Old 12-09-2019, 07:25 AM   #15
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
did you rescale port injector MRP compensation table for boost?
in my case, that helped a little bit.
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
The Following User Says Thank You to Yobiwan For This Useful Post:
solidsnake11 (12-13-2019)
Old 12-09-2019, 07:54 AM   #16
tomm.brz
Drives: brz 2017 hksv2
He did, but he won t go lower than 4 of engine load with just that
He would need to make the maf scaling in open loop about 20% lower at least and force more fuel putting a lot lower "cc" value in the port scaling table and go from it
The Following User Says Thank You to tomm.brz For This Useful Post:
solidsnake11 (12-09-2019)
Old 12-09-2019, 11:39 AM   #17
tomm.brz
DI scaling is a lot more complicate since it s a 3D map and it uses variable fuel pressure, I guess it could help to put out more fuel than intended while keeping less load but cannot help with that
Old 12-10-2019, 04:41 PM   #18
tomm.brz
I assure you that cable feels even cheaper than 24$
And let s not talk about the shitty delicate USB dingle that breaks just by looking, and if it happens you get an heart attack
But you will like it anyway
solidsnake11 (12-10-2019)
Search this Thread:
Advanced Search
Car Running Lean MyGT86Yas Software Tuning 9 09-24-2019 07:46 PM
16 or 32 bit ECU? Should I lean the air if.... chazmuska Software Tuning 2 07-12-2017 06:48 PM
Running lean ? Maybe ? lizbrayan Engine, Exhaust, Transmission 35 06-19-2016 12:16 AM
lean at idle only woode Forced Induction 5 05-03-2014 04:48 PM
running lean EZWood Engine, Exhaust, Transmission 26 10-18-2013 12:53 PM
