Old 07-31-2012, 10:26 AM   #29
thejevans
Rugger Extraordinaire
thejevans's Avatar
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
When doing mine the other day, the part that the pulley rides on came out. Let me tell you, it was a bitch to put back. there is a notch on the back of it that needs to be lined up, and has no wiggle room. Once it slides out a 1/2", then you got a problem. Be very careful to make sure this doesn't happen.
thejevans is offline   Reply With Quote
The Following 4 Users Say Thank You to thejevans For This Useful Post:
BabaYaga (03-05-2015), brybot (12-23-2016), ChrisD (07-08-2015), civicdrivr (07-31-2012)
Old 07-31-2012, 04:37 PM   #30
xcelir8brz
Drives: 2013 BRZ Limited
Well done!
xcelir8brz is offline   Reply With Quote
Old 07-31-2012, 04:45 PM   #31
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
Did you get that from TiTAN by any chance?
I sent him my money but later found that he got banned which would explain the lack of communication from a otherwise really quick to respond vendor.
have any contact info I could use?
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 07-31-2012, 05:27 PM   #32
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
anyone in socal that has done this mod that can helped me do mine???its been a month since i received my pulley i already try 3 times to take off the stock pulley but i cant.the stock pulley keeps rotating everytime id try get it loose.ive done everything right,car in 6th gear,ebrake,brakes but the stock pulley rotates so i cant get it loose helpppppp
Sall is offline   Reply With Quote
Old 07-31-2012, 05:52 PM   #33
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I spent about two hours trying to loosen the stock pulley. My mistake was, I was not setting the e-brake hard ebough and the crank kept rotating. Also, use a long breaker bar, set that e-brake very firm and 6th gear and turn it. It will work.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Sall (07-31-2012), Techfl3x (10-05-2013)
Old 07-31-2012, 05:58 PM   #34
wu_dot_com
Drives: accord
im in cerritos, just installed mine last night.
though it wasnt easy, i was able to do it in under 30 min.
I usually gets home around 8, let me know if you want to bring your car by.
wu_dot_com is offline   Reply With Quote
The Following 2 Users Say Thank You to wu_dot_com For This Useful Post:
paintdude258 (10-21-2020), Sall (07-31-2012)
Old 07-31-2012, 06:59 PM   #35
Sall
Sallbaru
Sall's Avatar
Drives: raven FRS
like i said im doin everything right.but my stock pulley rotates way too much idk why
Old 07-31-2012, 07:38 PM   #36
Sportsguy83
Drives: Limited BRZ
How long is the breaker bar you are using?
Old 07-31-2012, 08:12 PM   #37
Calum
That Guy
Drives: 2013 asphalt FRS MT
I did mine the other day. The vast majority of what I did was the same as the OP's. The biggest difference though is that I didn't need to remove the filter box or sensor, only the intake tube.
My list of tools was sockets: 8mm, 10mm, 14mm, and 22mm. Also a ratchet, short extension, and a breaker bar. You may also need needle nose pliers to remove the PCV tube from the intake tube. Oh, and of course a small amount of oil.
The Following User Says Thank You to Calum For This Useful Post:
Old 08-02-2012, 02:59 AM   #38
jpit
Drives: Subaru BRZ
Also, make sure the O ring doesn't slip off.
jpit is offline   Reply With Quote
Old 08-02-2012, 12:45 PM   #39
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by Enigmus View Post
Get some motor oil and grease up the threads and flat surface of the bolt head before inserting back into the pulley.
Great DIY! I wonder if you could use anti-sieze on the crank pulley bolt instead of motor oil. [Speaking here from the land of road salt and sand.]
My cars always dress formally. They all wear black tires.
Black Tire is offline   Reply With Quote
Old 08-02-2012, 02:14 PM   #40
thejevans
thejevans's Avatar
I had this problem as well. There's a simple solution that should solve your problems.
-Put the car in neutral
-Put the beaker bar with socket on the pulley
-Move the breaker bar as far CLOCKWISE as it will go
-Put the car in sixth
-Pull the breaker bar COUNTER-CLOCKWISE and you should have enough room to break the bolt loose even with the play in sixth
Good luck.
Old 08-02-2012, 03:37 PM   #41
wu_dot_com
Drives: accord
we tried 24" breaker (the longest avaliable at autozone). no help. he and i were going at it for at least an hour.
we think the problem is something his friend did to the car during his first attempt.
we crank the bolt so hard that the car even rotate while the bolt just stay dead on.
as a last resort, we even spray some WD40 on the bolt head flange hoping it would loosen it up... no luck.
im now thinking perhaps kroil might help...
milko002 (01-26-2013), Sall (08-03-2012)
Old 08-02-2012, 03:40 PM   #42
wu_dot_com
Drives: accord
Good luck.
we tried something similar, like releasing the break and let the car roll for a bit in 6 to get a good grip... no luck... perhaps your methond is better and worth a try.
The Following User Says Thank You to wu_dot_com For This Useful Post:
Sall (08-03-2012)
brz, crank pulley, diy, frs, perrin, raceseng
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
