Forced Induction Turbo, Supercharger, Methanol, Nitrous |
03-02-2016, 01:34 PM | #1 |
Supercharger charge pipe question
Hey guys. I'm curious about the effect of charge pipe length on supercharger(specifically centrifugal). Most if not all kits currently come with a front mount intercooler. But what if someone used a liquid to air intercooler? Assuming you could find one that would fit between the throttle body and your supercharger outlet of course. Would the elimination of charge piping running thru the bumper increase throttle response? Decrease charge temp? Thoughts?
Ps: I am aware it's easier to just buy a kit and use what they give you but I'm curious about this. |
03-02-2016, 06:05 PM | #2 |
Y u do dis?
sprintex's and other twin screw supercharger kits use Liquid to Air intercoolers. necessity varies depending on your supercharger of choice.
since most of the rotrex and centrifugal kits work like a belt driven turbo, it is more effective for these kits to run an Air to Air intercooler, which works most efficiently with heat radiating off it.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
03-02-2016, 09:32 PM | #3 |
[insert cool phrase here]
Drives: BRZ Premium
You'll still need some air going to it. Look up the last gen celica all tracks. They have a top mounted water to air inner cooler. But it has a hood scoop.
To me it's extra work for a bit of gain. More stuff to go bad. But if anything it could be done, lower air temps and what nots. Not sure how much power you'll gain but some one out there might find out.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
The Following User Says Thank You to Mr.ac For This Useful Post: | Dream20b (03-02-2016) |
03-02-2016, 09:51 PM | #4 | |
03-02-2016, 10:05 PM | #5 | |
Y u do dis?
I assumed that was understood.
Dat Hot Lava Doe
03-02-2016, 10:30 PM | #6 |
It takes almost no time to pressurize the pipe and IC. I went from a TMIC to a FMIC on my WRX and it really made almost no difference. The on/off throttle response was still very good even with the larger FMIC and it used longer and larger piping than what you have with a S/C on this car.
03-02-2016, 10:34 PM | #7 | |
03-03-2016, 01:43 AM | #8 | |
Drives: BRZ Premium
Turbocharged that's a different story. I'm thing your mixing your forced inductions. No worries I been there. Both of my old cars gets me thinking at times
03-03-2016, 02:22 AM | #9 |
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Run an ice box and a water to water fuck it!
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
The Following User Says Thank You to #maverick# For This Useful Post: | mrk1 (03-03-2016) |
03-03-2016, 06:56 PM | #10 | |
03-03-2016, 07:22 PM | #11 |
Drives: 2014 Monogram FR-S Whiteout
The thing is on or off throttle at a given rpm the SC is flowing the same CFM. The variable is the bypass valve so really throttle response won't be changed with charge pipe length, only BPV responsiveness will play into throttle response since all the airflow is already being pushed back against the throttle body and out the BPV.
Disclaimer: I could be wrong and if someone points it out to me I am ready to learn! |
03-03-2016, 09:28 PM | #12 | |
Drives: BRZ Premium
Uh. Supercharge... Boost is instant. No mater what version. Roots type or centrifugal.
03-03-2016, 09:31 PM | #13 |
Drives: BRZ Premium
Interesting fact one of the later ford lighting trucks played around with using the AC to cool the inner cooler. Cool idea but extra load and worse mpg for a daily driver.
Similar Threads | ||||
supercharger question. | smshocker | Forced Induction | 17 | 07-17-2014 12:12 PM |
Need some help building my f.i charge pipe | SavingManuals | Forced Induction | 7 | 04-11-2014 02:37 PM |
Innovate Supercharger, Over-pipe & Front pipe for SC setup | scionsalesjay | Engine, Exhaust, Transmission | 7 | 03-22-2014 09:13 AM |
Agency Power over-pipe/front pipe combo question... | seven | Engine, Exhaust, Transmission | 11 | 01-13-2013 12:14 PM |
Supercharger question | PrDarkKnight | Forced Induction | 9 | 12-26-2012 01:49 PM |
