Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
11-20-2017, 03:17 PM | #15 | |
Drives: 2003 S2000, 2008 Fit
Makes sense to me! |
The Following User Says Thank You to daiheadjai For This Useful Post: | humfrz (11-20-2017) |
11-20-2017, 03:34 PM | #16 |
義理チョコ
[ame="https://www.youtube.com/watch?v=6x_Eijnn1Ak"]Simpsons - Koyaanisqatsi Spoof - YouTube[/ame]
The Following User Says Thank You to Ultramaroon For This Useful Post: | TofuJoe (12-02-2017) |
11-20-2017, 07:06 PM | #17 |
Ha! Yep, getting a similar leak. If it's under the intake runners toward the back of the motor, I got bad news for you. It's NOT the timing cover. Signs are looking at the head gasket BUT I am confirming with Racer's Line in Concord, CA Tuesday AM. Stay tuned!
11-21-2017, 03:35 AM | #18 |
Drives: raven FRS
Nice ,keep me update from your issue , thanks .My leak is under the intake go around the front at driver side between timing chain seal. I will take my car for 60K service soon. Let see what the dealer gonna say about that.
IACRO RAVEN86
https://www.instagram.com/louislee0828/?hl=en |
The Following User Says Thank You to snk828 For This Useful Post: | exE36M3 (11-22-2017) |
11-22-2017, 03:34 AM | #19 |
Drives: 2013 brz limited / galaxy blue
I had an oil leak behind the cam that Subaru techs had to fix on my Brz before . I took it in for a leak because I noticed oil in the same area as you . Techs then said it was the cam position sensor and then I got the car back with no leak about a month later from Subaru dealer ship . They warrantied it for me and the car even had the Jackson racing super charger on it . I just had to pay for them to remove and install the super charger as the parts and labor were under warranty .
The Following User Says Thank You to mswbrz For This Useful Post: | snk828 (11-22-2017) |
11-22-2017, 06:04 PM | #20 | |
After taking it to an independent Subaru Shop - the 2 sources for my leak are the head gasket or the injector. Mine appears to be spray leaking under pressure. I'm not versed enough with the FA20 motor to know all the oil leak spots. Given where yours is on the motor. It's hard to fathom a timing cover leak on top of the motor as I don't *think* the timing cover has that much oil pressure... Enough to push oil upward anyway. |
The Following User Says Thank You to exE36M3 For This Useful Post: | snk828 (11-22-2017) |
12-02-2017, 03:14 AM | #21 |
Drives: raven FRS
update: first dealer visit , dealer can't confirm where's the leak come from,so they clean it up as much they could and let me drive the car for a week to see does it happen again. The leak comes back two days after normal driving, I would take it back to dealer for second visit tomorrow.
IACRO RAVEN86
The Following User Says Thank You to snk828 For This Useful Post: | exE36M3 (12-02-2017) |
12-02-2017, 11:25 AM | #22 | |
Isn't this fun? I've been about 3 times and 3 weeks for this case. I have to wait until after January to bring it back in (as I am in/out over the holidays) and IF they find something with the car, it's at least a week turnaround.
Good luck with your case. Here's to hoping for easy fixes right? Quote:
The Following User Says Thank You to exE36M3 For This Useful Post: | snk828 (12-03-2017) |
12-03-2017, 02:13 AM | #23 |
Oh, I'm thinken you young-ens are spoilt.
As long as it's not leaking more that a quart of oil a week ....... just drive it.... humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | exE36M3 (12-03-2017) |
12-03-2017, 02:58 AM | #24 | |
Drives: raven FRS
IACRO RAVEN86
12-03-2017, 02:49 PM | #26 |
03-22-2018, 10:35 PM | #27 |
Drives: 2013 Firestorm FR-S
Did you ever solve where he oil under your intake was coming from?
Similar Threads | ||||
Oil Leak | Brz_racer | Engine, Exhaust, Transmission | 22 | 07-17-2017 04:28 PM |
Intake manifold leak | Diz86x | Engine, Exhaust, Transmission | 5 | 07-13-2017 12:42 PM |
oil leak ! | frsqc | Issues | Warranty | Recalls / TSB | 5 | 07-01-2015 07:08 PM |
Oil leak. | ohnoitsthefuzz | Issues | Warranty | Recalls / TSB | 2 | 03-23-2015 01:31 AM |
A/T Pan leak | goke186 | Issues | Warranty | Recalls / TSB | 0 | 04-15-2013 10:31 PM |
