06-09-2016, 11:47 PM | #29 | |
Drives: FRS Silver LS1 swapped.
06-10-2016, 12:03 AM | #30 |
Drives: It has 4 wheels
06-15-2016, 06:14 AM | #31 | |
Drives: 22RE, FA20, 4G63
Edit: keeping all electronics working. That's one of the reasons I buy, first I can tune the FA20 as desire and if some day the swap materialize the ECU thing is already there... Last edited by AJPG; 06-15-2016 at 06:32 AM. |
06-15-2016, 10:28 AM | #32 |
Drives: 2013 Brz C38 (bought not built :P)
10-02-2017, 12:31 PM | #33 |
Drives: Frs
I really want to built a frs or brz but don’t know what engine swap. Im between ls swap or a 2jz. Any recommendations with engine swap is better?
10-02-2017, 03:38 PM | #34 | |
Drives: 2015 Raven V8
A lot of the 2jz swaps I've seen seem to be focused on huge power and most being drag setups. Personally I think LS is a bit easier, engine fits nicely in the bay with no mods to firewall or radiator mounting. |
10-05-2017, 09:52 AM | #35 | |
Drives: Frs
10-05-2017, 10:26 AM | #36 |
Drives: 2015 GTI
LS will get you there easily. If you’re not shooting for more hp then there is not much of a reason to go 2JZ.
10-05-2017, 03:25 PM | #37 |
Drives: Frs
10-10-2017, 11:57 AM | #38 |
Drives: RAVEN
Curious as to what the state of the art is for the rear end when doing a Ls swap?Are most people getting away with the factory parts? That would be a huge savings. When I did the Miata V8 swap, even the low-buck 8.8 conversion stuff was over 2K and some fabrication effort that has to come-out right.
10-10-2017, 12:25 PM | #39 | |
Drives: 2013 Ultramarine FR-S
Similar Threads | ||||
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-21-2015 11:38 PM |
2JZ swap? | jordydiaz | Engine Swaps | 44 | 05-21-2015 10:19 PM |
2jz swap | p3raltaboi | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 06-11-2014 08:09 PM |
Key Fob Swap | joergasm | BRZ First-Gen (2012+) -- General Topics | 1 | 10-02-2012 11:40 PM |
