Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-28-2018, 02:15 AM | #1 |
Drives: 2015 Subaru BRZ Series.blue
LWCP Kit - Worth Keeping Any of Them?
I have a LWCP kit. I installed 2 of the 3 pieces.
I am going back to stock CP and was wondering if keeping either of the other 2 pulleys is worth it or rather do those one cause any issues/have risks? I keep reading and hearing that LWCP is not worth it due to benefit:risk and because of harmonic balancing. Do I need to worry about the other 2, or can I keep that tiny bit of weight reduction and be worry free besides general wear and tear?
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. |
01-28-2018, 02:37 AM | #2 |
義理チョコ
You're a lot smarter than you admit in your sig.
The other pulleys are fine. If you like the bling, leave 'em.
01-28-2018, 05:09 AM | #3 | |
Because compromise ®
Drives: Red Herring
OMG!! Fitting a lwcp has released 40 gazillion GW and the mass of my car has increased to 48 solar masses because I am reaching relativistic speeds! and Don't do it!! You risk annihilating the local space/time continuum and we will all end up drinking dark matter through a worm hole out of each other's asses. The only hard evidence, done by a tuner on these forums, whose name escapes me and I can't be bothered looking for him because this has been done to death all ready, is that if you run a lwcp AND a lightweight flywheel below a certain mass you will destroy your engine. This rule is only applicable to these engines; other engines have different criteria. The only benefit to having a lwcp is the bling.
The Following User Says Thank You to Captain Snooze For This Useful Post: | Strife26 (01-28-2018) |
01-29-2018, 04:43 PM | #4 | |
I feel like the chatter is gone, but I haven't got to drive much because I am still on the base map until tonight (I hope). @Ultramaroon thank you for the kind words. It's just been the experience being a gamer and a newb, lol. I've had a few subtle cases on here too where I am clearly inexperienced but still catch flak : (. I like something being there to remind those who think about being ...mean (let's go with that, haha) so maybe they won't. I do need to update it though.
01-30-2018, 12:13 AM | #5 | |
The Following User Says Thank You to NRXRaptor For This Useful Post: | Strife26 (01-30-2018) |
01-30-2018, 12:20 AM | #6 | |
Sent from my SM-G950U using Tapatalk
01-30-2018, 01:15 AM | #7 |
Drives: '15 BRZ RA
With a pulley kit, you can remove around 5lbs. A lightweight flywheel can free up to 20lbs, so yes there is a difference. Overall, these changes work. The physics behind are the transmission gear mechanism and the final drive ratio mechanism which act as levers. In low gears (1st, 2nd, 3rd) the crankshaft is rotating a car with a much smaller weight, so if the other engine parts (pulleys, flywheel) are lighter it helps a lot. A pulley kit provides better gains if you under-drive the peripheral systems (i.e. the alternator and/or the water pump). Personally, I would suggest these modifications if someone builds a track oriented NA car. They are not the best option for a daily driver.
01-30-2018, 02:25 AM | #8 | |
The Following User Says Thank You to Strife26 For This Useful Post: | nikitopo (01-30-2018) |
Similar Threads | ||||
[SOLD] Grimmspeed LWCP | xn7485 | Engine, Exhaust, Bolt-Ons | 2 | 08-02-2016 12:08 AM |
Keeping it Clean | FirestormHachiroku | CANADA | 25 | 05-24-2016 08:35 PM |
FS: Perrin LWCP / SOLD | chuccwagon | Engine, Exhaust, Bolt-Ons | 4 | 12-11-2015 03:28 PM |
Keeping them (please delete) | Skurj | Canada Classifieds | 5 | 06-04-2014 05:35 AM |
Perrin LWCP tensioner wabble | NickFRS | Engine, Exhaust, Transmission | 8 | 04-02-2013 08:23 PM |
