Old 12-04-2016, 12:26 PM   #15
TkTk
TkTk's Avatar
Drives: 2014 TRD GT86 CUP, 2014 991 GT3
I don't mind any of the two options.
At zero aoa, what will the balance of the car be at high speeds (+90 mph) with all velox front aero?
I think having a mid size wing that is legal for most classes is the best option.
TkTk is offline   Reply With Quote
Old 12-04-2016, 07:57 PM   #16
0 AOA relative to the ground, or airflow over the rear of a twin? Remember, 0 AOA relative to the ground is still some effective AOA due to the airflow over the rear of the car, for a portion of the wing. This is also why a chassis-specific 3d wing can be superior to a 2d airfoil, provided it is mounted in the proper position. The higher you go, the less the twist matters.
MaximeT (12-05-2016), yberther (12-21-2016)
Old 12-05-2016, 02:00 AM   #17
TkTk
TkTk's Avatar
Wing
Well it depends on their design as you said 2d is different than 3d. For both cases I mean the lowest aoa possible at which it is producing the lowest downforce numbers. As most gt wings (+1600mm) are producing more than enough downforce at 0 aoa.
It would be nice to have a mid size low drag wing that start producing downforce at 0 aoa where it can be balanced out easily with front aero. Also if its legal for most classes that would be a win win for us.
Old 12-05-2016, 09:57 AM   #18
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
Here is Element Tuning's setup. Is this something like what you had in mind?
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 12-05-2016, 10:12 AM   #19
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Initially, yes. However, I'm really enjoying sitting back and listening/hearing some of the ideas being thrown out there. Some of them aren't necessarily plausible or make a lot of sense, others are really helping Paul and I potentially come up with something neat for you guys. This is all part of brainstorming honestly, and it's neat to have it be a positive thought process with the community to hear/see what you guys are after.
So far, glad we started the thread as it's lead to some neat potential new ideas for mounting and future product development .
Eric
VerusEric is offline   Reply With Quote
The Following 3 Users Say Thank You to VerusEric For This Useful Post:
MaximeT (12-05-2016), Pat (12-30-2016), Takumi788 (12-05-2016)
Old 12-17-2016, 04:51 PM   #20
.RYAN
AWOLBRZ
Drives: 2017 BRZ
I was curious on this whole "chassis mounted" wing thing so I started doing some research. I found a thread on Track Junkies and posted it below. There is some pretty good data in there along with some valid arguments all before the thread goes sideways and the topic blurs....like most threads. lol. Anyway. They all seem to think the chassis mount is "a gimmick" for "street" cars and I tend to agree.
Please hear me out. I own a bunch of Velox products and do not doubt their engineering. However. There are a ton of trunk mounted wing options that do not distort the sheet metal. The swan neck seibon wing is MASSIVE. Speed Academy put one on their FRS and did not have problems with sheet metal. Even if there is sheet metal distortion there are easy ways to remedy this that will be far easier than developing a chassis mount setup. And the wing would probably sell better seeing as you don't have to cut into anything (aside from a few holes in the trunk.)
Just my 2 cents. I am but a mere design engineer that is over excited for a wing with data to be produced.
https://www.trackjunkies.org/topic/4...ssis-mounting/
Speed Academy has the Voltex Swan Neck Wing.
.RYAN is offline   Reply With Quote
The Following User Says Thank You to .RYAN For This Useful Post:
Takumi788 (12-17-2016)
Old 12-18-2016, 06:26 AM   #21
thatonehoonigan
thatonehoonigan's Avatar
Drives: '16 Halo White FR-S '07 GSX-R600
Velox Motorsports Rear Wing Development
There is a company called BattleAero that has a chassis mounted swan neck wing that still allows use of the trunk. They fold the wing down and away from the trunk, obviously not the easiest way to use a trunk but it's an idea. I like how their wing looks and they have options for endplates as well, but there is zero research into performance and they provide literally nothing to state it aids in any kind of performance. But just an idea.
Edit:found a picture
thatonehoonigan is offline   Reply With Quote
Old 12-18-2016, 10:06 AM   #22
.RYAN
AWOLBRZ
Drives: 2017 BRZ
^ Pure rice.
The Following 3 Users Say Thank You to .RYAN For This Useful Post:
civicdrivr (12-19-2016), RavioliG (02-23-2018), Takumi788 (12-18-2016)
Old 12-21-2016, 05:11 PM   #23
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
sub'd!
Looking forward to see what happens with this.
Old 12-31-2016, 10:17 PM   #24
2086GT
Drives: 15 Scion FRS Halo
Just going to point out top tier racing classes are not using swan neck. So either they are doing it wrong, I don't know of some class rule against swan necks, or swan neck isn't even worth it. So I am going to say A.
2086GT is offline   Reply With Quote
Old 12-31-2016, 11:09 PM   #25
StegaDragon
StegaDragon's Avatar
Drives: 13 Sc10n FR-S
How about option #3 and go with a set up like the rocket bunny, less chances of distortion to the trunk, and leaking, then just develop something to brace the trunk to the chassis, like replacing the rubber stoppers with something that has less give and make it more direct transfer of Force to the chassis
Sent from my XT1650 using Tapatalk
StegaDragon is offline   Reply With Quote
The Following 5 Users Say Thank You to StegaDragon For This Useful Post:
Ashikabi (01-14-2017), Brayden_23 (05-05-2017), Hostile_Kittens (01-24-2017), Hyper4mance2k (02-04-2017), zeal86 (10-20-2017)
Old 01-01-2017, 12:46 AM   #26
Devil 86
Devil 86's Avatar
Drives: Ultramarine FR-S
Seems like a terrible area to mount a wing. Bracing that area of the trunk wont be as effective as mounting the wing on top and bracing the top portion of the trunk.
Devil 86 is offline   Reply With Quote
Old 01-01-2017, 12:54 AM   #27
StegaDragon
That's the thing, this part doesn't need the bracing that mounting it on top of the trunk would, as the sheet metal is vertical and hence will withstand the load. The drag on the wing pushing it back would be the real concern. And that can easily be sorted out as compared to the hundred plus pounds of down force placed on the thin sheet metal with no bracing on top of the trunk. Plus it would definitely not cause an issue when trying to load items into the trunk
The Following User Says Thank You to StegaDragon For This Useful Post:
Hostile_Kittens (07-10-2017)
Old 01-01-2017, 06:57 PM   #28
Takumi788
JHerbert Racing
Takumi788's Avatar
Velox. what do you think about this idea? It seems like you could design a swan neck from this type of mount.
I still stand by my original post in which I stated that a "typical" trunk mount solution would be preferred. But this could be a plausible solution to create a swan neck design.
Search this Thread:
Advanced Search
WTB: Header, Rear Diffuser, Rear Wing/Spolier, Trunk, Tail lights Apples_ZN6 Canada Classifieds 0 06-04-2017 11:27 AM
Street Faction Engineering Chassis Mount Wing FRS/BRZ hellokyles Exterior Parts (Aero, Lighting, Etc.) 19 08-19-2016 05:20 AM
Freed Engineering custom metal fabrication and parts development bFreed Announcements, Contests, Giveaways 23 03-24-2012 03:35 AM
Wing or no wing? (rear spoiler) quik1987 Scion FR-S / Toyota 86 GT86 General Forum 123 12-12-2011 06:11 PM
