Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
01-11-2013, 11:07 AM | #1 |
Rugger Extraordinaire
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
Square Setup w/ Rear Spacers
Before I say anything else: I understand spacers are not ideal. That being said, I was wondering how bad this would be if I were to do it. According to the wheel fitment chart, at lowered 1", there is a 10mm discrepancy between the offset for the front and rear to be flush. I don't want to run a staggered setup because I wouldn't be able to rotate tires, I would like the spokes to have the same angle on the front and rear, and buying a square setup is usually cheaper. I plan on using this only for the street and removing the spacers for the track, as well as probably getting some dedicated track wheels. Is this a good compromise? What are the downsides? Can anyone recommend good spacers?
01-11-2013, 02:09 PM | #2 |
Drives: 2006 STi
maybe try with 20mm ichiba V2s
01-11-2013, 02:24 PM | #3 |
01-11-2013, 03:03 PM | #4 |
Drives: 2006 STi
10mm or 15mm "studded spacers" might be too thin of a spacer where the existing studs may hit the "mounting pad" of the wheel
10mm or 15mm "slip on spacers" might be too thick of a spacer not leaving enough threads to safely mount wheels and lugs if you definitely want 10mm spacer you can: mount 10mm studded spacer and grind down existing studs OR mount 10mm slip on spacer and replace stock studs with extended studs. 20mm may be the easiest route
01-11-2013, 03:53 PM | #5 | |
01-11-2013, 04:33 PM | #6 |
Yup
01-11-2013, 04:53 PM | #7 |
Tells it like it is
Drives: SS1LE | F150 Diesel | Civic | S3
I don't see an issue with running spacers as long as it isn't on the track.
Find something hub-centric and go from there
-Seven || youtube.com/turnsevenvideo
2012 C6 Grand Sport 4LT 2015 Mazda 3i-T/Tech |
Similar Threads | ||||
Rays 57 Xtreme - 18x9.5 +40 - Square setup | No Limit Motorsport | Wheels and Tires | 16 | 01-21-2013 02:59 PM |
(Back up!) FS in FL: Drag DR-31 17x9" Square setup 5x100 (or 5x114.3) +38 | Kido1986 | Wheels and Tires | 5 | 01-10-2013 03:21 PM |
FS in FL: Drag DR-31 17x9" Square setup 5x100 (or 5x114.3) +38 | GTB/ZR-1 | Wheels and Tires | 1 | 12-06-2012 07:22 AM |
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
Widest rear tire for a staggered setup? | Jeff Lange | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 05-22-2012 08:52 PM |
