Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Software Tuning
Old 11-06-2019, 04:45 AM   #1
gt7877
Drives: turbo frs
log whp???
Dear
Is there any way to log whp?
If there is no Dyno around
For scion FRS?
gt7877 is offline   Reply With Quote
Old 11-06-2019, 06:03 AM   #2
steve99
steve99's Avatar
Try virtual dyno
https://www.google.com/url?q=https:/...88sf8iNwlZaasW
gt7877 (11-06-2019)
Old 11-06-2019, 06:48 AM   #3
gt7877
Drives: turbo frs
Thnx Steve
But what parameters I have to log by ecuTek
If I have ecuTek tune ??
Coze sometimes virtual Dyno gave error msg
Also how I can any FRS has oft tune by tactrix openport?
Thnx again
Old 11-06-2019, 07:17 AM   #4
steve99
steve99's Avatar
Originally Posted by gt7877 View Post
Thnx Steve
Thnx again
I have not used virtual dyno unfortunatly.
But try removing any lines at top of logs that are not data or parameter name
gt7877 (11-06-2019)
Old 11-06-2019, 08:16 AM   #5
DarkPira7e
Handin' out 1 Deags
DarkPira7e's Avatar
Drives: 13 Firestorm Red FRS
The only thing that can truly log your WTQ or WHP is a dynomometer. Only the ground can measure how much force you're pitting against it, a computer can only guess (which is why dynos were created, to measure force exertion). What Steve has given you is as close as you'll get without going onto a dyno.
The Following User Says Thank You to DarkPira7e For This Useful Post:
gt7877 (11-06-2019)
Old 11-06-2019, 08:22 AM   #6
solidsnake11
Drives: brz
This is what I found on the net
N/A and Turbo Engine HP= MAF (g/s) * 1.25
Supercharged Engine HP=MAF (g/s) *1.1
N/A and Turbo Dynojet WHP manual= MAF (g/s) * 1.1
Supercharged Dynojet WHP manual =MAF (g/s) *0.95
Log maf g/s then multiply by number above that fits your setup.
solidsnake11 is offline   Reply With Quote
The Following User Says Thank You to solidsnake11 For This Useful Post:
gt7877 (11-06-2019)
Old 11-08-2019, 10:46 AM   #7
wparsons
wparsons's Avatar
This is critical, otherwise it'll fail to import the log into virtual dyno.
I can't remember what needs to be logged, but at a minimum it needs RPM and throttle position. You might need to modify throttle position, IIRC virtual dyno needs it above 95% and sometimes it'll log lower than that.
You can open the log file in excel (or google docs), just set throttle position to 100 wherever you were actually at WOT, and cut out any lines before or after the WOT pull.
You need to tell it what gear, and by default it won't let you run it in 2nd gear. 3rd gear is the minimum you want the pull to be done in.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
gt7877 (11-09-2019)
Search this Thread:
Advanced Search
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
