08-26-2017, 03:40 PM | #253 | |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | BirdTRD (08-26-2017) |
09-27-2017, 02:41 AM | #254 |
Drives: car
Torque spec transmission differential gt86 brz?
What is the service manual's recommended ft/lbs torque spec for the drain and fill plugs on the transmission and differential?
*edit* nvm found it. trans: 27 ft/lbs diff: 36 ft/lbs Last edited by radroach; 09-27-2017 at 10:16 AM. |
The Following User Says Thank You to radroach For This Useful Post: | ragequitfail (09-27-2017) |
12-07-2017, 10:52 AM | #255 |
Drives: 2013 WRB BRZ Limited
How terrible would it be to use
https://www.amazon.com/Mobil-104361-75W-90-Synthetic-Gear/dp/B000ONZXPK/ref=sr_1_1?ie=UTF8&qid=1512661887&sr=8-1&keywords=mobile+one+75w90 in the diff and in the transmission. Does the LS property make in unsuitable for use in the transmission? Just curious.
"If you're not first you're last!" -Ricky Bobby
12-07-2017, 08:57 PM | #256 | |
Drives: 2013 Firestorm FRS
You don't have to buy it too often! You CAN use the LS stuff in the diff though, but I'd just run the same of everything. |
12-23-2017, 09:43 PM | #257 |
Drives: 2013 brz
So... Can we use 2L and get away with 2 one L bottles or does it have to be 2.2L such that we have leftover?
01-06-2018, 04:37 PM | #258 |
Drives: '13 Whiteout FR-S
.2L is around 6.75oz, so not quite one cup. I think it'd be worth having the correct amount in there. It's not worth risking the transmission to save $25
04-06-2018, 01:12 AM | #259 | |
Drives: 2014 Subaru BRZ
Sent from my SM-G925V using Tapatalk |
04-20-2018, 11:39 AM | #260 |
Drives: Whiteout Scion FR-S
Not too bad. I haven't touched them since I put them in (skipped changing the fluid last summer). After two Minnesota winters, they are still in decent shape on the differential. From the looks of the condition, I should be able to remove without them without undue effort in the summer. I will look at the transmission bolts soon as the weather improves. The photo showing snow was take on Monday, April 16, 2018. Today should have a high of 56°F so things are melting. It looks like spring is finally coming to Minnesota.
05-10-2018, 11:00 AM | #261 |
Drives: 2013 Rally Blue BRZ
Did anyone measure the crush washers? I really don't want to pay the dealership $15 for a couple crush washers. I'm guessing they aren't the same size as the ones used by the oil drain plug. That'd be too easy!
05-10-2018, 04:44 PM | #262 | |
http://www.ft86club.com/forums/showp...8&postcount=14 And yes, someone's found cheaper alternates online: http://www.ft86club.com/forums/showp...7&postcount=40 |
05-13-2018, 12:49 PM | #263 | |
THANKS! Maybe we can get OP to post those in the first post. |
07-03-2018, 09:49 PM | #264 | |
Drives: Q5 + BRZ + M796
There are vehicles that call for filling the fill plug on a level surface until oil begins to drain because the drain location would represent the volume of fluid required for the change. In that case, the vehicle needs to be as level as possible. In the case that someone knows how much to fill, the best procedure would be to tilt the car towards the drain plug to maximize emptying then to tilt the car away from the fill plug to maximize fluid retention. Am I missing something?
07-04-2018, 12:40 PM | #265 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
The Following User Says Thank You to BirdTRD For This Useful Post: | Irace86.2.0 (07-04-2018) |
07-04-2018, 02:47 PM | #266 | |
Tags |
differential, diy, fluid, transmission |
Similar Threads | ||||
Transmission fluid swap? | flawedchemical | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 48 | 09-12-2014 02:23 PM |
What Differential fluid is in your BRZ/FRS? | ft86Fan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 11-12-2012 08:57 PM |
Anyone change transmission lube yet? | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 08-21-2012 05:47 AM |
FR-S quick reference and warranty / maintenance guide is up | pkny | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 06-20-2012 11:33 PM |
topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) -- General Topics | 51 | 05-04-2012 07:54 PM |
