eddieEndo
Old 01-23-2018, 12:10 PM   #239
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
4X4 STOCK HEIGHT FOR NOW
AVID.1 AV-30 FLAT BLACK
FRONT: 18X8.5 +35 - 225/40/18
REAR: 18X9.5 +30 - 235/40/18
xenarc is offline   Reply With Quote
The Following User Says Thank You to xenarc For This Useful Post:
FRS13_ (02-09-2018)
Old 02-09-2018, 01:32 PM   #240
texastwurkt3am
texastwurkt3am's Avatar
Drives: '17 PP BRZ
18x8+45 squared Enkei Raijins, powder coated Illusion Red, wrapped in 225/40 G-Force Comp-2 A/S
texastwurkt3am is offline   Reply With Quote
The Following User Says Thank You to texastwurkt3am For This Useful Post:
FRS13_ (02-09-2018)
Old 02-16-2018, 04:46 PM   #241
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
17x7 +42 RPF1s, 215/45/17 RE71r tires
18x7.5 Advan RG2's 225/40/18 Continentals
-B
HeresMyMind is offline   Reply With Quote
The Following User Says Thank You to HeresMyMind For This Useful Post:
Leonardo (02-16-2018)
Old 02-16-2018, 05:22 PM   #242
FRS13_
FRS13_'s Avatar
Drives: 2013 Scion FRS 6-speed
FRS13_ is offline   Reply With Quote
Old 02-18-2018, 06:39 PM   #243
Waffle86
Waffle86's Avatar
Drives: 2013 SWP BRZ Limited
Stock height + Aftermarket wheels compilation!!!!
Originally Posted by Relyt86 View Post
I'm thinking of getting a 18x8.5 wheel (I don't know the offset i want; I want to be flush, if anyone knows a good offset for this size, Please tell me) (Also on stock suspension)
The tire size I'm thinking of is a 245/40/18 or a 245/35/18
I don't know which tire size would be better for fitment.
Please tell me which is best, thank you!
Plenty of treads on the forum for you to get a visual idea of what fitment you'd like. Generally people usually go for +35, +38, or +42/45 depending on desired stance, what wheel you're looking at, and what is offered in that size. When I was at stock height I ran 18x9.5 +38 and I was perfect in the rear with a small bit of poke in the front. Here's a pick of mine: if you went +38 you'd be about 1/2" more sunk in due to being an inch less in wheel width. I'm on 235/40 Continental DWS06 Tires for reference.
FYI - if you decide to go 9.5, +38 and higher (+42/45) have issues clearing the front spring perch on stock struts.
Waffle86 is offline   Reply With Quote
Old 03-05-2018, 08:25 PM   #244
DJ Rain Candy
Drives: 2013 Ignition Silver Scion FR-S
https://imgur.com/a/ecFR9
17x9 +38 SSR GTX01s
Sorry I'm garbage at formatting
DJ Rain Candy is offline   Reply With Quote
Old 03-25-2019, 01:32 AM   #245
mac_77
Wheels Spec
Originally Posted by FR-FKN S! View Post
Can you share your wheels specs ?
mac_77 is offline   Reply With Quote
Aftermarket lug nuts on stock wheels: confirm? empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-19-2018 07:38 PM
Aftermarket wheels with stock suspension Thongpocket Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-24-2013 05:08 PM
Stock TPMS's with aftermarket valves/wheels? Phaedrus29 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2012 01:18 PM
Need help with Stock height measurement D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-03-2012 03:30 AM
Aftermarket wheels on stock BRZ/86s yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 2 05-01-2012 02:52 AM
