04-11-2018, 02:04 PM | #15 | |
Drives: '15 BRZ RA
Here is the original communication by Yokohama. They say that the tire meets the official Gazoo regulations. It would be a madness Bridgestone to be allowed to use the RE71R tire and Yokohama to come with a tire that had a much softer compound. http://www.y-yokohama.com/release/?id=2881 Do you have any idea about racing regulations or are we losing our time here? In the specific races they cannot use whatever tire compound. |
04-11-2018, 02:13 PM | #16 |
Yeah, it's probably not the way to make my point. My point was that it seems like the compound is faster. That along with that size being a half inch shorter means that tire width and wheel width are a couple of many variables and is foolish to think you know that it's those variables instead of, imo, much more important variables like compound and drive ratios.
Drive upgrades. Don't buy them.
The Following User Says Thank You to fatoni For This Useful Post: | venturaII (04-11-2018) |
04-11-2018, 02:59 PM | #17 |
Drives: '15 BRZ RA
No, the clue is that the wheel/tire selection on the TRD 14R60 car was wrong or guided entirely by the marketing department. How many customers would buy a 6.3 million yen car with narrow tires? Are you aware that this one was inspired by the Griffon TRD 86 car which made a lap time of 58"407 at the same track? All the other equipment of the 14R60 car like the final drive/gear ratios you mentioned, the compound and all the rest of the factory modifications which it looks you are unaware were very competitive. Issue is that the wheel/tire size was too much for the specific stock power levels and in general for a car on similar power levels.
04-11-2018, 03:27 PM | #18 |
Drives: '23 BRZ
There are WAY too many variables other than tire size to draw the conclusion: quicker because smaller tires...
Test the same car, same make/model/age/heat-cycles tire, same day, same driver, only difference being tire width, and then you have a valid comparison. Road and Track did a test like this, but unfortunately didn't test tires of the same diameter (215/45-17 = 24.7", 235/40-18 = 25.4"), so different gearing and c.g. height. If only they'd tested a 245/40-17 vs. 215/45-17... https://www.roadandtrack.com/car-cul...ransformation/ Car went 6 tenths faster lap time on the 215/45-17 StarSpecs vs. 235/40-18. However pulled slightly more g's and quicker slalom time on the 235s... |
04-11-2018, 03:44 PM | #19 | |
04-11-2018, 03:52 PM | #20 | |||
There is no such thing as perfect size, compound, tread, sidewall, weight and so on for tires that applies to all applications. The same tires, on the same car, on the same track can perform radically different depending on weather conditions the surface or even the layout so saying one is better than the other no matter what the application is not possible.
The Following User Says Thank You to Tcoat For This Useful Post: | nikitopo (04-12-2018) |
04-11-2018, 03:58 PM | #21 |
Drives: Crapcan
If you wanted an example of this it would be the same brand tire, on the same car, with same setup except camber optimized for each tire width.
This comparison is like asking someone to watch me throw two different sized rocks, and then judging which one went faster. |
04-11-2018, 03:59 PM | #22 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Tcoat. Don't forget the other variable - driver. Different drivers with different styles can use tires in very different ways.
Slow is smooth, and smooth is fast
04-11-2018, 05:12 PM | #23 |
StreetKart
Drives: 2014 Scion FR-S Monogram
treadwear numbers mean absolutely nothing. It's a HORRIBLE way to class tires.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
The Following User Says Thank You to Roadcone For This Useful Post: | nikitopo (04-12-2018) |
04-11-2018, 05:55 PM | #25 | |
Only users lose drugs.
Drives: All the time
Actually, they're not specifically classed by tw rating. Grand Touring Summer, 240-300tw: https://www.tirerack.com/tires/tires...iEcoContact+EP Max Performance Summer, 340tw: https://www.tirerack.com/tires/tires...remeContact+DW Which one handles better? People just assume that a lower number means stickier rubber, but it's a WEAR rating, not a grip rating. Lots of factors affect both characteristics, and classification.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post: | nikitopo (04-12-2018) |
04-11-2018, 05:57 PM | #26 |
Or how RS3s went from 140 to 200 from one season to another?
The Following 2 Users Say Thank You to venturaII For This Useful Post: | JazzleSAURUS (04-12-2018), nikitopo (04-12-2018) |
04-11-2018, 06:05 PM | #27 |
Drives: 2023 BRZ
I love it when people start threads to justify their purchase decisions.
04-11-2018, 06:16 PM | #28 |
Weight Weenie
Drives: 15 FR-S
If 205's are good why not go down to 195?
Similar Threads | ||||
What am I missing with all the ultra-wide wheels & tires? | Vdub | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 53 | 07-14-2017 08:08 AM |
What are some good slippery narrow tires? | PowderfaceTr. | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 38 | 02-07-2015 12:14 AM |
Tires that run wide or narrow | switchlanez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 12-08-2013 03:55 PM |
I have a 18x7.5+38 wheels..How wide can i go with tires | Bmore_Raven86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 07-23-2013 12:04 PM |
235 mm tires, great fit but not too wide | Black Tire | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 02-07-2013 08:38 AM |
