Old 03-07-2024, 09:31 PM   #1
HotlavaFRSGT86
Keep ICE alive+manuals
HotlavaFRSGT86's Avatar
Drives: 2015 Hot Lava 6 spd
Who else?
Who else does and enjoys(most of the time anyway) doing all the work on their own vehicles besides me? Both Custom work and maintenance of course. I also think that the 86/BRZ platform is quite easy to work on, kind of reminds me of working on 60s/70s American Muscle.
If your not first your last - Ricky Bobby
HotlavaFRSGT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to HotlavaFRSGT86 For This Useful Post:
humfrz (03-22-2024), Wally86 (03-13-2024)
Old 03-08-2024, 01:16 AM   #2
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
Most routine maintenance jobs, no problem, I enjoy them and the twins were indeed great to work on. Some repairs though as an amateur mechanic without all the necessary tools can be infuriating...our 2011 Prius has a problem with the hvac blend door, service manual says to basically take apart the whole dash and here I am trying to avoid that by using all sorts of small offset screwdrivers and probably looking pretty silly squeezing underneath everything needless to say it has been a real pita
HKz is offline   Reply With Quote
Old 03-09-2024, 08:22 PM   #3
HotlavaFRSGT86
I feel your pain there man, usually anything behind the dash is a real mother, and what your doing with the blend doors can be quite a difficult job. Now on your Prius are they still vacuum powered or the ones with little electric actuators?
Old 03-11-2024, 09:00 AM   #4
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
I do most of own work as well. (expensive) tool dependent, but I'll tackle most anything on the difficulty scale up to a 7.
The Following 2 Users Say Thank You to WolfpackS2k For This Useful Post:
HKz (03-11-2024), HotlavaFRSGT86 (03-12-2024)
Old 03-11-2024, 01:52 PM   #5
HKz
Reformed
HKz's Avatar
Well luckily, the actual flap is all good so it was just the electric powered servo that moves the flap. Finally got that sucker out the other day..now the next challenge is my local pick a part just got a 3rd gen Prius in their yard and I went over there thinking the dash would already be pulled off and allow easy access for me to grab its servo but annoyingly the dash was only really disassembled on the driver's side so I called it a day and I'll be back later this week to try and extract it at least problem is temporarily fixed for my wife since I am able to physically turn the flap so that the AC properly blows only cold air while the engine runs.
The Following User Says Thank You to HKz For This Useful Post:
Old 03-12-2024, 05:47 PM   #6
HotlavaFRSGT86
Yea it looks like a real PITA my man. HAHA
The Following User Says Thank You to HotlavaFRSGT86 For This Useful Post:
HKz (03-13-2024)
Old 03-13-2024, 08:13 AM   #7
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
It's a nice, fun, and easy to work on car so far.
It helps to have a bike to screw around with and build that mechanic confidence muscle with.
A driveway lift helps too.
(having some tools helps too, I suppose)
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Wally86 For This Useful Post:
HKz (03-13-2024), HotlavaFRSGT86 (03-30-2024), NoHaveMSG (03-22-2024)
Old 03-21-2024, 12:15 AM   #8
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Depends on the condition of the car.
I did coilovers, rear control arms, and camber bolts on my BRZ that's stored over winter and doesn't have an ounce of rust on it. Every bolt came out with zero issues. Everything went right together with no issues.
Doing just brakes on my SO's Sentra is a chore. Rust, seized slide pins, ordering parts you didn't think you'd need. Using heat, drilling out snapped bolts, etc. Everything is seized and caked on.
Generally though, doing any type of maintenance, fluid changes, replacement parts, feels like you're giving the vehicle new life. Super satisfying.
cmiovino is offline   Reply With Quote
The Following 2 Users Say Thank You to cmiovino For This Useful Post:
blsfrs (03-23-2024), Wally86 (03-22-2024)
Old 03-22-2024, 06:19 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
You guys work on your own cars ?!?
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
HotlavaFRSGT86 (03-30-2024), humfrz (03-22-2024)
Old 03-22-2024, 09:06 PM   #10
Hells bells, back in the day, I used to do ALL of my own work on my automobiles.
All that was needed was a spark plug wrench, a screwdriver, a 9/16-1\2" wrench, a thin dime (to set the points), a fingernail file (to file the points), a good ear (to set the timing), a pair of pliers and a socket set if you were going to overhaul the engine.
However, today, I feel lucky to find the dipstick to check the oil -
Old 03-23-2024, 01:52 PM   #11
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
That thar is a Chevy 235 cu in straight six. 1955-1957'ish.
The Following User Says Thank You to blsfrs For This Useful Post:
humfrz (03-23-2024)
Old 03-23-2024, 02:56 PM   #12
Good eye, there, old man. I couldn't find a picture of a 216 -
Old 03-23-2024, 03:05 PM   #13
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I am weederr33 by name. My car easy to work on.
MS, CSCS, TSAC-F, CPT
The Following 3 Users Say Thank You to weederr33 For This Useful Post:
humfrz (03-23-2024), NoHaveMSG (03-24-2024), Wally86 (03-25-2024)
Old 03-23-2024, 05:07 PM   #14
weederr33 (03-23-2024)
