Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
05-08-2019, 08:29 PM | #1 |
Drives: '16 CWP BRZ
Car acts weird after not driving it for a couple of days
So i noticed that if i don't drive the car for at least 3 days it starts to act weird. One, my e brake handle becomes very loose and then feels normal after driving for like 30 minutes. Two, on my first drive out while the car is still somewhat cold, the car likes to vibrate violently going over 50 mph but goes away a minute later. Three, again on my first drive out, when i put the car in 1st gear it doesn't start rolling. I would have to give it some gas for it to start going, but i just think it's really weird that the car wouldn't move when i bring out to the bite point but this eventually goes away when the engine or transmission is warmed up. I checked my tires and see if my lug nuts were on tight and everything seems fine, so i have no idea what the problem is. If anyone can please help thank you!!!
Mods: Invidia N1 Invidia catless front pipe Tomei overpipe Tein coilovers Edit:Car will act normal after driving it for a while but problems will come back when i don't drive it for a couple of days Last edited by Bryan86; 05-08-2019 at 08:36 PM. Reason: Car will act normal after driving it for a while but will come back when i don't drive it for a couple of days |
05-08-2019, 09:58 PM | #3 |
Used or new? Do you have a tune or stock? Your still on OEM headers? What your describing are mechanical issues... Describe cold as in what temperature?
2013 Series 10 FRS #553
05-08-2019, 10:12 PM | #4 |
Drives: '16 CWP BRZ
05-08-2019, 10:15 PM | #5 |
Only thing I would say is check your modified exhaust parts for loose bolts, leaks, or clearance issues. When did this start happening? any CELs or codes?
05-08-2019, 10:35 PM | #6 |
Drives: '16 CWP BRZ
No CEL or any codes. It randomly just started happening like a week or two ago but i’ll def check for all this during the weekend.
05-09-2019, 12:03 AM | #7 | |
Car vibrating over 50 mph - maybe the tire(s) just had a temp flat spot which goes away when they get warm. Maybe check the tire pressure. Car not moving in first. You might check the clutch adjustment and the clutch system fluid level. humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Bryan86 (05-09-2019) |
05-09-2019, 07:24 PM | #8 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Sounds like your parking brake is sticking.
Your handle is loose because the brake shoes aren't retracted. The car shudders because the brake is getting very hot and grabbing. The car doesn't start rolling because the parking brake is stuck. Vibration/heat eventually nudges the brake shoes to free the rotor completely. |
The Following User Says Thank You to RZNT4R For This Useful Post: | Bryan86 (05-09-2019) |
Similar Threads | ||||
Driving cross country in the next couple months | rainmonkey | BRZ First-Gen (2012+) -- General Topics | 24 | 02-17-2016 07:58 AM |
Winter driving: dry days only? | 1Cor10:23 | CANADA | 38 | 01-23-2015 07:23 PM |
How many days the battery last without driving the car? | djmm | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 04-02-2014 06:13 PM |
Couple of days to kill in Ft Lauderdale/Hollywood area, cool things to do/see? | Bad Habits | Southeast | 3 | 01-14-2014 06:02 PM |
