Diode Dynamics
Old 02-13-2016, 09:50 AM   #29
iLaw
iLaw's Avatar
Drives: 2015 BRZ, Aozora Edition
I didn't see it mentioned, but maybe you bought 55W bulbs? OEM spec is 35W.
If you bought 55W bulbs, the ballast isn't sending enough juice to properly power the bulb, so it won't work properly.
I bought Ostram Xenarc 66440 CBI bulbs (which are 35W, but 5000K) and they work great. Never had an issue.
iLaw
2020 Subaru Crosstrek Sport
2015 Subaru BRZ Aozora Edition (Sold)
iLaw is offline   Reply With Quote
Old 02-15-2016, 01:16 PM   #30
taiguy
Drives: 2013 Black BRZ Limited
Originally Posted by frznBRZ View Post
idk i feel like i see better with a "whiter" light as opposed to a "yellower" light. How is it less usuable? just wondering?
and no i only swapped out the bulbs. i did not touch the ballasts.
4300k is closer to actual sunlight. at the same wattage level, lumen output goes down the higher up in color temperature you go. Between 4300k and 6000k it's roughly 300 lumens (not a huge amount). The more important distinction is you get much better color reproduction and clarity at 4300k. Your rods, responsible for night vision, become more sensitive to the higher color temperature so it appears brighter but you lose detail. You generate more glare without increasing visibility.
6000k is not terrible, but not optimal. if you want it for cosmetics that's fine, but functionality suffers. This is why OEM is always in the 4300K range.
taiguy is offline   Reply With Quote
The Following 2 Users Say Thank You to taiguy For This Useful Post:
frznBRZ (02-17-2016), Yoniyama (03-15-2019)
Old 02-15-2016, 01:24 PM   #31
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
I prefer 5000k, it's a nice balance between vision and appearance. It's pretty much pure white usually, but it's also not very common.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 02-15-2016, 08:03 PM   #32
Slade
Slade's Avatar
Drives: 14 Limited BRZ
hey I am having the exact same issue! It's just been really cold and constant snowing here in New York so I haven't had the opportunity to fix this, but my passenger side headlight goes out after a few minutes driving. The drivers side bulb is fine. I too love the look of the 6000k hids and love that they match my fogs. Should I have diode dynamics send me a replacement bulb?
Slade is offline   Reply With Quote
Old 02-15-2016, 09:56 PM   #33
ryoma
ryoma's Avatar
swap sides on the bulbs to make sure it is a bulb problem. then contact diode dynamics
The Following User Says Thank You to ryoma For This Useful Post:
Old 02-15-2016, 10:25 PM   #34
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Seems like more and more of these issues are coming up with their bulbs.
Old 02-17-2016, 02:50 PM   #35
frznBRZ
Drives: 2015 BRZ Ltd
thanks for the explanation
I believe the DD bulbs are 35W. I could have sworn I read that on the bulb when I pulled it out to inspect it.
I would do what the person above said and swap them to see if you're getting the same issue. I would contact DD and inform them of the issue you are having.
Once I went back to my stock bulbs I haven't had an issue. Still waiting on the arrival of my Philips HID Bulbs...
frznBRZ is offline   Reply With Quote
Old 02-17-2016, 04:25 PM   #36
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You're right Diode Dynamics doesn't sell the 55 watt crap.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
frznBRZ (02-22-2016)
Old 02-23-2016, 11:49 AM   #37
Boywonduh
Drives: 2015 Crystal White Pearl Subaru BRZ
Stock vs 6000k diode dynamics hids
Boywonduh is offline   Reply With Quote
Old 02-23-2016, 01:23 PM   #38
tinma
Drives: '13 BRZ
Is it just me or does the oem look a lot better light output? Is this because. Or the higher k?
tinma is offline   Reply With Quote
Old 02-23-2016, 03:35 PM   #39
iLaw
iLaw's Avatar
The OEM would have a higher output because typically the more you veer away (higher or lower) from 4300-4500k output, the less output you have. You sacrifice colour for output.
iLaw
The Following User Says Thank You to iLaw For This Useful Post:
tinma (02-23-2016)
Old 02-23-2016, 04:31 PM   #40
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Go with the retrofit source.
Old 02-23-2016, 04:39 PM   #41
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
OEM isn't that pleasing, imho. I like 5500k tbh.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
The Following User Says Thank You to Rifle For This Useful Post:
frznBRZ (03-30-2016)
Old 02-23-2016, 04:41 PM   #42
FRSBRZGT86FAN
If I ever do a retrofit, or upgrade to denso ballasts sure I will....
Search this Thread:
Advanced Search
Using OEM Mic for Aftermarket Radio AND/OR Replacing OEM Mic with Aftermarket Mic ecko04 Electronics | Audio | NAV | Infotainment 10 05-05-2018 03:47 PM
AT frs rpm issue ricebox Issues | Warranty | Recalls / TSB 18 01-04-2016 01:01 AM
OFT IAM issue Tectoniic Software Tuning 23 10-28-2015 05:52 PM
Need help with FI issue!! Jhood Forced Induction 16 09-07-2015 10:04 PM
Anyone having this issue? zoomzoomers BRZ First-Gen (2012+) -- General Topics 11 08-09-2012 11:19 PM
