist. There is a post from Wayno on how he enabled it:
http://www.ft86club.com/forums/showp...postcount=2481
Ive checked the definitioms between A01 and A00 and they tend to be different, however using HxD it seems the desired tables are the same. Im not sure should I just add randomly this lines of code to my A00D file? where to add them or it doesnt really matter?
UPD:
I`ve actually managed to add those tabs, however at the example its Wayno`s v65-v66 and mentioned its not propertly tested. Currently he sells v143 something, so I doubt there is something changed significantly.
LLW is offline   Reply With Quote
Old 10-16-2019, 03:19 PM   #16
tyler_win_photo
tyler_win_photo's Avatar
All your issues would be fixed if you just drove it in manual.
Are you sure you're wot? The car has a slight kick down at the top of the throttle.
Lastly, oft tunes don't do much in terms of power. I can pull up a dyno sheet of a oft car with bolt ons vs a stock car if you'd like to compare. Peak gains of 3-4hp and about 5 lbs-ft torque.
tyler_win_photo is offline   Reply With Quote
Old 10-16-2019, 06:03 PM   #17
LLW
LLW's Avatar
Drives: FRS, 13 A/T
Basically, I lost the feel of that kickdown after I got shim installed to fix cell, but Ive removed the shim to test and result was absoulutely the same, apart from kickdown feel.
If I would love to drive manual I would pick manual car
That sound weird regarding OFT coz there was a tonns of dynos which showed it gained up to 20-30 whp with boltons n OFT.
Old 11-06-2019, 01:50 PM   #18
LLW
LLW's Avatar
Drives: FRS, 13 A/T
Ok so I got Wayno Rom, absoulutely brilliant it feels, I will do the test pulls after learning period will be completed.
Old 11-13-2019, 11:47 AM   #19
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
any updates?
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 12-13-2019, 07:20 AM   #20
LLW
LLW's Avatar
Drives: FRS, 13 A/T
Originally Posted by Soloside View Post
any updates?
Unfortunately I didnt had a chance to try max speed just yet. But it feels like the problem is still there. Any suggestions?
Old 12-13-2019, 10:48 AM   #21
wparsons
wparsons's Avatar
Log throttle position while you're trying to make sure it's actually seeing WOT and not a problem with the sensor in the throttle pedal.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Tristor (12-14-2019)
Old 12-17-2019, 11:46 PM   #22
LLW
LLW's Avatar
Drives: FRS, 13 A/T
Thanks, while I was making a pull to adjust MAF map from Wayno, I did logged it already, was 100% at some of the points of RPMs.
Need advices on parking sensors Grace Scion FR-S / Toyota 86 GT86 General Forum 26 06-13-2013 09:29 PM
Looking for DMG BRZ Limited 6 Speed Jon H Northern California 3 04-21-2013 12:05 AM
Looking for DMG BRZ Limited 6 Speed Jon H Southern California 8 04-18-2013 12:39 PM
FR-S newbie to Mod needs advices!! newkid185 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-09-2012 06:39 AM
