Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
01-16-2013, 05:05 PM | #29 |
Drives: Many types of cars in R&D.
Yes, the back cover for the lamps have European/Japan/and even USA DOT markings... So I assume they are all built with the same electrical specs, and it should be the vehicle side BCU that is feeding the appropriate pins for the different lamp requirements in each territory for such things like DRL's.
Moto Miwa
www.club4ag.com R&D Driving Engineer, Product Planning Consultant Consulting Member at Cusco, OEM+, RS-R. www.club4ag.com |
The Following User Says Thank You to Moto-P For This Useful Post: | bggns (01-16-2013) |
01-17-2013, 07:25 PM | #30 |
I Void Warranties
Drives: Asphalt 86
Just a quick follow up. Fedex tried delivering these today but I was not home. I am going to pick them up tomorrow and try to get them in Saturday. I will let you guys know how it goes.
The Following User Says Thank You to tbwoodlee For This Useful Post: | FreshFRS (01-17-2013) |
01-17-2013, 09:20 PM | #31 |
Drives: 2013 Scion FR-S 6AT, Asphalt
01-17-2013, 09:41 PM | #32 | |
01-18-2013, 05:55 PM | #33 |
Shift Down
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
nice you dont need levveling but ballasts not included
The Following User Says Thank You to DanoFA20 For This Useful Post: | bggns (01-19-2013) |
01-21-2013, 04:49 PM | #34 |
I Void Warranties
Drives: Asphalt 86
Well turns out I told an unintentional lie. The FedEx package that I assumed was GT86 headlights was actually Eibach Springs. I do apologize.
01-21-2013, 05:50 PM | #35 |
01-21-2013, 06:07 PM | #36 |
Drives: 2013 genesis rspec
this is why im still waiting for these headlights to come to the frs, still holding out for those god damn headlights, I SWEAR TO GOD THAT I WILL NOT BUY FRS WITHOUT JDM HEADLIGHTS.. so yea no frs yet for me
The Following User Says Thank You to just86 For This Useful Post: | tbwoodlee (01-21-2013) |
01-21-2013, 06:29 PM | #37 |
I Void Warranties
Drives: Asphalt 86
I ordered mine around the end of December from nigel-jdmparts and they said it was a 6-10 week turn around. I am not too worried about it, to be honest I am not looking forward to taking off the front bumper. I have some fog lights waiting to be installed, I will knock them out all at once.
01-31-2013, 08:46 PM | #38 | |
Problem with EDM headlights
02-07-2013, 09:56 PM | #39 | |
02-08-2013, 12:34 AM | #40 | |
Drives: 10 series FRS
Check to see if your drl resistor wire is getting power. Also, try flipping your high beam wires. I followed moto-sans diagram and found out his high beam wires were reversed. Thank you moto-p San for your work! |
02-08-2013, 05:19 PM | #41 |
Sorry, I had the High Beam actuator wire color reversed. I corrected it on the original post.
As for the LED bright and low modes. The FRS has a different circuit than the Japanese model for DRL (Japan has no DRL, while Europeans do in the OEM config.) The headlight in either region has DRL built in, where Japan is not hooked up, so if you want to make it work, wire it accordingly to your preference as I wrote originally in the diagram. You can also opt to wire it separately from the system on the FRS so you have direct control of the bright mode LED, rather than only have the use of it during the daytime mode with the headlight off... (which is the only time DRL is active, except when high beams are used... And that's because on the FRS, the high beam bulb is used for the DRL.)
Moto Miwa
The Following User Says Thank You to Moto-P For This Useful Post: | Dadhawk (02-09-2013) |
02-08-2013, 08:20 PM | #42 |
Thanks Moto for your help...changed the wires on the high beams and now they work. The DRL are working but not the way you listed. I hooked up the white wires to the green wire from the resistor and removed the resistor altogether from the car. The way the DRL are working now are low LEDs come on when no lights are on. I turn the parking lights on and the High LEDs come on. I turn the low beams or the high beams on and the DRLs go to LED low. Do you think if I change the low and high LED wires it would correct this? I'd like the DRL LED highs on with no parking or HID lights on and DRL LED lows with parking, low and high beams. Thanks again Moto
Tags |
gt86, gt86 headlights, headlights, lhd |
Similar Threads | ||||
Plug N Play Super Bright LED Kits @ JWM- FREE SHIPPING! | JWMotoring | Interior Parts (Incl. Lighting) | 166 | 03-23-2014 08:08 PM |
ECU Plug and Play | Mo707 | Engine, Exhaust, Transmission | 8 | 08-26-2012 11:21 AM |
Xenon HID Conversion PLUG & PLAY | jarviz | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 08-01-2012 05:34 PM |
HID Plug 'n Play Kit | JW89225 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 24 | 07-31-2012 12:17 AM |
Which hid plug n play kit? | huma | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 07-20-2012 11:10 PM |
