Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
08-12-2019, 02:18 PM | #15 |
Senior gif poster
Drives: 2013 Asphalt FRS
hey sorry for the semi off topic but I had a quick question:
I've never ordered rotors online before, and Im looking at a new set on rockauto and I don't get the two different sizes 277mm or 292mm? Is the front and back rotors different sizes? Other than cost is there any reason not to get the 292mm rotors for front and rear? This is what I'm looking at, the centric ones under daily driver with the heart icon: https://www.google.com/url?q=https:/...4i58U7_n2jNYrQ Any advice or guidance form more experienced folks would be greatly appreciated, I gotta order some asap so I can hopefully do the job by next weekend. |
08-12-2019, 02:32 PM | #16 | |
Drives: Black FRS
The Following User Says Thank You to Butterballz For This Useful Post: | DandoX (08-12-2019) |
08-12-2019, 02:41 PM | #17 | |
Senior gif poster
Cool thanks man, and it is the same size rotor all round correct? |
08-12-2019, 02:55 PM | #18 | |
Drives: Black FRS
Fronts are 292mm and get specifically the VENTED rear rotors. These are the Centric part numbers for the rotors I bought a while back: Fronts: 12047021 Rears: 12047031 |
08-12-2019, 03:11 PM | #19 | |
Senior gif poster
Awesome thanks man, that helps a lot. I see both those part#s so I will just order 2 of each. Doesn't help rockauto does not label which ones are front and which ones are rear. I was about to order 4 fronts lol. |
08-12-2019, 10:07 PM | #20 |
Drives: Black FRS
Update - So I got the 2017 caliper and haven't removed the piston yet but it seems like the exposed part of the piston is the same diameter as the ones I have now.
So I'm just going to say its the same all years at 40mm or something. Not sure where the 42.8mm and 40.4mm numbers came from other than that's what they were for other Subaru models. |
Similar Threads | ||||
Sumitomo 4 Piston WRX caliper upgrade | GC GTS Aero Kit | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 12-06-2020 09:55 AM |
Alcon Front Brake Kit, 4-piston 332x28mm Rotor Size - now available!! | FRSport.com | Brakes, Suspension, Chassis | 0 | 07-08-2016 07:14 PM |
Rear brake caliper banjo bolt size? | ChrisD | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 04-22-2016 06:51 PM |
Front Brake Caliper Piston Rebuild? | smbstyle | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 0 | 10-17-2013 05:18 PM |
BRZ/FRS big brake kit vs WRX counterparts: brake piston size (differences, if any)? | mav1178 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-25-2013 12:07 PM |
