12-18-2019, 11:59 AM | #1 |
Drives: 2013 Firestorm Red FRS
2014 Heads On A 2013
As the title states, has anyone tried to use newer heads on an older block? I have a 2013 that was affected by the recall and apparently the springs aren't the only thing that's garbage about the valvetrain. I don't want to risk a dropped valve or breaking a rocker arm, both of which should be solved with a 2014/2015 head. So are they backwards compatible?
The Following User Says Thank You to Alpha86 For This Useful Post: | solidsnake11 (12-18-2019) |
12-18-2019, 12:13 PM | #2 | |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | solidsnake11 (12-18-2019) |
12-18-2019, 03:39 PM | #3 |
The 14 and 15 will be completely compatible with the 13.
The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Alpha86 (12-18-2019), solidsnake11 (12-18-2019) |
12-18-2019, 07:09 PM | #4 |
Drives: 2013 Rally Blue w/Bronze wheels MT
Not to hijack your thread, throw stones, or flame you but shouldn’t this be in the engine sub rather than engine swap?
Vyse | How fast can you afford to go | Etc...
12-19-2019, 05:21 AM | #5 |
Drives: 2015 frs
So when my swap is done I suppose since its supercharged I will post it up in the forced induction section. After all its supercharged.
12-19-2019, 08:28 AM | #6 |
Drives: Crapcan
The Following User Says Thank You to NoHaveMSG For This Useful Post: | solidsnake11 (12-19-2019) |
12-19-2019, 08:44 AM | #7 |
Drives: 2015 frs
I wish it would look good enough for a show. Highly unlikely though. This shit is built for charmin it's all about the go. Lol
12-19-2019, 09:30 AM | #8 |
Drives: Crapcan
12-19-2019, 09:47 AM | #9 |
Drives: 2015 frs
Thanks. I work to much, so it's going to be a while. I just enjoy working on machines. I started the build to kill time, but it also has murdered my bank acount. Anyway hope this guy gets his heads straight.
12-19-2019, 10:18 AM | #11 |
Was considering, I figured it fit here because its replacing half of an engine with non-stock parts. If any mod wants to move it, that's totally fair.
01-10-2020, 12:26 PM | #12 |
I can vouch for this as I have 2014 heads on my 2013. It was straight forward and everything is running just fine!
If you're buying your 2014 heads used, you may want to invest in new cam gears depending on the condition.. If the 2014 engine had metal shavings in it I wouldn't reuse the cam gears. You could try and clean them but it's not very simple! |
The Following User Says Thank You to fika84 For This Useful Post: | Alpha86 (01-10-2020) |
01-10-2020, 12:43 PM | #13 |
Drives: brz 2017 hksv2
the heads are the same
in 2014 they changed the rocker arms and the cams, but the heads are the same from August 2016 (my2017) they changed the Cam Intake RH (the one that has the lobe for the fuel pump, and all the 16 valves, making them longer |
01-11-2020, 02:51 AM | #14 |
ops, yes you are right 2014+ the made valves longer
MY17+ they changed again the code of the valves because they made them buffed for less friction |
Similar Threads | ||||
TRD Carbon Fiber Fender Fins Scion FR-S 2013-2014 / Subaru BRZ 2013-2014 | RallySport Direct | Exterior Parts - Lighting | 73 | 07-31-2015 11:39 AM |
Cosworth Stage 1.1-1.3 Power Package BRZ 2013-2014 / FR-S 2013-2014 With Videos! | RallySport Direct | Engine, Exhaust, Bolt-Ons | 104 | 07-02-2015 10:10 AM |
APR Front Bumper Canards Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 | RallySport Direct | Exterior Parts - The Rest | 0 | 01-14-2014 11:17 AM |
GTSpec Rear Subframe Reinforcement Panels Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 | RallySport Direct | Brakes, Suspension, Chassis | 0 | 01-08-2014 12:32 PM |
Injector Dynamics Fuel Injectors 1300cc Subaru BRZ 2013-2014 / Scion FR-S 2013-2014 | RallySport Direct | Engine, Exhaust, Bolt-Ons | 0 | 01-07-2014 12:13 PM |
