Old 07-11-2016, 02:45 AM   #7351
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Ahh. I think I'll stick to 12psi
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
The Following User Says Thank You to riboyster For This Useful Post:
raven1231 (07-11-2016)
Old 07-11-2016, 03:42 AM   #7352
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by walletsr View Post
https://goo.gl/photos/qv1SfbBF2qstP3A6A
Is this a bad seal on the intercooler plate?
Oil?
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-11-2016, 07:56 AM   #7353
walletsr
Drives: 2014
Yeah, it's oil. Not sure where exactly its coming from
walletsr is offline   Reply With Quote
Old 07-11-2016, 10:13 AM   #7354
Vten
Drives: Too heavy
Same thing happens with my 210 blower. I believe the oil comes out from the glass window under the snout and sipping all the way to the sides.
I brought it to a local Performance shop and they were in contact with sprintex and jonbond, and told that it is the common problem with them ....I had it fixed by opening the front parts by the snout, install the Jon bond breather kit , resealed it with a gasket maker ...it was a couple of months ago, But yesterday , when I opened the hood for maintenance check , I saw some same wet spot around the glass window again ..... Pretty frustrating ...
Vten is offline   Reply With Quote
Old 07-11-2016, 12:21 PM   #7355
riboyster
riboyster's Avatar
It's gotta have something to do with blowby. I seem to be the only one who hasn't had this, and I vent to atmosphere through a catch can.
Dream20b (07-11-2016)
Old 07-11-2016, 12:27 PM   #7356
walletsr
Drives: 2014
Gotcha.... well I may have to get a catch can... it makes things messy...
Old 07-11-2016, 05:17 PM   #7357
Kodename47
Kodename47's Avatar
Drives: UK GT86
Mine had this issue after a recent sprint day and I have no sight glass. Assumed it was coming out the rear.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-11-2016, 06:35 PM   #7358
walletsr
Drives: 2014
Yeah mine didn't have the glass sight either. It's coming out of the base of the blower.
Old 07-11-2016, 08:34 PM   #7359
Dream20b
Y u do dis?
Originally Posted by stockysnail View Post
It's back earlier this year on this thread, but if I recall correctly the rod broke and cracked the block and bent the piston, but don't quote me since I'm not positive.
That was smudge's build and it was due to a manufacturing failure
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
The Following User Says Thank You to Dream20b For This Useful Post:
riboyster (07-12-2016)
Old 07-12-2016, 12:44 AM   #7360
riboyster
riboyster's Avatar
Well that's good news. Bittersweet I guess...
Dream20b (07-12-2016)
Old 07-12-2016, 06:54 AM   #7361
Dream20b
Y u do dis?
I suppose. It is his SC unit on my car now, though.
Dat Hot Lava Doe
Old 07-12-2016, 06:35 PM   #7362
riboyster
riboyster's Avatar
On the bright side, you know it makes good power!
Old 07-12-2016, 10:13 PM   #7363
DIE1000DEATHS
TechNINJA
DIE1000DEATHS's Avatar
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
Originally Posted by Jeremiahlee34 View Post
That's good to know! Thank you! I would be on the 85mm pulley and 93 pump gas, ALONG with WMI just to help with the overall reliability.
Did you run the 80mm pulley on 93? Or just e85. If so id love to hear more about that. I.e. Any dynos, knock count, intake temps, ect.
I appreciate it!
Cheers
I ran it on both, but e85 is EVERYWHERE around here. More power and lower cylinder temps... I'll stick to e85 as much as possible lol.
It was never dyno'd (the new block will be). If I get a chance to pull up my old logs I can try and get the other info for you. I know Mike did pull a little timing out from the base tune he sent with the 93, as he saw a little knock.
DIE1000DEATHS is offline   Reply With Quote
Old 07-13-2016, 05:22 PM   #7364
camelflage
Drives: pinto power
how is the pulley measured? from edge to edge mine is 80mm..
camelflage is offline   Reply With Quote
2 whp better than n/a e85, 2 whp? you're an idiot., 2screwsbetterthan0screw, 65 whp better than na e85, bspt fittings ftl, hate u all me no have sc, im just here for the tags, inorite!, it's no turbo but, only big numbers matter, screwyou, whine sexier than turbo, whines_more_than_your_gf, wts grey market butthurt.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
