Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
04-16-2017, 12:03 AM | #15 |
Hooner in training... eh?
Drives: 2013 Scion FRS
Try to do some digging on here (or HIDPlanet as well), for local shops near you that offer headlight retrofitting services. That's probably going to be the best option if you're trying to get a specific look and output for around or less than the price of replacing the OEM $1500 healdights.
If you're unfamiliar with retrofitting: a shop will take apart your headlights and install a different set of projectors, bulbs, lens, etc in to your preference. HIDPlanet and The RetroFit Source are probably the two best places to start. Start there and see if anything piques your interest. Here's a quick review of the Spec-D headlights from a member that has some amazing retrofitting skills: http://www.ft86club.com/forums/showthread.php?t=63406 Also from the same guy, one of the more ambitious projects you can shoot for: http://www.ft86club.com/forums/showthread.php?t=33559
**Dunno what to put here yet... Imagine something witty...** |
04-16-2017, 12:19 PM | #16 |
Drives: 2023 BRZ
04-16-2017, 01:32 PM | #17 |
Drives: Grrrr
Car dismantles or breakers. Avoid the aftermarket tat.
04-16-2017, 02:26 PM | #18 |
Drives: 2023 BRZ
Thanks. I've been trying those with little success. I did find a place in CA that has something that would probably work, but still kinda pricey.
04-19-2017, 04:35 AM | #19 | |
Drives: Toyota GT 86
http://www.ft86club.com/forums/showthread.php?t=102373 It's not as awesome as BMW adaptive LED that I have on another car but close and night/day difference with Spyders I had previously which were just crap both in light and build quality. I had to swap the stock ones as I swapped the stock bumper and needed indicators inside the unit. Otherwise, I'd not touch stock lights which were quite good (I had the xenon European spec). |
The Following User Says Thank You to Efferalgan For This Useful Post: | Pat (04-19-2017) |
04-26-2017, 09:36 AM | #20 |
Drives: 2014 Whiteout FRS
Just though I would chime in here. I bought a set of Spec D headlights and retrofitted them with stuff from https://www.theretrofitsource.com/.
I went with the MORIMOTO FX-R 3.0 which required me to make custom brackets. But they have other options that literally bolt up no problem. The difficulty is pretty low, wiring them was the most time consuming. Light output and cut off is comparable to a high end luxury car. |
08-06-2019, 02:36 PM | #21 |
Drives: Q5 + BRZ + M796
https://www.amazon.com/MOSTPLUS-Sequ...CG40NWHEZZMBV9
Does anybody have any experience with these? Do they come with a harness? I'm assuming they are not plug and play with the MY13-16 BRZ, but could it be done easily?
08-06-2019, 02:40 PM | #22 |
Answered my own question, maybe.
[ame]https://www.youtube.com/watch?v=9lTlYfsPQTQ[/ame]
08-06-2019, 05:02 PM | #23 | |
Drives: 17 Asphalt 86
The fitment isn't perfect either. For $200-250 per headlight they're an upgrade over halogens.no where near OE quality. |
The Following User Says Thank You to RToyo86 For This Useful Post: | Irace86.2.0 (08-06-2019) |
08-06-2019, 05:35 PM | #24 |
Vlands and the amazon posting look the same. There are a few more "brands" with the same design. What do you think, did the same place produce them then sold them to difference brands, or are they just all slightly different copies?
08-06-2019, 07:04 PM | #25 | |
Or worse, they're knock offs which means they're probably worse but who knows. I see no reviews, so you'd be taking a shot in the dark. Worst case the light pattern is crap and you could gut them and put in quality projectors. |
08-06-2019, 07:10 PM | #26 |
Drives: '13 Scion FR-S & '17 Toyota 86
I would recommend that you look into Morimoto headlights if you're looking for a very high-quality option! I have them on my FRS and LOVE them! Pics below!
They are plug-and-play and use only LED bulbs. A 5-year warranty is offered from Morimoto, and the DRL's look amazing IMO! Light output is great as well, didn't need to adjust the headlights at all. -Sam |
The Following User Says Thank You to eastendraceshop For This Useful Post: | Irace86.2.0 (08-06-2019) |
08-06-2019, 09:23 PM | #27 | |
@RToyo86 I’ve read this elsewhere, that the projectors are bad. What does that mean? The bulb has defects in the glass, or the concavity is warped or not ideal? Shouldn’t the stock HIDs plug into the projector and work?
08-06-2019, 09:28 PM | #28 | |
-Sam |
The Following User Says Thank You to eastendraceshop For This Useful Post: | Irace86.2.0 (08-07-2019) |
Similar Threads | ||||
15mm Highest Quality Spacers | Mr. | Wheels and Tires | 8 | 08-24-2016 01:39 PM |
Quality Aftermarket Lights | Fenix | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 03-01-2016 09:21 AM |
Highest build quality cat-back? | NWFRS | Engine, Exhaust, Transmission | 5 | 09-07-2014 01:19 PM |
Varis Arising II - highest quality made kit I hv ever seen | RehabJeff86 | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 07-16-2014 08:32 PM |
Aftermarket LED Tail Light Quality | randel_07 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 09-15-2013 07:57 AM |
