Old 01-30-2019, 11:03 AM   #729
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Installed the 2017 cluster last night. Spent way too long in a 30F car to figure out where the security programming was, but I think it was worth it in the end. Just need to order the buttons and be good to go.
The Following 6 Users Say Thank You to DustinS For This Useful Post:
eastendraceshop (01-30-2019), Kiibiiin (01-30-2019), MCTeeJ (01-30-2019), Sportsguy83 (01-30-2019), Teseo (01-30-2019), Zer0 (01-30-2019)
Old 01-30-2019, 11:59 AM   #730
Zer0
Drives: 2015 frs
Nice update. looks good
Zer0 is offline   Reply With Quote
The Following User Says Thank You to Zer0 For This Useful Post:
DustinS (01-30-2019)
Old 01-30-2019, 12:19 PM   #731
Lantanafrs2
Drives: 2013 frs red
Thank you for letting me live vicariously through your obsession lol
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Old 01-30-2019, 01:58 PM   #732
Face_Plant
Face_Plant's Avatar
Drives: 2015 Scion FR-S
How tough was the swap? That looks awesome.
Face_Plant is offline   Reply With Quote
Old 01-31-2019, 09:54 AM   #733
DustinS
DustinS's Avatar
Not too difficult. Hardest part was getting security programmed. Something the dealer can do very quick and easy. I just wanted to see if it was possible for people that have Techstream to do it themselves.
Unless you are changing LEDs in the cluster, than that is the most difficult part.
The Following User Says Thank You to DustinS For This Useful Post:
Zer0 (01-31-2019)
Old 02-01-2019, 11:06 AM   #734
DustinS
DustinS's Avatar
Video of how to program the cluster.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
T-Steve (02-06-2021), Zer0 (02-01-2019)
Old 02-04-2019, 02:05 PM   #735
DustinS
DustinS's Avatar
Picked this up from the junkyard over the weekend. Not sure if I will use it, but can't beat junkyard prices for a 2J.
MCTeeJ (02-04-2019), Zer0 (02-04-2019)
Old 02-20-2019, 10:25 AM   #736
DustinS
DustinS's Avatar
New Radiator Came in:
Zer0 (02-20-2019)
Old 02-20-2019, 11:52 AM   #737
Zer0
Drives: 2015 frs
That radiator looks good. What are the dimensions? Looking into doing a V mount once I get the crossmember project done.
Old 02-20-2019, 12:16 PM   #738
DustinS
DustinS's Avatar
~ 27" x 13.25" x 3"
Zer0 (02-20-2019)
Old 02-26-2019, 12:27 PM   #739
jflogerzi
jflogerzi's Avatar
Those fans look super beefy
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
DustinS (02-26-2019)
Old 03-01-2019, 09:32 AM   #740
DustinS
DustinS's Avatar
Oil Pump came in yesterday. Will get better pictures later. Should help with the oil pressure issues. As soon as the weather quits giving us one 60 degree day and then a week of 20 degree days, I will start tearing the car apart to get everything buttoned up.
Old 04-03-2019, 03:33 PM   #741
DustinS
DustinS's Avatar
Engine is ready to come out. Ran out of time last night.
I don't think my current catch can is enough. Going to try and figure out another solution before the engine goes back in (which I hope to be next week)
This shows more build up and the flakes of nylon or whatever is woven around the trickflow hose. Super cheap and has actually worn off. Will be replacing with vibrant hose. The fibers are just from taking the intake off, they weren't actually being sucked into the intake while running.
Trans leak is still as bad as before. Plan is to try and remove just the tail housing and reseal, worst case I send it to someone to have diagnosed.
Wasn't going to do a whole lot while engine was out, but things keep popping into my head. Improved Racing Crank Scraper/Windage tray, as well as Energy Suspension full bushing kit, and Whiteline offset front control arm bushing have been added. Hopefully get everything in before next weekend.
Zer0 (04-04-2019)
Old 04-04-2019, 12:30 AM   #742
Zer0
Drives: 2015 frs
You can't go wrong with oil system upgrades.
DustinS (04-04-2019)
The reason I'm always broke - Dustin's Supercharged 86 Dustin Member's Car Journals 211 11-08-2015 10:57 AM
Help! New Car Engine Blew Up. What are my rights? Obsidiank Scion FR-S / Toyota 86 GT86 General Forum 53 12-11-2014 11:43 AM
Midwest Modified - Auto Photography by Dustin Faulkner (aka Fancy) Kuzuri Great Lakes 20 02-16-2014 05:23 PM
Engine Warm-up Time Chad86 Scion FR-S / Toyota 86 GT86 General Forum 44 01-10-2014 12:03 AM
So my engine blew up.... alliedcam1 Engine, Exhaust, Transmission 57 12-28-2013 02:50 PM
