Old 11-08-2023, 03:02 AM   #491
TurboLag23
TurboLag23's Avatar
Drives: 2018 BRZ w/Performance Package
Originally Posted by timurrrr View Post
That's a strange combination of facts and conclusions.
Given that you use PS4Ss, I presume you mostly do autox for fun, not competitively?
Back when I had a gen1 with CSG FLAs and finally switched to 200tw tires for autox, I quickly found the suspension to be too soft. The body had a lot more rolling, squatting and diving than the top cars.
My results improved once I switched to a stiffer setup.
FLAs can definitely handle casual autox, but I wouldn't call them "well-sprung" or "phenomenal" for autox in general.
Yes, I do autocross mostly for fun - although I am considering attempting to get to SCCA Nationals for the 2024-2025 season.
If stiffness was really an issue for you, that probably just means that the spring rates (which dictate total articulation under "static" loading scenarios such as front-end dive under heavy braking, outside-front compression mid-corner, etc.) were too soft for your preference. Personally, I've found them to be totally fine... but that's the fun thing about preference - there is no right answer!
If I get to the point where my preferences change to more closely match yours - either because of 200TW tires or because of a change in my driving - I'll just upgrade to a stiffer set of springs. Or if I'm satisfied with dive/squat properties and I just want roll reduction, I'll upgrade the stock sway bars to aftermarket bars that maintain the current front:rear stiffness ratio while being stiffer overall (probably the Perrin ones). Or if I just want to control front-end dive I'll get the Jackson Racing Anti-Dive Kit. Or if I want to control rear-end squat I'll get the MCA Traction Mod.
Regardless - my plan has been (and will continue to be) to make "unprompted" changes (ex: going from stock suspension to coilovers, going from PS4S to 200TW tires, etc.) one at a time, then adjust the car to my liking based on that one change. Although my wallet would definitely prefer I just leave it the hell alone at this point
TurboLag23 is offline   Reply With Quote
Old 11-08-2023, 10:00 PM   #492
strat61caster
strat61caster's Avatar
If you intend on being in stx when you head to Nats those geometry changes aren’t legal.
ineedyourdiddly
timurrrr (11-09-2023)
WTB Tein Flex Z HachiRo Want-To-Buy Requests 1 09-19-2016 01:13 PM
tein flex z mclovin85 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-14-2016 06:27 PM
TEIN Super Racing (SRC) - CSG Spec - GROUP BUY THREAD - 4/22 Last Day CounterSpace Garage Groupbuys 47 02-18-2016 12:33 AM
Help wanted: Tein Street Flex for $950 or Flex Z or $820? chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-01-2015 09:33 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
