Forced Induction Turbo, Supercharger, Methanol, Nitrous |
06-23-2013, 01:40 AM | #1 |
Drives: Subaru BRZ Limited
3-bar map sensor wiring
Anyone have an upgraded map sensor, and can tell me the stock wiring scheme? MY new sensor is 3-wire, and the factory has more than that.
Any help, links, etc... Thanks |
06-23-2013, 11:03 AM | #2 |
Drives: 2013 Asphalt FR-S
this may help, compiled from the service manual pdf that is available on this site.
~Namaste~ |
The Following 2 Users Say Thank You to mad_sb For This Useful Post: | Sportsguy83 (06-23-2013), xkalelx (09-01-2015) |
06-23-2013, 12:05 PM | #3 | |
I Love custom Turbo kits
Drives: Limited BRZ
06+ S2000.
06-23-2013, 12:19 PM | #4 |
Its the omnipower ....MAP-K-3BAR
06-23-2013, 12:25 PM | #5 |
Drives: Limited BRZ
I think you are trying to plug it into the MAF sensor instead of the MAP. Are you tring to plug it in in front of the A/C compressor? The MAP sensor sits below the engine cover that says (Subaru Toyota DS4). I bet thats it!!
The Following User Says Thank You to Sportsguy83 For This Useful Post: | King Tut (06-24-2013) |
06-23-2013, 12:28 PM | #6 | |
That what happens when you work all night... hahah, man im a friggin idiot...Been working on this like since 5pm ylesterday. Maybe i need a break. Got to say though, i took it for a quick test run to check for leaks around 3am...man, even with a base tune at like 5psi, what a huge difference....note to self. SEcure fender plastic better if doing that. The wind blew those right into the tires at hi speeds and melted some of the plastic fender liner stuff...hahah David, as always, thanks for the help man, you have been a huge asset! Yes everyone....im an idiot |
06-23-2013, 12:32 PM | #7 | |
Drives: Limited BRZ
You're welcome!!
06-24-2013, 03:06 PM | #8 |
NASA SpecE30 Racer
I had to ask David why my car wouldn't run after I installed my OmniPower 4 BAR MAP sensor.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
The Following User Says Thank You to King Tut For This Useful Post: | Sportsguy83 (06-24-2013) |
07-07-2013, 12:35 PM | #9 | |
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Sent from my Nexus 4 using Tapatalk 2
Nolan
The Following User Says Thank You to pheoxs For This Useful Post: | Sportsguy83 (07-07-2013) |
11-22-2013, 02:46 PM | #10 |
Drives: FR-S 10 series
stupid question as @gdrider77 is apparently using it...MAP-K-3 BAR from omnipower works for the FRS right? I dont plan on going 40+ psi ever so Im about to buy 3 bar for the RSX??
11-22-2013, 02:50 PM | #11 | |
This is what i am using. http://www.rallysportdirect.com/Omni...Bar-MAP-Sensor Do note, you will need a retune for it though. |
The Following 3 Users Say Thank You to gdrider77 For This Useful Post: |
11-22-2013, 02:53 PM | #12 | |
11-22-2013, 03:08 PM | #13 |
you don't really need a tune for changing a map sensor... just need to scale it properly in the map. anyone who can click a mouse can do it. ecuflash/romraider or openflash/tunerpro can both do it (though the values need to be converted depending which software you use).
The Following User Says Thank You to jamesm For This Useful Post: | Pablitomarrero (11-23-2013) |
11-23-2013, 12:56 AM | #14 | |
The Following User Says Thank You to gdrider77 For This Useful Post: | Pablitomarrero (11-23-2013) |
Similar Threads | ||||
is the front o2 sensor a wideband sensor? | mad_sb | Engine, Exhaust, Transmission | 19 | 12-13-2015 02:20 PM |
Map Sensor Hookup? | ft86-UAE | Forced Induction | 22 | 01-08-2015 03:56 PM |
02 Sensor | mjsivee | Engine, Exhaust, Transmission | 4 | 06-13-2013 01:58 PM |
Bad MAF Sensor | paulieblaze | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-23-2012 10:34 PM |
Stock O2 Sensor | d1ck | Engine, Exhaust, Transmission | 1 | 07-11-2012 07:16 AM |
