08-17-2015, 12:35 PM | #197 | ||
Drives: 2010 MS3
08-17-2015, 12:52 PM | #198 | |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | JS + BRZ (08-17-2015) |
08-17-2015, 01:08 PM | #199 |
Drives: 2010 MS3
Yep! No noise when coasting. Not sure what it is.
08-18-2015, 05:43 PM | #200 | |
Thanks |
The Following User Says Thank You to jflogerzi For This Useful Post: | JS + BRZ (08-18-2015) |
02-07-2016, 01:59 PM | #201 | |
hey you, yeah you <3
Drives: 2014 37J FR-S
If its not when ac kicks in, it's a unbalanced or not symmetric rocker arm. Eventually it sticks or clicks wrong and bye bye engine. Could also be a pump issue.
02-07-2016, 03:26 PM | #202 |
02-07-2016, 03:28 PM | #203 |
You get a new car?
02-07-2016, 03:52 PM | #204 |
義理チョコ
Thaaat's the spirit.
02-08-2016, 10:46 PM | #205 | |
Drives: Firestorm 2013 FR-S
Sounds suspicious for oil that has gotten too hot and is now too low in viscosity. Perhaps the hydraulic lifters are not staying pumped up. I assume your car does not have an oil temp gauge. I know we are supposed to run 0W-20 oil regardless of temp or use, but that is illogical, really. I was running 5W-40 oil in my Abarth in the Los Angeles winter (if you can call it that) but in the summer when the oil got to near 100C the oil pressure at idle was only about 1/2 bar (so about 7psi). So I switched to 5W-50 Castrol. Problem gone. I suspect if you had an oil temp gauge you would have seen 100 or over *C.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
02-08-2016, 10:56 PM | #206 | |
Drives: 2010 MS3
02-08-2016, 11:14 PM | #207 | |
I noted on another thread these engines don't have hydraulic lifters, so that's not what you're hearing You might want to research online or go to bobistheoilguy.com to see what the viscosity of 5W-30 wt oil is at 260F. If the engine is designed to run on whatever the viscosity is at 212F, you will see how far below that you are at 260. IIRC the twin-turbo BMW 335i was programmed to go into limp home mode at 260F because the oil cannot lubricate adequately at that temp. Don't know what viscosity that car used.
02-09-2016, 01:09 AM | #208 |
Drives: Yes
Mine turned out to be a loose bolt in one of the header flanges. Torqued it down and the noise was gone. It's worth a try.
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
02-09-2016, 08:09 PM | #209 | |
Drives: BRZ DGM Limited
I've noticed the sound similar to what the OP posted on page one (that he found was rocker failure) once or twice but only after car is fully warmed up , with lots of stop and go driving, and when the car is at idle but only when the idle is at its lowest point.(which would be when oil pressure is at its lowest) Which makes me wonder if this is an oil pressure issue from using the 0w-20 oil and if moving up to 5W-30 would help. |
02-12-2016, 07:02 PM | #210 |
Yea a 1999 Alero 4 door car for now.(Free so can't complain) Wife is due in 5 months(first kid) and we will be going on my income only for a while. So I have been saving up as much money as we can while she is still working. Thus the car was an easy choice. I was positive on the car plus lower insurance and no car payment.
The Following User Says Thank You to jflogerzi For This Useful Post: | Packofcrows (02-12-2016) |
Similar Threads | ||||
loud knocking constant with engine speed | whatsmynameagain | Issues | Warranty | Recalls / TSB | 34 | 12-09-2014 09:58 PM |
2013 scion frs engine | scion123 | Engine, Exhaust, Bolt-Ons | 16 | 10-13-2014 09:03 PM |
Engine knocking after flash | Tenchi | Software Tuning | 10 | 09-25-2014 11:50 PM |
tapping sound coming from engine | forgotten93 | Issues | Warranty | Recalls / TSB | 11 | 12-23-2013 09:54 PM |
Scion FR-S (2013 2.0L) - Cusco Strengthened Engine Mounts | ptuning | Engine, Exhaust, Bolt-Ons | 0 | 02-04-2013 10:24 AM |
