Tracking / Autocross / HPDE / Drifting What these cars were built for! |
08-23-2014, 11:29 PM | #57 |
in orbe terrum non visi
Drives: violent
Ae86- $500, lexus v8, transmission, wiring harness, ecu-800$ gutted-free, coilovers-500$, the look on peoples faces-priceless. I would have gone ls1 but the lexus v8 was damn cheap and local.
08-23-2014, 11:44 PM | #58 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
The beauty of that approach is that it's so easily achieved. And inexpensive if you wish. |
08-23-2014, 11:52 PM | #59 |
Drives: violent
True. See my above comment.
08-24-2014, 03:16 AM | #60 |
Drives: ...saving up for FRS/BRZ still
I guess another big Pro to having an LSx FRS instead would be...you won't look like every other rich arrogant asshle dckhd dousche that has a Porsche lol.
The FRS is 1000x more humble. You can still go to a drive thru to get a burger, without people around really secretly wanting to spit on your car. You can park at the mall, grocery, movies, restaurant, without people wanting to key your car and/or smear poop on the windshield/door handles. Ya...I don't think I could live with a fancy and flashy Porsche. Nice cars....but owning a Porsche will instantly transform you into a raging asshle dousche I bet. |
08-24-2014, 12:26 PM | #61 |
Drives: 2014 BRZ
The Porsche driver bashing is not appreciated and quite unwarranted. I'll wager many FRS owners will eventually end up with a Pcar and if they were not aholes before, owning a Pcar won't change them.
Also, the expense of tracking a Pcar isn't going be greater than an 86 with an LS.
08-24-2014, 12:39 PM | #62 |
Lacking brains
Drives: frz
With or without a pcar ill still be an asshole
08-31-2014, 09:29 PM | #63 |
Drives: 400whp Scion tC
No one cares about California.
I have been thinking about doing an LS swap. I have a track car already, so I'm more interested in drift car setup with my FR-S. It's LS/2jz or PTuning turbo setup. |
The Following User Says Thank You to SnapOv3st3r For This Useful Post: | orangeblue (02-22-2015) |
09-01-2014, 12:13 PM | #64 | |
Drives: Moped
Don't forget, 90% of the aftermarket companies are here too |
09-01-2014, 01:27 PM | #65 |
The Following User Says Thank You to dradernh For This Useful Post: | SnapOv3st3r (09-04-2014) |
09-01-2014, 07:31 PM | #66 |
Drives: 2014 BRZ
Toss in an E-Rod LS and there should be no problems.
09-02-2014, 04:33 PM | #67 |
Drives: 2020 BRZ PP
Just go into the swap with an open mind. It's going to nickle and dime you pretty bad if you do things right. Here's a couple things off my head from my buddy's car (s14 240 with LS1 swap.)
1. Save yourself the headache and buy a TurnOne power steering pump. The stock one is notorious for going out and blasting your engine bay with fluid. Also plan on a power steering cooler to help as well. 2. LS1's also are known for oiling issues. Might not matter too much when you're starting out depending on how experienced a driver you are but upgrading to slicks almost gurantees an oil sump. 3. Should you ever want to compete in a racing event the swap puts you in a group/level where it's more difficult to be competitive. (At least as far as NASA goes, not as familiar with SCCA or other organizations. 4. Be mindful that the slave cylinder takes a beating as well on track and to change it requires a transmission pull. 5. Consumables will depend on your skill level and other mods. A big brake kit will be a must and you will at the very least want suspension upgrades to handle the power. |
09-04-2014, 11:25 PM | #68 | |
Yea a dumb phenomenon. CA has the dirties tracks, the strictest car laws and still it's all anyone ever talks about in import magazines. |
10-05-2014, 05:47 PM | #69 |
I have been running an ls swap in a AC since 2000. started with ls1 (400) and ran it on the track for 6 years. many mods to the engine. distributed part all over the track in SC. next was a 6/3 put together that had problems from the start about 500 but solids never could last. now running dry sump ls7 620 but the heat is giving problems new radiators should help. something about more hp means more heat. shallow vet pan or dry sump is the only way to drop the engine low enough to fit I did it for cg and also offset to the right to compensate for belt size. GM now has a racing computer that can easily be programed with out worrying about nanny's.
10-05-2014, 07:11 PM | #70 |
With an unfinished estimate that included (only) 75 hours of shop labor, as well as a Vorshlag kit, I pulled the plug when I got to $30K for swapping a crate LS3 376/480 into my race E36 M3. The shop said a budget of $40K was more realistic for an all-new-parts swap that used my existing MoTeC M880.
Similar Threads | ||||
engine swap | p3raltaboi | Hawaii | 25 | 06-11-2014 06:15 AM |
Engine swap JDM EJ25 STI engine | FRSToyota86 | Engine Swaps | 25 | 11-20-2013 01:56 AM |
4-aGE engine swap on FR-S | bacon_cheese_beer | Engine Swaps | 13 | 12-15-2012 03:29 PM |
Engine Swap ... | Macavely | Engine Swaps | 220 | 07-25-2012 03:58 AM |
engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 05:10 PM |
