Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-06-2017, 03:26 AM | #29 |
Drives: 2015 Raven FRS
09-06-2017, 09:33 AM | #30 |
Drives: 2015 Scion FRS - Raven
I have a 5.29 in my manual. If you guys have any questions about it I'll be happy to answer them.
The Following User Says Thank You to TRAKRAVN For This Useful Post: | jcw99 (11-17-2018) |
09-06-2017, 12:00 PM | #33 |
Yes I changed to an 1.5/2.0 way M Factory LSD. Set up as a 1.5way 100% engagement with the steeped ramp.
The Speedometer reads the same as it did before, or at least I didn't notice anything different. 1st gear is still useable it is very short though. It makes hill starts really easy. I think it maxes out around 40kph. As short as it is I don't know anyone who cruises in 1st gear anyway so it's not a fair statement to say the taller gear makes it unusable. There is along noise at cruising from 80-90kph but I believe this is more from the AL driveshaft and the fact that I have solid subframe bushings. There is also noise at low speed turning from the rear diff. It sounds like a racket sometimes. It doesn't bother me because I know what it is. Overall feelings I would do it again for sure. I did the hearing before I did the 60R catback. On the highway now I could do without the exhaust noise. That being said I would change the exhaust and not the gearing. On the track the 5.29 performs close to the same as a supercharged car but without the reliability concerns. |
The Following 3 Users Say Thank You to TRAKRAVN For This Useful Post: |
09-06-2017, 05:35 PM | #34 |
Weight Weenie
Drives: 15 FR-S
The Following 2 Users Say Thank You to new2subaru For This Useful Post: | bfrank1972 (09-06-2017), Somerandom18 (09-07-2017) |
09-07-2017, 09:30 PM | #35 | |
Most older cars a changed final drive would affect the speed displayed, but these cars use the wheel speed sensors not a sensor in the gearbox (before the final drive).
The Following User Says Thank You to wparsons For This Useful Post: | jcw99 (07-29-2018) |
09-08-2017, 01:34 AM | #36 | |
09-08-2017, 12:31 PM | #37 |
Ah I see. May I ask why you went aftermarket? I'm interested in the 4.88 swap but was unsure if it would work best on the stock Torsen or an aftermarket 1.5 way or 2 way LSD. Mine's an auto too. Are there better LSD's out there that are better at transferring power to the wheel?
09-08-2017, 03:35 PM | #38 |
Surething. This is comparing laptimes between cars and top speeds hit on the striaghts at shannonville. The supercharged car with coilovers and Federal tires (my car is stock suspension on 215 RE17R) is about 0.5 second faster per lap and hits about 5kph faster on the straights. When we drag at lunch on the straight for fun the two cars are about even maybe the supercharged car gets about 1/2 a car length depending on the launch. Data is collected with the Aim SoloDL.
Reliability wise I have an upgraded rad and oil cooler. I just change fluids and check them without worrying about heat soak, belt tensioners and whatever else goes along with that. It was also about 1/3-1/2 the price for the gears, LSD and diff cover. |
The Following User Says Thank You to TRAKRAVN For This Useful Post: | new2subaru (09-08-2017) |
09-08-2017, 03:37 PM | #39 |
09-08-2017, 09:29 PM | #41 | |
07-22-2018, 09:57 PM | #42 | |
Drives: Man
Sent from my LG-H872 using Tapatalk |
The Following User Says Thank You to j5o5n For This Useful Post: | TRAKRAVN (07-28-2018) |
Similar Threads | ||||
4.8 final drive | drift86 | Engine, Exhaust, Transmission | 29 | 11-28-2022 12:49 PM |
Needed: drive line shop in Houston for 4.56 final drive install - good experiences? | Joesurf79 | Southwest | 3 | 03-10-2017 12:21 AM |
3.7 Final Drive | GsxrMe | Engine, Exhaust, Transmission | 9 | 09-28-2015 07:55 AM |
FS: BNIB Weir Performance 4.56 SOLD | mrk1 | Engine, Exhaust, Bolt-Ons | 5 | 07-12-2015 02:33 PM |
WEIR Performance 4.56 FD & IS300 LSD Rear Differential | SportInjected | Transmission and Driveline | 3 | 08-09-2014 09:36 AM |
