Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
09-05-2017, 07:32 AM | #29 |
Drives: Raven FR-S 6MT
Front & rear jacking points then harbor freight jack stands on the pinch welds. No issues for 2 years now
09-05-2017, 02:02 PM | #30 | |
Drives: 2005 Toyota Camry
I just use these if jacking up one side at a time:
https://www.walmart.com/ip/Areyoursh...Weld/165705821 Quote:
https://www.harborfreight.com/rubber...-pc-63373.html |
09-05-2017, 02:21 PM | #31 |
Persona Non Grata
Drives: '15 BRZ (WRB)
When I bought "Blue" I also ordered four Esco Jack stands. They come with flat rubber platforms that cushion the pinch welds. They also make for a REALLY stable platform when working under the car.
https://www.amazon.com/ESCO-10498-Ja...co+jack+stands
Slow is smooth, and smooth is fast
09-05-2017, 09:41 PM | #32 | |
Drives: '13 BRZ
09-05-2017, 10:19 PM | #33 |
09-05-2017, 10:51 PM | #34 |
The Dictater
Drives: '13 Red Scion FRS
So, I've considered making something like that, and I determined that I would be more worried about the car tipping forward on the pucks. That's a lot of vertical lever arm for a short lateral distance to tip. Though maybe the picture angle is deceptive.
09-05-2017, 11:09 PM | #35 |
義理チョコ
I get you but once the weight of the car is on it, believe me. It's solid as a rock on a rubber mat. Squishes way out.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Spuds (09-06-2017) |
09-06-2017, 06:46 AM | #36 |
Drives: '13 BRZ
09-06-2017, 10:07 AM | #37 |
You do understand that the rubber pads are flexible enough that they give at the weld and disperse the weight across the whole surface right?
09-06-2017, 10:57 AM | #38 | |
I used it for 3+ years on my car, wrenching on it almost every weekend because I was running the car "safely" at the track without "abusing" it at 3000-6000RPMs and the pads totally fucked up my pinch welds. Here's a fact for you: I used it for 3 years and it never bent the pinch welds. About the only thing it did was start stripping the paint due to excessive use. -alex |
09-06-2017, 10:58 AM | #39 |
I've been using Esco jackstands and they work great. No damage to the pinch welds. If you're really worried, you can even slot a hockey puck and place them on top (although I haven't found a need to).
2022 BRZ Build 2013 FR-S Build |
09-06-2017, 11:28 AM | #40 |
The Dictater
09-06-2017, 12:41 PM | #41 | |
義理チョコ
The main issue with bending the pinch weld comes from lifting at that single point with a device that pulls out away at an angle as the chassis is lifted. I wouldn't think twice about in gently resting both sides onto those stands. Thanks, @Capt Spaulding and @DarkSunrise, for suggesting those.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | DarkSunrise (09-06-2017), Tcoat (09-06-2017) |
09-06-2017, 06:42 PM | #42 | |
Drives: '13 BRZ
You might as well just use flat jackstands. Same thing. |
Similar Threads | ||||
FS: BINB Stoptech Slotted Front Rotors(Pair) and 2 full sets of Brake Pads | jflogerzi | Brakes, Suspension, Chassis | 12 | 10-24-2015 03:26 PM |
Pinch weld jack point paint damage? | Ingen | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 37 | 10-12-2015 08:43 AM |
Jack Stands + Pinch Weld | Wyattkb | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 10-12-2015 03:45 AM |
Stoptech Slotted Rotors w/ BMB Pads | 14BRZ | Brakes, Suspension, Chassis | 0 | 06-04-2015 01:16 AM |
