Old 03-13-2019, 05:07 PM   #15
wparsons
wparsons's Avatar
Originally Posted by Pat View Post
I am not feeling the gears. This is something completely different. I know what you're referring to, as I heard that when I changed the bushings too. The buzzing that I am referring to is completely different.
Does it happen if you get up to speed and push the clutch in? How about just revving the engine in the bad RPM range while stopped?
It almost sounds like the flywheel is out of balance and causing a vibration and harmonic resonance.
flickr
Pat (03-13-2019)
Old 03-13-2019, 05:52 PM   #16
Pat
Pat's Avatar
Drives: 2023 BRZ
When driving at nearly any speed I can depress the clutch pedal to make the sound go away immediately.
When just revving the engine in neutral while stationary I can't say for sure. I just tried it in the garage, but it sounds not as bad today as it normally does. I'm pretty sure it still vibrates, but can't say for sure. We have terrible weather here today, so I can't really take it out to check easily right now.
Old 03-13-2019, 07:23 PM   #17
Pat
Pat's Avatar
Drives: 2023 BRZ
I just spoke with fika84. It sounds like the problem is not the flywheel given my previous post. What else could it be?
Old 03-13-2019, 09:18 PM   #18
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
It's the complete clutch kit. I had the same one, and it shook the whole car every time I lugged the engine. All I added was the whiteline transmission bushing:
https://www.ft86club.com/forums/show...9&postcount=18
Honestly, It wasn't a big deal to me. I just avoided lugging the engine.
I eventually removed the kit because of clutch drag:
https://www.ft86club.com/forums/showthread.php?t=128871
EndlessAzure is offline   Reply With Quote
Old 03-13-2019, 11:05 PM   #19
Pat
Pat's Avatar
Drives: 2023 BRZ
Your situation is not the same as what I'm dealing with.
Old 03-13-2019, 11:12 PM   #20
FRS Justin
Drives: 2013 Asphalt FRS
upload a video so we can hear it.... because what your describing is a normal issue with that clutch setup...
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
wparsons (03-14-2019)
Old 03-14-2019, 04:38 PM   #21
Pat
Pat's Avatar
Drives: 2023 BRZ
If the clutch is not engaged it sound normal. Only when the clutch is engaged does the the car vibrate. Revving the engine while stopped doesn't cause the vibration, whether the car is in neutral, or there is a gear selected and the clutch pedal is on the floor.
Old 03-14-2019, 04:57 PM   #22
CSG Mike
CSG Mike's Avatar
@Pat under what circumstances are you getting increased NVH? Decel in gear only?
Was your clutch installed using the provided plastic tool (which sucks), or a metal tool (way more rigid)? Everything torqued down slowly in a star pattern or just full depth torque in a star pattern?
It sounds to me like it may slightly be out of alignment.
Old 03-14-2019, 05:08 PM   #23
Pat
Pat's Avatar
Drives: 2023 BRZ
Thanks, Mike. I remember reading about the plastic tool vs. the metal tool. I spoke with Mark Baer about this at SCR Performance. He said they use the plastic tool that comes with it, as that is what gets it on there. But what really centers it, he said, is tightening everything down.
I get the noise at nearly any speed as long as the clutch is engaged. It is noisiest when decelerating between 2k and 4k RPMs. But I get is accelerating, too. When the revs are high it's almost unnoticeable. I believe there is a harmonic factor involved.
I have to imagine it was torqued bit by bit in a star pattern as the shop, SCR, is pretty well respected. But who knows, everyone makes mistakes.
Thanks again.
Old 03-14-2019, 05:19 PM   #24
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Strife26 View Post
Are you talking about chatter?
I have the oem flywheel in my car but I do get chatter at all rpm on occasion. There seems to be a 1:1 correlation between the noise and the good wife being in the car.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
Strife26 (03-15-2019), wparsons (03-15-2019)
Old 03-15-2019, 09:21 AM   #25
wparsons
wparsons's Avatar
If it's not happening in neutral, even with the clutch fully engaged, I'd lean towards something behind the gearbox. I've heard of balance issues on the driveshaft if not installed in the same orientation as it was removed, could possibly be that. If it was the driveshaft, I'd think you would get some vibration even in neutral while rolling though, and it would be more dependent on vehicle speed than engine speed.
flickr
Pat (03-15-2019)
Old 03-15-2019, 09:30 AM   #26
Grady
Grady's Avatar
Thanks again.
If you paid someone to do it and it started right after I would be working with them for the solution. Take them for a drive, if they have don a lot of these they should know if it is normal. If it is not they will just have to go over everything they had apart to verify it is correct and or defective part(if you purchased the part from them).
Grady is online now   Reply With Quote
The Following 3 Users Say Thank You to Grady For This Useful Post:
Pat (03-15-2019), Turbo (03-28-2019), wparsons (03-18-2019)
Old 03-15-2019, 03:40 PM   #27
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by Grady View Post
If you paid someone to do it I and it started right after I would be working with them for the solution. Take them for a drive, if they have don a lot of these they should know if it is normal. If it is not they will just have to go over everything they had apart to verify it is correct and or defective part(if you purchased the part from them).
Thanks. You're right. Sometimes I get too deep into e-diagnosis. The bottom line is if they recommended it, I bought it from them, and they did the work, they should troubleshoot. Cheers.
The Following 3 Users Say Thank You to Pat For This Useful Post:
Strife26 (03-15-2019), Turbo (03-28-2019), wparsons (03-18-2019)
Old 03-22-2019, 12:24 PM   #28
Pat
Pat's Avatar
Drives: 2023 BRZ
I just heard from the shop. They verified everything in the drivetrain looks fine, with the exception of the tranny. IIRC they stuck a scope in there while driving and saw movement around the TOB. We used a current OEM TOB. We scheduled more time next week to take it apart and figure it out.
To be continued...
Does the ACT Streetlight kit need a Verus clutch fork? Pat Engine, Exhaust, Transmission 21 02-09-2019 12:31 PM
Buzzing/vibrating gear stick paulca Issues | Warranty | Recalls / TSB 49 10-12-2017 11:47 AM
WTB ACT Streetlight Flywheel or Similar Cross Want-To-Buy Requests 0 03-31-2015 06:34 PM
Ordered my ACT streetlight clutch kit! Anyone have this? NickFRS Engine, Exhaust, Transmission 17 06-17-2013 06:05 PM
Buzzing/vibrating speaker fix CBR600RR DIY (Do-It-Yourself) Guides 3 05-21-2013 12:11 PM
