Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Forced Induction
Old 06-12-2019, 11:24 AM   #1
BIOSphere
Drives: Turbocharged 2015 Scion FR-S
Turbo Flutter
I recently purchased a Turbocharged 2015 Scion FR-S (Automatic).
It pulls smoothly when under full boost, but makes a fluttering noise (audible in the attached video).
What is causing this noise or what should I try to narrow down the source?
https://photos.app.goo.gl/3Nyjx5VS1s75xoeg9
Specs:
- Full MaPerformance turbo kit
- Delicious tuning flex fuel kit
- Borla catback exhaust
- Open dump wastegate
- 350 wheel horsepower
- 12 lbs of boost
BIOSphere is offline   Reply With Quote
Old 06-12-2019, 12:00 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Sounds like wastegate flutter
BigTuna is offline   Reply With Quote
Old 06-12-2019, 01:39 PM   #3
BIOSphere
Any idea on how to mitigate the flutter?
Assuming it is caused by the wastegate.
Old 06-12-2019, 06:38 PM   #4
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
Frequency of the ebc needs to be tuned higher.
Tonrogs is offline   Reply With Quote
Old 06-12-2019, 07:08 PM   #5
DarkPira7e
Handin' out 1 Deags
DarkPira7e's Avatar
Drives: 13 Firestorm Red FRS
This is your EBCS frequency.
Old 06-13-2019, 01:53 PM   #6
Fred E
Drives: DGM BRZ
Just to clarify the statements already made about the EBCS frequency, this is not indicative of an issue with the car/setup. Whoever tuned the car can increase the wastegate frequency to turn the BWA-BWA-BWA-BWA sound into a BWAAAAAAA sound, but the only difference will be the sound. The car will otherwise drive and feel more or less the same, but adjusting the frequency is entirely preferential. If you want the wobble, keep it unchanged, if you want it smooth, increase it. A setting between 20 and 30 Hz would make it smooth.
Fred E is offline   Reply With Quote
Old 06-14-2019, 04:33 PM   #7
BIOSphere
Ahh yes, it pulls smoothly, I am just not a fan of the sound and would prefer it to be smooth.
automatic frs, flutter, maperformance, noise, turbo
Open Waste gate ďFlutterĒ Kris86 Forced Induction 3 05-13-2019 08:56 AM
Wastegate flutter!! sid94 Forced Induction 14 08-19-2018 11:31 AM
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 03:41 PM
Hood flutter at high speed TheseColorsDontRun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-10-2013 10:39 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
