Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
02-11-2014, 06:24 PM | #113 | |
Codename: Stitch
L: -1.6* R: -2.2* Fronts using the OEM crash bolts are L: -1.1* R: -1.5* As you can see there is some variance from L to R but this is seen even on the factory alignment. If you have crash bolts or camber bolts for the front you can have things adjusted if you prefer to even them out a bit, but since I don't have LCAs and have no ability to adjust on the rear, I felt it was better to leave the variance in place.
02-11-2014, 10:16 PM | #114 |
Drives: 2013 FRS- Hot Lava
I'm split between these and the hotchkis or Tanabe springs. I want the mildest drop possible due to speed bumps at work...any thoughts?
09-27-2014, 10:02 PM | #115 |
Drives: Brz
What size tires / rims are on the car ? (With the eibach pros)
05-15-2015, 02:56 AM | #116 |
Drives: '13 FR-S
Bump
The BRZ and the FRS have different suspension. Not to mention the 2015 model upgrades. So I'm wondering how this kit manages to ride with BRZ shocks vs. FRS shocks. I do believe they are valved differently. |
05-15-2015, 09:29 AM | #117 | |
Drives: point A to point C. Screw point B!
I have no idea on the 2015 models - The suspension dampers are new part numbers, but there's a lot of misinformation around on what's what, and I haven't bothered to sift through it. |
05-15-2015, 04:26 PM | #118 |
Drives: 13 SWP BRZ
so if i swap my 2013 BRZ OEM springs to prokits, it will handle more like the FR-S with more oversteer?
08-02-2015, 12:29 AM | #119 |
junior mafia
Drives: ‘20 sti limited
just made this swap as the very first (and possibly last) mod to my brz. i had prokits installed in my 95 mustang back in the day and liked the ride and the height adjustment so i went with the same to the brz. its actually a perfect drop, not terribly low but noticeably not quite stock rally height.
i have two sets of speed bumps in my apartment complex that i could take at about 5 mph stock and now i try to roll over them as slow as possible - they don't feel like they compress the suspension too much when theyre taken that slow. i only have about 50 miles put on them since the install but the handling still feels super tight and the ride really isn't that much rougher than stock. the one downfall though is definitely that since the car starts with such a low center of gravity, that extra 7/8 of an inch makes it that much more challenging to get into, with these 38 year old knees. but its a price im willing to pay for being really happy with the look of the drop.
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
The Following User Says Thank You to perryair For This Useful Post: | Astroboy (09-12-2015) |
09-12-2015, 09:40 AM | #120 | |
Drives: None
Sent from my LG-D850 using Tapatalk |
09-12-2015, 11:14 AM | #121 | |
junior mafia
i had those same springs on my mustang for 2 years without any negative consequences to stock shocks or anything. supposedly they're designed to work within the constraints of the stock suspension (pro kit not the larger drop in the sport line) but I'm sure other folks on here can weigh in more on that.
05-24-2016, 11:21 PM | #122 |
Drives: GT86 GTS
08-22-2016, 05:36 PM | #123 | |
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Sure, they drop more the Pro springs, but poor ride quality/performance. The springs are 90+% compressed when car is parked, so the springs do very little to help aid in absorption of small/big impacts. Match them with the right strut (something high quality= Koni or Tokico adjustable) , that should help some, but it's also more money out of pocket. At this point, you'd be best suited going with a coil-over if you're wanting about a 1.5" drop, IMHO. I doubt the FRS/BRZ would be any different in their performance. Last edited by Adam_L; 08-22-2016 at 07:01 PM. |
The Following User Says Thank You to Adam_L For This Useful Post: | dattran86 (04-03-2017) |
04-03-2017, 01:37 PM | #124 |
Drives: 2016 FRS-RS
I just put my pro kit on this weekend and noticed two additional plastic bumpstops on the stock setup (this is in addition to the stock rubber one, so three pieces in total stacked). Do I toss these and only use the Eibach bumpstops by themselves? Or just replace the rubber bumpstops and leave the plastic one's there?. My FRS is a 2016.
10-16-2017, 08:11 PM | #125 |
Indulgent Tormenter
Drives: 15' LTD Subaru BRZ DGM
18 x 8.5 245/35/18 will I either sink too much or rub?
Instagram: 86_Maul |
03-23-2018, 06:27 PM | #126 |
Sorry to re-up this thread: EU P/N is different, E10-82-043-01-22. Are the springs different?
Similar Threads | ||||
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! | Racecomp Engineering | Brakes, Suspension, Chassis | 141 | 10-07-2012 08:12 PM |
Eibach Pro Kit Lowering Springs for BRZ/FRS at Redline360 | Redline360 | Brakes, Suspension, Chassis | 15 | 07-21-2012 11:46 PM |
Eibach Sportline Lowering Springs for BRZ/FRS at Redline360 | Redline360 | Brakes, Suspension, Chassis | 4 | 07-06-2012 11:04 AM |
Anyone running Eibach lowering springs? | Bahraini86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 06-01-2012 02:05 PM |
