Doborder, orthojoe
Old 06-29-2012, 06:27 PM   #15
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 07-02-2012, 12:51 PM   #16
simpleisbest
Senior Citizen
Drives: Scion FR-S
Get one of these:
http://www.flyinmiata.com/index.php?...umber=35-70000
Allows you to safely jack half of the car at once. I used it on my Miata and tested it on my FR-S last night. Works like a charm.
simpleisbest is offline   Reply With Quote
The Following 4 Users Say Thank You to simpleisbest For This Useful Post:
amram (04-10-2014), civicdrivr (07-02-2012), finch1750 (06-11-2013), Fly Guy (07-11-2012)
Old 07-02-2012, 01:01 PM   #17
Ben_G
Drives: Blue BRZ
Originally Posted by simpleisbest View Post
Get one of these:
Oh shit..... I've been using a wooden block with a channel cut into it..... Functional, but this looks much more pro.
Sent from my Galaxy Nexus using Tapatalk 2
Ben_G is offline   Reply With Quote
Old 07-03-2012, 10:18 AM   #18
Wepeel
Drives: '13 BRZ Ltd
The Harbor Freight 3 Ton jackstands have a notch deep enough to clear the pinch welds (they're actually orange and white):
http://www.harborfreight.com/3-ton-h...nds-38846.html
Wepeel is offline   Reply With Quote
Old 07-10-2012, 11:35 PM   #19
GUYVER116
GT86
GUYVER116's Avatar
Drives: Whiteout FR-S:(5/14/12)
Does anyone know where is the best placement for a jack to lift your engine once your motor mount bolts are loose? (Installing a downpipe but need a inch more clearance for fit where the overpipe once was)
FR-S Whiteout
GUYVER116 is offline   Reply With Quote
Old 07-16-2012, 02:50 AM   #20
SFTiofoso
Drives: '10 Civic Si Coupe
I've always used polyurethane pads on my jack and jack stands. They protect the paint from chipping (rust), prevent the jack/jack-stands from bending/denting jack points, and help secure the car even better, as there is more friction than just the metal-to-metal contact points.
You can get some from summit racing: http://www.summitracing.com/search/?...e%20jack&dds=1
SFTiofoso is offline   Reply With Quote
Old 07-31-2012, 06:31 AM   #21
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Does anyone recommend against using flattop jack stands with the pinch welds?
http://sector111.com/track/highly-re...jacks-pair.cfm
I'm thinking about going with a 2 pairs of these.
These look good too, but super expensive
http://www.jackpointjackstands.com/
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
\o/ (04-14-2014)
Old 07-31-2012, 07:42 AM   #22
xwd
Too expensive you can get aluminum jack stands at Harbor Freight. They also sell jack stand pads. I wouldn't get the flat ones even though you can probably find a spot for them under the car.
As for jack pads, I've had one of these for years, works great. Of course a hockey pick works too but this gives a little more lift.
http://protechproducts.com/index.php...&product_id=57
Old 08-16-2012, 04:31 AM   #23
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Can anyone confirm whether any of the Harbor Freight jacks will be able to slide under the front of the car, reach the front-middle jack point, and get the car up high enough to slide jack stands in on the sides?
Some other jack to recommend instead? I can confirm that this puny craftsman one doesn't cut it heh: http://www.sears.com/craftsman-2-1-4...1&blockType=G1
Phaedrus29 is offline   Reply With Quote
Old 08-24-2012, 05:19 PM   #24
Phaedrus29
Phaedrus29's Avatar
I ended up getting this jack from Harbor Freight: http://www.harborfreight.com/2-ton-l...ump-68051.html
Because the front jack point is back a bit, the raised part of the jack gets much too close to the front bumper for my liking. Especially if the car is lowered, I can't imagine this jack will work. Hrmmmm...maybe this one would have been a better option:
http://www.harborfreight.com/2-ton-l...ump-68050.html
UPDATE: OK I exchanged my jack for this one: http://www.harborfreight.com/2-ton-l...ump-68050.html
I can confirm that the new jack works great with no clearance issues whatsoever.
Old 08-31-2012, 05:22 AM   #25
jstans84
Drives: Scion FR-S
This makes me even happier to have a buddy with a lift at his house.
jstans84 is offline   Reply With Quote
Old 09-10-2012, 02:54 PM   #26
sa1126
Drives: n/a
Stupid question, but I am having a hard time finding the front lift point. How far back is it (or maybe the FRS is different underneath?)?
I don't have enough clearance to get a good look and my jack doesn't seem to slide very far underneath before it runs out of room for height.
Sorry for all the questions. I just want to make sure I am getting this right.
Raven MT as of 07-09-2012
'01 Taco prerunner
sa1126 is offline   Reply With Quote
Old 09-10-2012, 03:11 PM   #27
Phaedrus29
Phaedrus29's Avatar
The jack point is pretty far back...most jacks won't be able to reach it. Initially I tried a little craftsman trolley jack which had no shot. Then I tried this jack from Harbor Freight, but it did NOT really clear the front lip: http://www.harborfreight.com/2-ton-l...ump-68051.html
Here's the part of the jack that got super close and basically touched the lip, and this is a fairly low profile jack:
I exchanged that jack with this one and it clears the lip and it goes back far enough to reach the jack point with no issues:
The only issue is that it's a heavy monster, but it works!
The Following 3 Users Say Thank You to Phaedrus29 For This Useful Post:
amram (04-10-2014), Chenslee (11-24-2015), isolato (09-06-2015)
Old 09-10-2012, 03:16 PM   #28
sa1126
Drives: n/a
Thanks for the heads up...I actually have a coupon for harbor freight here.
Is there any other way to safely lift the front of the car without having to go buy a new jack?
'01 Taco prerunner
Jacking up car - using garage jack NYNOMAD BRZ First-Gen (2012+) -- General Topics 2 06-27-2012 08:36 AM
Front jacking point dsgerbc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-30-2012 05:19 PM
Supporting Mods Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 02-21-2012 05:33 PM
Unacceptable: Toyota/Subaru among group of auto manufacturers supporting SOPA. Mitch Other Vehicles & General Automotive Discussions 43 01-09-2012 08:07 AM
