Old 04-12-2019, 11:33 AM   #127
extrashaky
Drives: 2014 BRZ Limited
Is that with or without a driver sitting in it? My understanding was that once you put a driver in it, it shifts the distribution toward the center to near 50/50.
Old 04-12-2019, 01:07 PM   #128
Clutch Dog
Drives: 2017 BRZ PP , 2005 Saab 97X
Originally Posted by 949 Racing View Post
Ours was 54%, but I was quoting factory specs to avoid arguments
Im probably closer to 56... cause.. am huge.
If there was a 5 fot 4 guy and 160 lbs it might be closer to 53% front hahahah
Clutch Dog is offline   Reply With Quote
Old 04-12-2019, 07:25 PM   #129
extrashaky
But you're not sitting in the front. You're sitting near the center. If the COG started forward, putting more weight in the center would shift it toward the rear.
Old 04-12-2019, 08:48 PM   #130
Clutch Dog
Really long legs... and more realistically. if you add weight between the two wheels, you are adding weight to both the front and the rear.
Im getting an alignment and scales done later this month, I'll play around with it then.
Old 04-12-2019, 11:23 PM   #131
cjd
cjd's Avatar
Drives: 2017 BRZ
I get 54.x% also (me in but high autocross gas levels, 1/4 tank or so). And that's with the only weight reduction being up front (OK, no trunk junk either...) I weighed it when I got it home for the first time too, forget what it measured. Probably have it somewhere.
Old 04-16-2019, 12:36 PM   #132
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
Just checking in after the preliminary testing on the Xida protos. I think we got all the dimensions spot on. We tweaked strokes and body lengths from OEM slightly. Those willing to remove or modify front fender liners or trim a tiny bit from the rear bumper skin can achieve additional bump travel. The advantage there is being able to run lower for competition without bottoming. As the system will have a small amount of ride height adjustment along with the usual preload adjustment, it will still accommodate taller than OEM 255/40/17 and completely unmodified fenders/liners. We will ship the kits adjusted to that length so no one will have tire clearance issues out of the box. But for those that are willing to go off the reservation with big tires and competition ride heights, and willing to mess with the fenders, more bump travel is available.
Before anyone asks the inevitable "How low!!??", the limits will be tire clearance, not the Xidas.
Damping wise, our bump/rebound ratios and digression are just about spot on for sporting and competition use. The softest settings for daily driving on soft springs need to be even softer. So we will make some tweaks to the valving and continue testing. Even with the current valving, they already ride much better than OEM on the springs stiffer than the RCE yellows. The stock shocks inability to soak up big sharp hits is magically fixed. Really happy that our first prototype config is really close to final production spec, just a few small tweaks to low speed comp on the soft end and a bit more digression on the stiffer settings.
One thing we suspected, and seems to be supported by our initial test drives, the FR-S in particular, does not need a bunch more rear sway bar as most tuners would suggest. We're still running the stock rear even with Hoosiers, just a slightly larger front so far.
949 Racing is offline   Reply With Quote
The Following 3 Users Say Thank You to 949 Racing For This Useful Post:
churchx (04-16-2019), Code Monkey (04-16-2019), Shark_Bait88 (04-16-2019)
Old 04-16-2019, 02:37 PM   #133
CoolHandMoss
Drives: 2013 FRS
Any idea when they might be available? Spring 2020?
CoolHandMoss is offline   Reply With Quote
Old 04-16-2019, 04:38 PM   #134
churchx
churchx's Avatar
Drives: 2014 GT86
949 Racing: how are xida's strut bolt holes placed, is "camber out of-box" with them same as OE or more (even without camberbolts/camberplates, especially in front)? As for how low .. i'm from those weirdos, that would wish for ride height to be tunable at least to stock height. Given local roads & speedbumps here, no slightest wish to go lower then OE even slightly.
Old 04-16-2019, 08:58 PM   #135
Clutch Dog
Im actually contemplating on getting suspension spacers to raise the car back up as well... im glad im not the only one
Old 04-17-2019, 01:08 AM   #136
vgarcin
Swiss Alps Driver
vgarcin's Avatar
Drives: Toyota gt86
You re not going to have reliability issue with the rear axles running so low?
vgarcin is offline   Reply With Quote
Old 04-17-2019, 01:57 AM   #137
churchx
churchx's Avatar
Drives: 2014 GT86
vgarcin: i guess, for rear, just as with other overlowering means in past, one can just install diff riser.
Old 04-17-2019, 12:34 PM   #138
949 Racing
949 Racing's Avatar
Target is OEM location for steering knuckle as baseline, then two steps negative from there. Exactly how much more negative TBA.
OEM ride height no problem.
The Following User Says Thank You to 949 Racing For This Useful Post:
churchx (04-17-2019)
Old 04-17-2019, 01:25 PM   #139
churchx
churchx's Avatar
Drives: 2014 GT86
949 Racing: if it's hard decision on what camber choose for set as defaults, what do you think of implementing something like many rally coilovers have - slotted strut hole with different offset inserts, something like this #1, #2, #3, #4? Should provide secure against slipping adjustability even without adjustable topmounts or camberbolts.
Old 04-17-2019, 01:34 PM   #140
949 Racing
949 Racing's Avatar
Not a hard decision, just not public yet
6ul, 949 racing, blub, xida
LED Blub Diffuser? Chimera Cosmetic Modification (Interior/Exterior/Lighting) 5 07-07-2016 12:24 PM
Project Mu Racing 999 brake pads CSG Mike Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 11-15-2013 03:55 PM
Project Kics R40 racing lug nuts HighbreadEH3 Wheels and Tires 0 09-03-2013 01:49 PM
The Enjuku Racing Project FR-S! Enjuku Racing Announcements, Contests, Giveaways 12 07-19-2012 11:54 AM
