02-19-2022, 08:58 AM | #799 |
Pissin off regressives
Drives: They have engines.
I can't get the car into reverse with the CAE shifter. Heard from KPower that someone modified their shifter by lowering it, but haven't been able to find that post.
Back in the day I had the TRD quickshift that worked by lowering the shift angle. Wondering if that could work. Any thoughts? http://www.billswebspace.com/PTR54-18130inst.pdf |
02-19-2022, 11:16 AM | #800 | |
Drives: 2017 Hot Lava 86
02-19-2022, 11:44 AM | #801 | |
Drives: Q5 + BRZ + M796
02-19-2022, 11:45 AM | #802 |
Again, I wanted to ask because no one has responded to a previous post: does anyone notice the car has a heavier feel to the steering, or is it just me?
02-19-2022, 12:00 PM | #803 |
Wears Pants
Drives: 14 FRS K24 swap - SOLD
Feels the same to me but I can’t really compare it easily to my previous FRS which had a completely different suspension setup and stickier tires.
The Following User Says Thank You to captain awesome For This Useful Post: | Irace86.2.0 (02-19-2022) |
02-19-2022, 01:05 PM | #804 |
Wears Pants
New shorter 2 piece driveshaft has been installed and it’s like a different car. Throughout the rev range under power it’s so much smoother. The 3500-4k vibes through the tunnel is gone. There’s still a rattle through the shifter in that range but I think that’s my shift knob extension plus the reverse lockout plastic making sweet love. I’ve shortened my shifter console and will probably test fit when the STI trans mount shows up then have a local guy weld it up. I figure if it’s no better then I’ll switch back but should only set me back a few bucks to try it out.
The Following 2 Users Say Thank You to captain awesome For This Useful Post: | Irace86.2.0 (02-19-2022), RedReplicant (02-19-2022) |
02-19-2022, 02:22 PM | #805 | |
Drives: None
02-19-2022, 03:04 PM | #806 |
Wears Pants
$325 after tax. He had to install a brand new yoke and ujoint assembly so that added costs but it had to be done regardless to fit the larger opening once cut. The front joints weren’t in great shape anyway. Also I added spacers and longer bolts for the carrier bearing. Around 5/8” I think. Just some spacers I had lying around from an old project. I’ll post up some pics later.
After more driving it’s just so much better than before. The rear view mirror isn’t a blur. Pretty sure I can quiet the shifter rattle enough to see whether I’ll bother getting the cut up stock shifter welded. I still have vibes at idle but it would be more tolerable once I get rid of some rattles under the dash. Would be nice if the Fluidampr helped in that department. |
02-19-2022, 05:27 PM | #807 |
Vibrations in my car are pretty minimal now. I haven’t changed anything other than making sure the trans tunnel has plenty of clearance. I’m using an IRP shifter that has a bit of rattle like normal, but no real vibrations. I’m also not using a dampened crank pulley. It’s aluminum and only weighs .8 pounds rather than 4.1 like stock, so my vibrations should be worse than most. Here is a quick video to show the 3-4K range and some acceleration. Not the best video due to the sun, so sorry about that.
The Following 3 Users Say Thank You to Ebush For This Useful Post: |
02-19-2022, 06:12 PM | #808 |
Wears Pants
Couple pics of the DS.
The Following 3 Users Say Thank You to captain awesome For This Useful Post: |
02-19-2022, 07:55 PM | #809 |
I’ve about to pull the trigger on a Fluidampr damper. The stock unit is solid steel or mildly dampened, so in light of losing the secondary balancing shafts, this seems like good insurance.
I was also wondering if there is an overrunning alternator pulley suited to the K24, so I’ve been looking. I haven’t found anything obvious. The video below shows the benefits in the first few minutes.
The Following User Says Thank You to Irace86.2.0 For This Useful Post: | captain awesome (02-19-2022) |
02-19-2022, 07:57 PM | #810 |
Wears Pants
Here's the work in progress on the shifter console. I hose clamped them together so I can test fit and if needed can move stuff around to align properly. With the Kpower kit the trans is lowered 1.25" over stock from my measurements, so I cut then stacked the console which just so happens to be about an 1". I "think" this should be ready to weld but better to test fit first before committing. 5.5" roughly shorter than stock. If the Kpower shift linkage doesn't fit I'll shorten the stock chunky one as needed.
02-19-2022, 08:04 PM | #811 | |
Wears Pants
Haven't looked into the alternator thing but interested in what you think of the Fluidampr. It's on my short list but may throw that money at starting a remote tune. Last edited by captain awesome; 02-19-2022 at 08:26 PM. |
02-19-2022, 08:26 PM | #812 |
I don’t notice any extra vibrations in my car from when it had an fa20. I just have the normal IRP shifter buzz/rattle. I have an aluminum drive shaft, aluminum flywheel, 3 puck exedy clutch, non dampened aluminum crank pulley, white line trans bushing thing, and an IRP shifter.
I did have a lot of vibrations the first time I installed the engine. Drove the car like that for 1000 miles, recently pulled the motor to swap head gaskets and increase the clearance around the trans. Now that I’ve made more clearance for the trans I don’t have any vibrations. A piece of the trans sticks inside the trans mount that we needed to hammer. And I believe that’s what was causing vibrations. When installing the engine/trans this time I left all the engine and trans mounts loose. I put a crowbar between the trans and the trans mount that we beat in. Then I tightened the trans mount and moved up to the engine mounts. |
Similar Threads | ||||
Rigid Industries SR-Series Pro Light Bar on my BRZ | Stang70Fastback | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 12-29-2019 03:13 PM |
Airlift from industries finest | J_Nasty | Member's Car Journals | 0 | 02-04-2017 01:59 PM |
Carbox Industries - Introduction | CarBox | CANADIAN Sales | 5 | 04-22-2014 01:22 PM |
86 industries | Duthebarber | Northern California | 70 | 03-28-2014 04:10 PM |
Another 86 Industries another bad experience | sikest | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-13-2014 01:00 AM |
