Old 05-29-2012, 02:42 PM   #183
86purity
Drives: 95 MR-2 Turbo, 08 Evo X GSR
Originally Posted by uspspro View Post
The Rotrex has so many good points. Sure it won't make the mid-range punch of a properly sized turbo, or the off-idle torque of a roots/twin screw, but it has several things going for it. I had one on my MR2 Spyder for a good while, before I went with the 3.5L V6 swap.
1) It's quiet. They use planetry rollers with traction oil, instead of gears. So there is no gear whine like other superchargers. I view this as a plus, I like the sound of the engine not to be drowned out by the SC. It will make the engine quite a bit louder and more "serious", lots more induction sucking sound and louder exhaust. The sound is awesome, and this is a huge plus IMHO.
2) It is reliable. Self contained oiling system with oil cooler, reservoir and filter. Alll of the components are compact, and can be installed easily. Rotrex is also the OEM supercharger for the Koenigsegg ccx (although they use two of them)
3) The boost ramp is much better than typical centrifugal blowers. The planetary rollers, high gear ratio, and well designed compressor housings allow the boost to ramp up quickly.
4) The use of restrictors. You can place a restrictor on the compressor inlet, which allows a maximum air flow, thus limiting the maximum boost. This allows you to use smaller SC pulleys to spin the SC up to higher boost numbers at lower RPM, but not have some stratospheric max boost. For my build, I used forged 9.0:1 pistons, so I did not use a restrictor and boosted up to 17psi. However for a stock bottom end with high compression, the restrictor makes perfect sense. Imagine a pulley capable of delivering 15 psi at redline, but with a restrictor keeping it at 8psi instead. You will probably see that 8 psi pretty early in the mid-RPM range and then it will hold that boost level. HKS has information about restrictors.
5) Packaging and heat. The compact packaging allows for good placement in the engine bay, and makes it easy to install an intercooler. Also, the SC produces MUCH less heat than a turbocharger. This leads to a more reliable setup: Easier to keep temps in check, less "baking" of engine bay components, better intake air temperatures.
I think a 250 rwhp Rotrex kit would be perfect for this car, IMHO... And, if they so chose, power-mongers can change out the restrictor and pulley along with a built bottom end and go for 350+
Very informative! Just about what I was thinking! The SC seems to make more than I expexted (75whp) with the high compression. This would be plenty for street use. I'm a bit of a purist, and NA is so visceral, so I may go with a top end build from Cosworth when they have it available. I could do the SC myself though. Tempting!
86purity is offline   Reply With Quote
Old 05-31-2012, 09:07 AM   #184
wcbjr
Drives: 2006 Subaru LGT
[ame="http://www.youtube.com/watch?v=t17hw2A8olw"]【HKS Racing Performer 86】 GT Supercharger spec test run - YouTube[/ame]
wcbjr is offline   Reply With Quote
The Following 3 Users Say Thank You to wcbjr For This Useful Post:
ESBjiujitsu (05-31-2012), Sonex51 (06-02-2012), [es vi: eks] (06-03-2012)
Old 05-31-2012, 09:10 AM   #185
wcbjr
10:50 mark for shots of the supercharger that we have already seen
Old 05-31-2012, 12:29 PM   #186
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
can someone translate if any good info is being shared? thanks
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 06-02-2012, 05:17 PM   #187
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Can customers have air conditioning and supercharger together? Can't bear the though of no A/C in this day and age
Tradewind is offline   Reply With Quote
Old 06-02-2012, 06:43 PM   #188
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Yes, that vid cleared out that question.
In the vid SC is for public, stock engine SC kit... which equal to yes on AC.
Old 06-02-2012, 08:28 PM   #189
gearheinz
Drives: FRS
ive installed many turbo and SC kits, and in my opinion HKS is by far the best for many reasons. let me list the ways.
1. fitment is great. small amount or no molestation to the chassis and body parts. some kits require you to cut this, notch that, whole saw here..... who wants to cut up their brand new car. they also cast alot of intercooler piping pieces to fit into small areas. this reduces the number of intercooler pipe and silecone couplers you have to use (less chance of one poping off).
2. parts last very long. Most of the SC brackets are casted with supports in them to reduce vibration. this will in long term extend the life of bearings and belts.
3. although their bolt-on kits arent rated at high hp, the power band is very strong. so if your daily driving it feels like twice the ponies
4. all hardware included in their kits are top notch. fitting are usually steel, not brass pluming ones from the hardware store(that some companies use. rubber hoses and vacuum line have a thick wall thickness so they dont bind around tight spaces. oil feed and return lines are made specific for every application, some companies provide you with 2 fittings and 10ft of coolant hose and have you make them your self.
5. install is straight foward with good instructions(lots of pictures)
6. never have to remove AC or PS
7. quality control is great! never parts missing or broken.
all in all, if your looking for a FI kit to get with the least amount of headaches, HKS is the way to go. the extra money spent is worth it
here is an example of the HKS Nissan 350Z and Honda CRZ kit.
gearheinz is offline   Reply With Quote
The Following 3 Users Say Thank You to gearheinz For This Useful Post:
Bahraini86 (06-04-2012), ESBjiujitsu (06-04-2012), Primo86 (06-03-2012)
Old 06-02-2012, 08:44 PM   #190
CoRi J
Xenogear
Drives: 2013 Scion FR-S, Ultramarine
This will be my biggest project to save up for!
CoRi J is offline   Reply With Quote
Old 06-02-2012, 09:32 PM   #191
Tradewind
Has the SC kit for the 86/BRZ been tested for use at high temperatures, is it good for sustained operation in 90F + ambient temps?
Old 06-03-2012, 06:38 PM   #192
catharsis
Drives: honda civic si 08
if its intercooled it should be fine imo.
catharsis is offline   Reply With Quote
Old 06-03-2012, 07:02 PM   #193
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
So very tempting.. If Subaru and Toyota decide not to do anything with this chassis when I'm ready to trade in, this will likely be the route I go.
Old 06-04-2012, 01:50 PM   #194
86purity
I really can't see the kit making more than 250 crank HP due to the high compression of the stock motor unless the dyno run included a reworked exhaust. 250 is fine though. Probably just right for this car. If you want huge power just get an STi.
Old 06-04-2012, 03:10 PM   #195
wcbjr
drop the compression to 10:1, add in 7 psi, and you get exactly 250hp.
Old 06-04-2012, 04:34 PM   #196
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
I the issue here is the limitation of the DI system, not the compression. Can't see a budget way to make the DI work effeciently at higher boost!
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr)
Bahraini86 is offline   Reply With Quote
86 forum, 86 forums, 86 supercharger, fr-s forum, fr-s forums, fr-s supercharger, fr-s video, fr-s videos, frs forum, frs forums, frs supercharger, gt 86 forum, gt86 forum, gt86 forums, scion fr-s forum, scion fr-s forums, scion fr-s supercharged, scion fr-s supercharger, scion fr-s video, scion fr-s videos, scion frs forum, scion frs forums, scion frs supercharger, scion frs video, scion frs videos, supercharged fr-s, supercharged frs, supercharged toyota 86, supercharged toyota gt 86, supercharger, toyota 86 forum, toyota 86 forums, toyota 86 supercharger, toyota 86 video, toyota 86 videos, toyota gt86 forum, toyota gt86 supercharger, toyota gt86 video, toyota gt86 videos
Supercharger or Turbo ? #87 Forced Induction 192 01-25-2013 10:20 AM
Supercharger for Infiniti G25 Lottta Other Vehicles & General Automotive Discussions 2 02-12-2012 09:10 PM
Arrested Development coming back? iff2mastamatt Off-Topic Lounge [WARNING: NO POLITICS] 0 10-13-2011 04:09 PM
