Software Tuning Discuss all software tuning topics. |
12-10-2014, 10:11 AM | #15 |
OBDII Bluetooth scanner: ($19.99) [ame="http://www.amazon.com/ELM327-WIFI-OBD-Automotive-Diagnostics/dp/B00AQ99UQ0"]Amazon.com: Simvalley ELM327 WIFI OBD II Automotive Diagnostics Scanner for iPhone iPad iPod Touch: Automotive[/ame]
OBD Fusion app (iPhone) ($9.99) https://itunes.apple.com/us/app/obd-...650684932?mt=8 For less than $30 you can find out what the CEL is, and not have to do the "battery-disconnect-without-actually-finding-out-what-the-CEL-is" method. |
12-10-2014, 12:16 PM | #16 | |
Road-hole
Drives: 2013 Whiteout FR-S
I had a code throw...
Jaden |
08-27-2016, 12:19 AM | #17 |
Drives: white brz
i connected my oft the turned off my car came back a half and hour later and had a check engine light out of no where any ideas as of why the check engine light came on its annoying the fuck out of me and has me scared to drive my car help
08-27-2016, 03:16 AM | #18 |
Drives: Subaru BRZ
Sometimes if you plug or unplug the OFT while the car is on, the check engine light will come on. Turn your car on and off a couple of times and it should clear.
08-27-2016, 05:44 AM | #19 | |
use your oft to read code then google the code plus subaru eg google " U0150 subaru" if its a communication loss code then dont worry |
08-27-2016, 06:52 AM | #20 |
Drives: white brz
t
09-03-2016, 11:47 PM | #21 |
Drives: SWP BRZ
01-05-2019, 03:48 PM | #22 |
Drives: '17 BRZ Dark Grey Sport-tech 6MT
Bringing the thread back from the dead a couple years later. OFT says no ECU fault on a 2017 BRZ with catless UEL and stage 2+ tune. Code reader says P2270. O2 sensor signal stuck lean - bank 1 sensor 2.
Guessing this means the 91 premium gas I just filled up with from empty is not so premium. I usually run 93 but switch to 91 in winter. First time at that gas station. I cleared the code and it did not come back right away. OFT shows LTFT between 0.00 and 0.78. STFT < 5 and AFR about 14.5 in normal driving. |
01-06-2019, 07:20 AM | #23 |
Drives: UK GT86
That's the rear sensor.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | OrangeGuitar (01-06-2019) |
01-06-2019, 11:14 AM | #24 |
With a catless header, wouldn't this be expected? The sensor measures the efficiency of the cat which in this case is missing. Wouldn't the stage 2+ tune account for that? I guess I should check if the sensor came loose at least. New gas might have been a coincidence though. I've been running with this tune and header for the last half year.
01-06-2019, 01:36 PM | #25 |
Drives: brz 2017 hksv2
the code for catless is p0420, that code you have I think it s because you ( or who did the install) damaged the rear sensor or its wiring and the ecu is getting a stuck voltage from it, warning you it s not working
01-26-2019, 04:01 PM | #26 |
I reset it and it came back after a few days then cleared on it's own a day later. After a fresh tank of better gas, it has not returned after a couple of weeks. OFT did not read the code when the light was on.
Similar Threads | ||||
traction light, engine light = cam sprocket , ecu | nivek111070 | Issues | Warranty | Recalls / TSB | 27 | 03-13-2016 09:28 AM |
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? | djdrugga24 | Issues | Warranty | Recalls / TSB | 3 | 06-25-2014 06:06 AM |
Will I get a check engine light on if the engine bay has a direct injection failure? | Astroboy | Engine, Exhaust, Transmission | 7 | 03-29-2014 06:16 PM |
Recognize these parts? | Uoeno | Cosmetic Modification (Interior/Exterior/Lighting) | 32 | 07-22-2013 02:42 PM |
Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
