Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
06-03-2015, 11:28 AM | #15 |
Drives: 2013 FR-S M/T Ultramarine
Same one on mine came cross threaded from the factory. I just snapped it off since I had all new parts. Then made my way to the o2 sensors since I was putting on my OFH, one of those was also cross threaded from the factory as well so, had to get a new o2 sensor. Really sad considering that's how it came from the factory.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2. OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1 C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can |
06-04-2015, 02:04 AM | #16 |
Marine Electrician
Drives: Toyota TRD86, 2014
That shit happened to me too, at the exact same location, probably an over tightening from the factory.. But I cut it off, then drilled it out with pure titanium drill, then just replaced the bolt and nut
Good luck..
My Toyota TRD86 can be found here:
http://www.ft86club.com/forums/showthread.php?t=63303 |
06-04-2015, 02:32 AM | #17 |
No choice, sell it.
06-04-2015, 01:23 PM | #18 |
Drives: 2013 Firestorm FR-S
update: i brought it to a shop, they welded a head onto it, heated it up, took it out, along with the threads , so they retapped it to a bigger diameter, and then just put in a new bolt and nut. Also charged me 70$. lesson learned...
going to get my headers professionally installed. |
06-04-2015, 01:36 PM | #19 | |
Drives: Slow
06-04-2015, 11:20 PM | #20 |
Drives: 2012 Toyota 86
stripping a bolt was either incorrect wrench size, cheap wrench, or a bolt that was so stuck, something had to give. i think you can tackle the header your self, its pretty straight forward.
06-05-2015, 12:04 AM | #21 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Six point sockets. Every time.
"I gotta rock." -- Charley Brown |
The Following User Says Thank You to bcj For This Useful Post: | Thedishdoc (03-08-2019) |
06-05-2015, 12:12 AM | #22 |
hey you, yeah you <3
Drives: 2014 37J FR-S
dafuq is that tool??? I messed up some nuts (weather/me over tightening 'em) and cant seem to get them off! Thats a bad@ss tool.
06-05-2015, 12:36 AM | #23 |
Geo Tyrebighter Esq
06-05-2015, 12:45 AM | #24 |
Ordered the one in vid off of e-bay. $15 w/ shipping. I'll let you guys know how it is when it gets here!
06-05-2015, 10:11 AM | #25 | |
Drives: RAVEN
google up "Nut Breaker" and you will find a ton of examples. Pretty cheap at the discount tool places, I paid like $15 for the ones I have. They come in a few sizes. I do a fair bit of Brit car restoration and between heat and these things I manage to get most things apart without breaking them. The person who posted "cheap wrenches or wrong size wrenches was also right |
The Following 3 Users Say Thank You to NOHOME For This Useful Post: |
10-07-2018, 01:00 PM | #26 |
Drives: 2017 86 6-Speed
Glad you got it taken care of, if you don't have the tooling it's probably no t cost effective to do it yourself.
For future reference, there's really about a hundred things you can do. There's really no magic way to get stuck hardware apart without effort, you just have to be more stubborn than the thing you're trying to get apart. In your situation my first attempt would be to heat the nut up red hot (concentrate the heat on the nut, not the stud), and then put some vice grips on the nut and it should spin right off. The heat will expand the nut causing it to loosen. Rather than vice grips, you can also take a pointy chisel or punch, and try to hammer the nut in a circle. Hit the face of the flat kind of close to a point in the direction you want to turn the nut. You'd be surprised how effective that is, if you can get a good swing at it, it acts like an impact. If you have a good socket selection, you can also sometimes hammer on a 12 point socket, one size smaller (metric or standard, whatever fits) and grab the nut that way. You can also take a die grinder with a burr or cutting disc (whatever fits), cut the thing off, and then drill the stud out of the header flange. As said above, in terms of not rounding it to begin with, wrench quality is important here. Better wrenches have much tighter tolerances and harder steel so they flex less, plus they are designed to grab the flats of the hex rather than the points. This is why you see the pro guys shelling out $500+ for a set of wrenches from sk/armstrong/snapon/whatever.
2017 86 set up for CS STX autocross
10-08-2018, 02:15 PM | #28 |
I'm trying to understand what you stiped. First of all there is no "bolt". The overpipe has a threaded hole in it. There is then a threaded stud which screws into the overpipe. Then you have a nut that screws onto the stud. So which is stripped? The nut, the stud or the overpipe itself? If it's the nut, replace the nut. If it's the stud, replace the stud. If it's the overpipe then drill it out and replace the original stud/nut with a bolt and nut.
Here is the stud: https://parts.toyota.com/p/STUD-BOLT...U00301117.html Edit: Nevermind, I see you took it to a shop. |
Tags |
bolt, front pipe, head, over pipe, stripped |
Similar Threads | ||||
Greddy Evo 3 Front Pipe Connection Pic Request | mad_sb | Engine, Exhaust, Transmission | 10 | 05-24-2017 09:41 PM |
P/N for Front Pipe Hanger Bolt | DarkSunrise | Engine, Exhaust, Transmission | 2 | 07-01-2015 12:47 PM |
Gains from aftermarket catted front pipe vs stock front pipe? | Vmax911 | Engine, Exhaust, Transmission | 4 | 01-20-2014 01:42 PM |
What is the difference between a Front pipe, a down pipe and an over pipe? | liajet24 | Engine, Exhaust, Transmission | 5 | 09-19-2013 10:03 PM |
