07-12-2019, 01:16 AM | #253 |
Drives: 2019 Autox BRZ & 2021 GTI (Daily)
First autocross event — any pointers appreciated! Video posted was the last and best run of the day. Had a better time each run out except for the fourth where I forgot to turn off traction control and it bogged off the start. Event was at Road America’s go-kart track.
Had a blast!! Hoping to do a couple more this season and go bigger for next year when I do some suspension mods over winter. Mods: K&N Drop-in | Perrin Intake Tube | Invidia Catless/Resonated Front Pipe | Corsa Catback | 17x9 Rays 57CR | RE-71R 245/40 | Stock Suspension (for now) [ame]https://www.youtube.com/watch?v=e-tGEOdeEJE[/ame]
2019 BRZ | Autocross focused, CSG tuned w/Jackson racing C38 & PTuning flex fuel kit
2021 GTI | Daily Last edited by AllThePeat; 07-12-2019 at 01:19 AM. Reason: Mod list |
07-30-2019, 04:51 PM | #254 |
Custom User Title
Here's my fastest left and right runs from the Packwood ProSolo a couple weeks ago. Constructive criticism is always welcome, thanks guys.
[ame="https://www.youtube.com/watch?v=8qyb5-hWJlI"]https://www.youtube.com/watch?v=8qyb5-hWJlI[/ame] [ame="https://www.youtube.com/watch?v=R1z0VwxscI4"]https://www.youtube.com/watch?v=R1z0VwxscI4[/ame]
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
07-31-2019, 01:02 PM | #255 | |
***** Lurker
Drives: 2015 BRZ
It may only be the difference of a 1/10th through there, but every 1/10th matters. It might also be interesting to see what the data says about the difference in your runs vs Glen's from the start to the end of the slalom. |
10-10-2019, 10:47 AM | #256 |
Drives: 1999 Miata
Here are my first two runs in my newly set-up STX BRZ (Could not get the GoPro to connect to the head unit and thanks to the iOS 13 update the GoPro app no longer works on my phone).
Current set-up: Feal 441+ coil-overs, swift springs Megan Front sway bar SPC rear lower control arm Momentum Intake Perrin Crank pulley HKS EL Header Custom 2.5" exhaust from the header back OFT Stage 2+ tune (Optimized by me) Rota Grid 17x9 +35 wheels RE-71r's (First event on these tires, love Rivals, these are MEH. Too noisy) Front Pressure(Starting): 30psi Rear Pressure (Starting): 28psi Alignment is as follows: Front: Camber:-2.1 degrees negative Caster: +6.5 Toe: 1/16" Toe-out Rear: Camber: -1.5 degrees negative Toe: 1/16" Toe-in Car was pushy and would transition to oversteer. Between these runs I adjusted the front struts which made the push a little better, but not cured. This made the second run very loose, I adjusted the rear shocks and dialed the car in as much as I could, but I think I need front camber bolts to get more front camber. With more front camber, I can then dial in more rear camber (Limited because of front camber). Thoughts? [ame]https://www.youtube.com/watch?v=778Zq28iozs[/ame] [ame]https://www.youtube.com/watch?v=TcsFZsUgAWc[/ame]
DJ
1999 Miata VVT swap "Maggie" 2013 BRZ "Nancy-Drew BRZ" |
10-10-2019, 11:03 AM | #257 |
Yes more camber, wouldn't go any less than -3F/-2R, if the stones are fresh they need to scrub in a bit so they'll get better imho, looks like you've got a good starting point.
The Following User Says Thank You to strat61caster For This Useful Post: | MX-5RACER (10-11-2019) |
10-11-2019, 09:43 AM | #258 | |
Drives: 1999 Miata
I am hoping I can get closer to -3.2 in the front with the camber bolts and be able to back off the camber plates between events. Any idea how adjusting the camber plates affects toe? I also plan to remove the camber plate bolts and replace them with studs and a nut. I think this will be more reliable when I start adjusting them before and after events.
DJ
1999 Miata VVT swap "Maggie" 2013 BRZ "Nancy-Drew BRZ" Last edited by MX-5RACER; 10-12-2019 at 09:34 PM. |
10-11-2019, 10:02 AM | #259 |
Not sure the magnitude of toe change, it certainly happens I just haven't measured in years, but I've been dailying -4 for the past year, you can grab some toe plates to check.
10-11-2019, 07:29 PM | #260 | |
Drives: 23 BRZ 15 Impreza
I've measured a 2mm gain of toe in going from camber plates at zero and ~ -2.2 of camber to maxing out the camber plates and getting up to ~ -3.2 of camber. YMMV. |
The Following User Says Thank You to cueball89 For This Useful Post: | strat61caster (10-11-2019) |
10-12-2019, 08:32 PM | #261 |
Drives: 2017 BRZ w/PP
I just learned about track addict last autocross so here is my first video with it. It helped me see corners i could take faster, but it clearly didnt help my terrible line.
[ame]https://www.youtube.com/watch?v=FBqm3nACxA0[/ame] [ame]https://www.youtube.com/watch?v=_9pGn8dxVxE[/ame] honestly i think i just need to grow more balls and work on better lines. i knocked a second and a half off just noticing i wasnt on the gas or brakes a ton Last edited by Breadman; 10-12-2019 at 09:22 PM. |
The Following User Says Thank You to Breadman For This Useful Post: | strat61caster (10-15-2019) |
10-15-2019, 10:43 AM | #262 |
My VTEC fluid is full
Drives: EFF JAY
Lots of rust. SSC car.
[ame]http://youtu.be/7GVfPOyeB48[/ame] |
The Following User Says Thank You to iLuveKetchup For This Useful Post: | strat61caster (10-15-2019) |
01-26-2020, 02:32 PM | #263 |
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
This with -.9 degrees of camber up front...need moar camber...and seat time. Always seat time.
[ame]https://www.youtube.com/watch?v=7eMmUa9h6tU[/ame] |
01-26-2020, 05:30 PM | #264 |
Weird 'not slalom' at 18s or were the cones wrong?
01-26-2020, 05:47 PM | #265 |
The Following User Says Thank You to BlueWhelan For This Useful Post: | strat61caster (01-26-2020) |
08-04-2020, 10:59 AM | #266 |
Drives: EFF JAY
The new SSC Falken RT660 tires feel great!
Similar Threads | ||||
Track Videos - Directory and Discussion | Dave-ROR | Tracking / Autocross / HPDE / Drifting | 697 | 04-13-2024 07:46 AM |
*Groupbuy: Invidia N1 and Q300 Cat-Back Exhausts (SS tips, T.I. tips) -fteightysix* | 86SPEED | Groupbuys | 74 | 11-09-2016 01:45 PM |
Feldys Autocross videos | feldy | Tracking / Autocross / HPDE / Drifting | 25 | 06-13-2013 02:58 PM |
Need help with some tips for autocross | Toyota GT 86 | Tracking / Autocross / HPDE / Drifting | 10 | 04-30-2013 06:43 AM |
2012 BRZ/FR-S Stock Class Autocross Discussion | EMguy | Tracking / Autocross / HPDE / Drifting | 183 | 01-04-2013 03:17 AM |
