02-10-2019, 06:03 PM | #897 |
Drives: FT86
Yes you can message me
02-10-2019, 07:57 PM | #898 |
Drives: FT86
B01C is compatable with 700C just later factory version
02-11-2019, 11:33 PM | #899 |
Drives: 2014 Hot Lava
Does anyone have N10C / ZA1JN10C EcuFlash definition file?
02-12-2019, 06:23 AM | #900 |
Drives: FT86
No its not been defined, however you can use the euro K00G as a subsitiute rom amd its been defined
If you jist want to flash back a stock N10C you can make a flash only definition see first post in this thread |
02-14-2019, 12:11 AM | #901 |
Drives: 2017 BRZ Premium
v4.03 for MY17 US MT (ZA1JK00C) has been giving more and more bucking after an upshift and a throttle, so I flashed back to stock.
Are there v2 or v3 available for this model? Not sure how to fix the bucking issue, but am on the search of it / learning how to modify values on RomRaider. |
02-14-2019, 04:03 AM | #902 | |
Did going back to stock help? Not sure I’ve seen anyone complain about bucking on OTS tunes. |
03-02-2019, 04:00 PM | #903 |
Moutain Runner
I hate to be that guy...but can someone spoonfeed me the process of flashing my 2018 BRZ MT to the v4.03 e85 tune?
I have everything done except for the checksum modifications. Tried speaking with Steve, but I could not figure out where to move the def.zip from the first page to...nor where to add the below text to. < rom> <romid> <xmlid> ZA1JK00G</xmlid> <internalidaddress>8000</internalidaddress> <internalidstring>ZA1JF00C</internalidstring> <ecuid>A929703007</ecuid> <year>2017</year> <market>USDM</market> <make>Subaru</make> <model>BRZ</model> <submodel>FA20</submodel> <transmission>MT</transmission> <memmodel>SH72531</memmodel> <flashmethod>subarubrz</flashmethod> <checksummodule>subarudbw</checksummodule> Last edited by Chuckls; 03-02-2019 at 05:23 PM. |
03-04-2019, 04:35 AM | #904 |
Drives: Toyota GT86 First Edition 53/86
Did anyone find out the address to log the rear O2 sensor voltage on A01G?
Interested in fitting a wideband at the rear and feeding the narrowband signal back to the ECU. OFT can read it, but I didn't find anything for OpenPort. Maybe @ztan? |
03-04-2019, 05:02 AM | #905 | |
Drives: FT86
Other option is to recale thte srock front 02 sensor it reaels pretty well down to about 10 afr no real need for separate wideband http://www.ft86club.com/forums/showthread.php?t=82875 Last edited by steve99; 03-04-2019 at 05:27 AM. |
03-04-2019, 05:18 AM | #906 | |
Drives: FT86
attached is a flash only def for K00G rom for ECUFlash do your editing in romraider then flash with ecuflash |
03-13-2019, 06:27 PM | #907 |
Drives: 13 White MT FR-S
Possible to use tactrix and RR to turn off abs and vsc like the 86nanny did?
03-14-2019, 04:48 AM | #908 |
Drives: FT86
03-14-2019, 04:54 AM | #909 |
Drives: brz 2017 hksv2
how do OFT and obd modules force Pedal dance mode?
03-14-2019, 06:54 AM | #910 |
Tactrix EcuFlash Info for BRZ 86 FRS Rom flash update and logging
The OFT does it by sending packets, not by changing the rom. You could write an app to send the CAN bus packets using the Tactrix to do all sorts of things but you can’t use RR to customize the rom and then flash it for a permanent fix.
If you want to get into CAN bus hacking you would be better of with an Arduino and a CAN bus shield. There aren’t any Linux drivers for the Tactrix and you don’t want a full windows machine in your car just to send some CAN bus packets. |
The Following User Says Thank You to ermax For This Useful Post: | tomm.brz (03-14-2019) |
Tags |
ecuflash, tactrix, taxtrix, tuning |
Similar Threads | ||||
ECUFlash - Getting close! | xjohnx | Software Tuning | 698 | 03-22-2015 12:10 PM |
EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
Tactrix Openport | jamesm | Engine, Exhaust, Bolt-Ons | 1 | 01-28-2014 08:27 PM |
Visconti Tuning - Latest BRZ Flash Info | Visconti | Software Tuning | 6530 | 12-24-2013 10:18 PM |
Overboost Protection With OFT/EcuFlash? | FrX | Software Tuning | 9 | 10-23-2013 07:27 AM |
