Tracking / Autocross / HPDE / Drifting What these cars were built for! |
06-17-2019, 01:39 PM | #15 | |
Drives: 2014 FR-S
-Mike
#24 CS/CSR |
06-17-2019, 01:51 PM | #16 |
Drives: 2023 BRZ
85k miles and around 100 track days here. No indication I need to change them.
Director of Rocky Mountain 86CUP
The Following 3 Users Say Thank You to Pat For This Useful Post: |
06-17-2019, 02:21 PM | #17 |
Purist
Drives: 2013 FRS - Hot Lava
Are youre tires doing this? I thought it was a wheel bearing at first. The humming was bad! It was just some toe-out.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85) |
The Following User Says Thank You to Westen86 For This Useful Post: | atomicalex (06-18-2019) |
06-17-2019, 04:20 PM | #18 |
Drives: Nevermorange FRS
There a lot of things that can add stress and change the life. Aggressive toe, camber, offset, lateral grip, heat, speed etc etc. Even with the varied results I've seen in the thread, I feel pretty positive about the longevity of this part of the car. Even more positive since replacing this part doesn't require the dismantling of ball joints or the use of a press like with other cars!
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post: | atomicalex (06-18-2019) |
06-18-2019, 11:38 AM | #19 | |
Drives: 2018 BRZ Limited Perf Pack
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon |
Similar Threads | ||||
Front wheel bearing | endless_pain | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 12-13-2016 06:06 AM |
Wheel bearing? | Nylander | Issues | Warranty | Recalls / TSB | 20 | 06-08-2015 04:57 PM |
Wheel bearing gone at 1,500k!? | Muskokan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 10-02-2014 03:58 PM |
Wheel Bearing Woes | jwstaton | Issues | Warranty | Recalls / TSB | 16 | 01-24-2014 08:06 PM |
Blown wheel bearing =( | silverbullet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 01-23-2013 10:34 PM |
