Old 09-18-2019, 02:46 PM   #435
scuzzy
Drives: 22 BRZ limited MT
Car Buzz is now confirming the rumor by Torque News that confirmed the rumor by BestCar.
What more proof do we need people?
The voices in my head approve this message.
scuzzy is offline
The Following 3 Users Say Thank You to scuzzy For This Useful Post:
Hoahao (09-19-2019), soundman98 (09-18-2019), Tcoat (09-18-2019)
Old 09-18-2019, 02:56 PM   #436
Don't worry. Eventually the things will become so top heavy that BestCar will quote the one, quoting the one, quoting the one, quoting the one, quoting the one, quoting them as new information.
Tcoat is offline
Old 09-18-2019, 03:52 PM   #437
DarkSunrise
DarkSunrise's Avatar
Originally Posted by Yoshoobaroo View Post
Why would the 2.4 be any heavier? The exterior dimensions of the engine are the same. It is a 9.5% increase in bore diameter. That's it.
That's assuming they would use the same transmission, driveshaft, axles, brakes, etc. I'd say the chances of a switch to a higher hp, larger displacement engine without any weight gain would be slim to none.
2022 BRZ Build
2013 FR-S Build
DarkSunrise is offline
The Following 4 Users Say Thank You to DarkSunrise For This Useful Post:
86MLR (09-18-2019), Adam_L (09-18-2019), Tcoat (09-18-2019), Yoshoobaroo (09-18-2019)
Old 09-18-2019, 04:14 PM   #438
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Yeah, it would increase in weight by at least 70-80 lbs, by going to a 2.4L , but if they can offset that weight in other areas of the car.....then that would be the master plan (as others have eluded to).
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline
Old 09-18-2019, 05:36 PM   #439
ZDan
ZDan's Avatar
Drives: '23 BRZ
Going from a 2.0 to a 2.4 doesn't necessarily mean added weight...
Legend has it that Chevy engineers used weight savings from larger bores in the same block as an argument to go from 427 to 454 c.i. way back when
ZDan is offline
Tcoat (09-18-2019)
Old 09-18-2019, 05:36 PM   #440
ermax
ermax's Avatar
More confirmation from Toyota on next gen 86
I was talking "as built now". It IS a lower revving engine. Or more accurately the power is delivered at lower revs. No doubt it could be designed to rev faster for an NA application but we are back to what would be the cost to emissions and mileage?
Gotcha. I think you’re right, emissions will be the hold up.
ermax is offline
The Following User Says Thank You to ermax For This Useful Post:
Tcoat (09-18-2019)
Old 09-18-2019, 06:15 PM   #441
Comparing apples to pumpkins though. I do not believe that the FA24 is just a bored out FA20 (anybody?) but a dedicated block all on it's own. They can get weight savings by boring out a big cast iron V8 with loads of material to spare. Boring out an aluminum boxer block that is already as compact as they feel they can safely make it is a whole different matter.
Tcoat is offline
gravitylover (09-18-2019), why? (09-19-2019)
Old 09-18-2019, 06:23 PM   #442
They gave the 17 5HP and it went up a few pounds. The idea of higher HP with less weight is a pipe dream. Not sure how they could save more weight anyway without going to materials that are going to jack the price. Hell, as you said everything would need to be heavier to deal with the power so all of a sudden it is a $55K car that everybody will still say is under powered and too heavy for the price.
Tcoat is offline
Old 09-18-2019, 07:21 PM   #443
Dirty Harry
Dirty Harry's Avatar
Drives: 2013 BRZ Satin White Pearl
https://www.motoring.com.au/tokyo-mo...reveal-120681/
And the “pièce de résistance”, article from motoring.com.au
Interesting to see if anything is revealed at the Tokyo Motor Show next month according the article.
Letter to the editor if it’s wrong lol: mike.sinclair@carsales.com.au
Dirty Harry is offline
Old 09-18-2019, 07:21 PM   #444
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
FWIW, when the ND came out Mazda said it only had 155hp to keep the weight of the driveline, brakes, spindles, etc, down.
Then 4 years later they drop 30 more horses in it and they don’t beef anything else up.
Point I’m making is that all of the components in the car have a healthy factor of safety in them (min FS of 2-3 is common in automotive), so a 10% bump in HP probably doesn’t require much redesign if any.
Yoshoobaroo is offline
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
Tcoat (09-18-2019)
Old 09-18-2019, 07:37 PM   #445
Ahhh but see that is the kicker. Everybody seems to think (want?) at least a 30% increase. People are already replacing almost every single component from brakes to suspension because they are not robust enough to take track time. A built in safety factor is exactly that and it doesn't mean there is room to keep adding power. If they add poser they will beef up enough to maintain that safety factor proportionally.
Tcoat is offline
Old 09-18-2019, 07:41 PM   #446
Yoshoobaroo
TRACKBREAD
If the power is higher than 226hp I’ll eat my hat.
I’ll also have to buy a hat first.
Tcoat (09-18-2019)
Old 09-18-2019, 07:47 PM   #447
Agreed! But 226 is not the rumour.
Tcoat is offline
Old 09-18-2019, 08:07 PM   #448
So now they attribute the platform "change" to Bestcar? In the other article that you posted they said it was "insider" info. They can't even remember what they wrote on the subject a couple of months ago. Distinct possibility that it was their article that Bestcar used to justify the claim of a change to the Toyota platform. It has probably gone full circle now and will continue to spiral. The good news is we only have to wait a month to see who is right.
https://www.motoring.com.au/new-toyo...atform-118087/
Tcoat is offline
why? (09-19-2019)
I'd read it was possible but here is confirmation Bodalenko AUSTRALIA 22 09-14-2015 08:57 PM
Part confirmation SubaSteve Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-25-2014 06:15 PM
Pioneer AVIC-X940BT confirmation FR-Shadow Electronics | Audio | NAV | Infotainment 35 11-29-2012 05:08 PM
Confirmation BRZ nav can play DVDs R0ME0 Electronics | Audio | NAV | Infotainment 21 11-14-2012 07:25 PM
Driver side controls confirmation please phanguy Scion FR-S / Toyota 86 GT86 General Forum 2 07-31-2012 03:17 AM
