DIY (Do-It-Yourself) Guides For all DIYs. |
08-19-2019, 10:44 AM | #15 | |
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
I didn't remove the parking brake shoe when I did mine.
08-19-2019, 01:17 PM | #16 |
義理チョコ
I don't think you have to for the front. There's plenty of clearance.
08-19-2019, 06:21 PM | #17 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
If you reread in the rear you have to rotate the hub around to one area where there is clearance to get the stud in/out. But you don't have to remove anything extra at least for stock length studs.
08-19-2019, 08:11 PM | #18 |
Thanks for clarifying that, finch
The Following User Says Thank You to GrantedTaken For This Useful Post: | finch1750 (08-20-2019) |
08-20-2019, 02:28 PM | #19 |
Yeah, I took off one hub each front and rear, then noticed I didn't have to do the other one. Learn from my mistake.
08-20-2019, 04:42 PM | #20 |
Drives: FRS
I confirm that the parking brake doesn't need to be removed with stock studs. Just remove the brake rotor. You also don't need a press, just screw a wheel on (before putting brake rotor back) to pull the stud in.
08-20-2019, 05:52 PM | #21 |
Use washers. Not a wheel
The Following User Says Thank You to finch1750 For This Useful Post: | Clutch Dog (08-20-2019) |
08-20-2019, 06:25 PM | #22 |
Drives: 2017 BRZ PP , 2005 Saab 97X
I used a stack of washers. and a sacrificial nut. and then hit it with a dugga ugga.
it is very shade tree. but i had a split front lug out and new one in within 20 min. the goal is to tighten down the nut on the washers and then have the nut draw the lug through while it is rotating on the washers. i typically like to run a few fat ones with a huge hole and then one that barely clears the new wheel stud this allows the washer to deform a little when the stud is tight without stripping threads or stretching the stud (hence sacrificial lug nut) |
08-20-2019, 07:22 PM | #23 |
Drives: FRS
08-20-2019, 07:56 PM | #24 |
Wheels for Brains
I 2nd this. I also did this. The tool can be used both to pop the stud out and to press the new stud on nicely too. I only have experience doing the front, though.
The Following User Says Thank You to EndlessAzure For This Useful Post: | YamahaR86 (08-21-2019) |
10-07-2020, 11:56 AM | #25 |
Drives: 2017 86
Thanks for this, I installed my Konis & Eibach suspension and noticed I hated the OEM lugs. Ordered new ones and broke a stud trying to get the OEM lug off. Going to the dealer to get a stud, then doing this.
The videos I found had me taking the whole assembly apart, glad to see I won't have to. |
Similar Threads | ||||
Wheel stud replacement | Dave-ROR | DIY (Do-It-Yourself) Guides | 267 | 01-21-2022 08:20 PM |
South Bay Wheel Stud Replacement? | HachiRo | Northern California | 4 | 02-04-2016 04:56 PM |
Replacement Windshield w/ blue shade band? | hmong337 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 08-27-2015 06:00 PM |
anyone know if there's a rear window shade? | nycfl123 | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 03-07-2014 02:39 AM |
Replacement Lug Stud/Wheel Hub | swift996 | Issues | Warranty | Recalls / TSB | 3 | 08-30-2013 01:58 PM |
