Engine Swaps Discussion of engine swaps. |
09-24-2019, 10:08 AM | #1 |
Anyone use CX Racing raditor hose kit?
Anyone use or have pictures of the cx racing radiator kit? I can see the top pipe installed on their website but have nothing to see the bottom pipe installed. Trying to see how they are routing it to see if it would work for me.
Thanks! |
09-24-2019, 10:54 AM | #2 |
2 ugga dugga's
Drives: Nike
Assuming you are asking regarding the 2jz stuff, the lower pipe goes like this:
Starting at the coolant water neck off the thermostat/water pump housing, it goes downward and a little towards the front of the car. Then it goes close to and just between the oil pan (front sump) and the lower part of the core support. Then it goes back up and forward into the radiator. Unfortunately I don't have any GOOD pics but if you really need them I can try to take some later today, after work. Overall their piping kit fits pretty nicely. My only complaint was when I ordered it, I did not receive the 1/16 NPT threaded barb nipple nor did I receive a radiator cap. It took me 3 months of calling and bugging them to get those 2 things. Also, the neck for the radiator cap is welded on crooked. It doesn't interfere with anything but it just looks weird. I think it's expensive for what it is, but you're paying for the convenience factor to not have to do it yourself. I WOULD absolutely buy this kit again.
Want to 2JZ swap your 86? Click here first!!
09-24-2019, 12:36 PM | #3 |
Thanks but I'm looking at ls kit. Sorry.
11-09-2019, 12:34 AM | #4 |
Drives: Subaru brz 2013 LS1 swap
All I could find hopefully helps
Sent from my SM-N960U using Tapatalk |
11-09-2019, 05:44 PM | #5 |
It does thanks. Not as clean of a route as I was hoping.
Similar Threads | ||||
GMS Inlet & Sound Hose @ Import Image Racing!**************************************** | ImportImage | Engine, Exhaust, Bolt-Ons | 109 | 01-18-2016 04:51 PM |
FS: SoCal - Tomioka Racing Inlet hose, NEW | AspenItIs | Engine, Exhaust, Bolt-Ons | 27 | 03-21-2015 07:44 PM |
Depo Racing Air Intake Hose $59.99 | Depo Racing | Engine, Exhaust, Bolt-Ons | 9 | 02-06-2015 06:21 PM |
Enjuku Racing - ISIS Silicone Radiator Hose Kit - ** NOW AVAILABLE ** | Enjuku Racing | Engine, Exhaust, Bolt-Ons | 0 | 01-08-2013 04:37 PM |
