Old 02-24-2013, 05:22 PM   #15
wrxgoose
WUB WUB
Drives: 2013 Firestorm
you put the FAQ, but didn't answer any of the questions.
i really need to try and find a Tuning for Dummies book
wrxgoose is offline   Reply With Quote
The Following 3 Users Say Thank You to wrxgoose For This Useful Post:
calis5nest (03-26-2013), Mooseknuckle44 (03-31-2014), spgrizz22 (07-03-2013)
Old 02-25-2013, 09:26 AM   #16
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Originally Posted by DanoFA20 View Post
on ECUtec tunes whats the new rev limit set to? and launch control i saw in some video is set by cruse control switch?
I believe on the ECUTEK tunes, the tuner can set the Redline limit to what you want...from 7500 to 9000. Most people go with 7800 to 8000 RPMs.
tripjammer is offline   Reply With Quote
Old 02-25-2013, 11:27 AM   #17
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
thanks soo much! would 8000 be harmful? or is that still safe id like a tad more rev unless its useless to rev it that high?
DanoFA20 is offline   Reply With Quote
Old 02-25-2013, 01:04 PM   #18
swift996
swift996's Avatar
You begin to lose power at around 7K. It really depends on the application and your goal. I wouldn't recommend it because you're not going to increase performance and are only putting additional stress on the engine system.
EDIT - To expand on application, for instance if you're running a more aggressive timing or cam profile, fuel, or port/bore the engine...obviously that changes the powerband and likely power could be gained above 7k rpms, it just really depends.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-25-2013, 02:26 PM   #19
DanoFA20
Shift Down
DanoFA20's Avatar
sounds good to me
Old 02-25-2013, 04:42 PM   #20
Kris86
Kris86's Avatar
Drives: RHD Gt86
My gt86 does not have cruise control, how would Ibe able to adjust/ operate my launch control?
Kris86 is offline   Reply With Quote
Old 02-25-2013, 10:17 PM   #21
Visconti
Drives: 05 STi
Good Thread!
On EcuTek you can have your tuner make launch control adjustable via the defrost button.
I've already has several guys ask for this.
-John
Visconti is offline   Reply With Quote
The Following 4 Users Say Thank You to Visconti For This Useful Post:
DAMotorsports (03-23-2013), Hook (03-06-2013), Jacques Blom (10-21-2013), Jive Turkey (03-13-2013)
Old 02-26-2013, 03:07 PM   #22
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Correct. DDPR is still playing it a bit safe on the redline as we don't really know where valve float or oil pump fracture may become issues, but with the Ferrea valvetrain I would be willing to risk 8500 for sure - MAYBE 9K.
Mind you at those revs you are looking at heavily accelerated piston and bore wear on thrust surfaces.
Boosted2.0 is offline   Reply With Quote
Old 02-26-2013, 04:29 PM   #23
Kris86
Kris86's Avatar
Drives: RHD Gt86
Good Thread!
-John
Kook thanks
Old 02-27-2013, 04:53 PM   #24
Ingeberger
Ingeberger's Avatar
Drives: 2013 Scion Fr-S
Hi all,
I'm quite confused on the difference between Ecutek tunes and Unichip tunes. Will Ecutek tunes produce more power? Be more reliable? I don't see how Unichip can be so much cheaper if they are providing the same type of service as the Ecutek tunes. Thanks!!
Ingeberger is offline   Reply With Quote
Old 02-27-2013, 05:23 PM   #25
swift996
swift996's Avatar
Originally Posted by Ingeberger View Post
Hi all,
They are two separate approaches to tuning. There isn't a lot of reliable information on the power output of the Unichip solution yet because it's still rolling out to market. The EcuTek solutions have been around and there is a ton of dyno figures out there. I think both have shown great reliability and power increases. A lot of the cost associated with EcuTek is the license and cable to flash a tune. The tune themselves are pretty cheap. Unichip offers some hardware with unlimited tunes that you can reflash via a $35 USB cable.
I will add some dyno info to this thread. However, from a quick search:
Unichip:
http://www.unichip.us/system/uploads...R-S%20Dyno.pdf
http://www.unichip.us/system/uploads...dyno%20bhp.JPG
http://www.unichip.us/system/uploads...rty%20dyno.jpg
EcuTek:
(I will post) but in the meanwhile look for the top few listed, they have a ton of dynos on here.
The Following User Says Thank You to swift996 For This Useful Post:
racer_tom (03-30-2014)
Old 02-27-2013, 05:34 PM   #26
Ingeberger
Ingeberger's Avatar
Thanks man! I will stay posted to see what info comes out in the near future. I found that dyno chart too and didn't really know what to think of it... Is it stating that you'll get those increases with the injen intake? Are those increases from just a tune? I guess we'll just have to see how this system performs. I'm very excited to see what's in store though .
Old 03-01-2013, 09:14 PM   #27
Pandle
Drives: CBS BRZ
Good Thread!
-John
How does launch control work with an automatic?
Pandle is offline   Reply With Quote
Old 03-01-2013, 09:44 PM   #28
Visconti
Drives: 05 STi
Last time I checked it doesn't !
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Ford Racing Suspension tuning guide? mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 01-22-2013 01:00 PM
fact or fiction on this performance and tuning guide? davey90 AUSTRALIA 10 07-19-2012 07:45 PM
FR-S quick reference and warranty / maintenance guide is up pkny Scion FR-S / Toyota 86 GT86 General Forum 15 06-20-2012 11:33 PM
86/FRS/BRZ Tuning Guide ESBjiujitsu Engine, Exhaust, Transmission 18 05-30-2012 06:42 PM
