Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
03-20-2017, 03:17 PM | #1 |
BOXER FR
Drives: WRB BRZ Limited
grinding noise when accelerating from stop
[ame="https://www.youtube.com/watch?v=SHNnT-0CrOs"]March 20, 2017 - YouTube[/ame]
do you guys hear the grinding when i accelerate? Only happens in 1st gear and only on left hand turns loading the front right wheel. the right front side has been in an accident previously and I ended up replacing the lower control arm and the hub carrier. I checked everything for any rubbing but no signs.. I even changed the driveshaft to another OEM one, but that didnt fix anything..
Build Thread of the "STI theme BRZ"http://www.ft86club.com/forums/showthread.php?t=61522
03-20-2017, 07:56 PM | #2 |
Have you tried accelerating from a stop in 2nd gear? (Without lugging it too much of coarse)
03-20-2017, 09:57 PM | #3 | |
Is the crunchy sound coming from the front of the vehicle .. ?? After the accident, and they replaced the hub carrier, did they replace the bearing..?? I had to ask. Why did you change the driveshaft ... ?? I suggest you take off the front wheels and inspect the hubs and bearings and the brake calipers. Or, do it the humfrz way ...... take it up to a local alignment/suspension shop and let them sort it out. OH HELL ....... daaaaa ........ I forgot ...... change the transmission oil ...... (that fixes everything) humfrz |
03-21-2017, 09:59 PM | #4 |
BOXER FR
So actually I have. Verdict is it only does it when I'm turning left but not when going straight (in 2nd gear).
03-22-2017, 12:31 AM | #5 |
Is it possible to tell if it's coming from the front or back? I'm leaning toward a a prob with your diff/lsd. Any mods or changes recently with your rear differential? Could also have something to do with VSC and wheel speed sensors but that would be very unusual.
03-22-2017, 03:00 AM | #6 | |
BOXER FR
Bearing was not changed.. I have done the transmission fluid not too long ago. I always use Motul for everything. Body shops mechanic told me he sees something weird about the driveshaft.. silly me I should've looked under myself but at $100 I was just willing to try to cancel out the possibility that it could be the driveshaft. I do have a weird wearing pattern on the front brake pads (inside wearing much faster) and I'm missing the metal shim.. can't be this causing the issue tho?
03-22-2017, 03:01 AM | #7 | |
BOXER FR
03-22-2017, 03:07 AM | #8 |
It is not the overpipe. I am 100% sure if that. This is most certainly related to low rpms and your turning plane. I honestly have no more input other than to take it to a dealer and have them evalute the car and re-calibrate the VSC. Very strange....
03-22-2017, 09:27 AM | #9 | |
Bingo! Driveshaft wouldn't just make a noise in one gear and while turning. It is not your problem.
03-22-2017, 06:32 PM | #10 |
BOXER FR
I'll try the rebuild of calipers and put in new pads with the shims and see what happens
04-07-2017, 09:59 PM | #11 |
BOXER FR
Got whole new calipers. Figured out overpipe is rubbing against the front crossmember
05-22-2021, 12:53 AM | #12 |
Drives: 18 BRZ tS, 27 GRMN 86
05-26-2021, 02:10 AM | #13 |
My guess would be ..........
The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (05-26-2021) |
Similar Threads | ||||
Shuddering feeling when accelerating from a stop while turning | mithrandiir42 | Engine, Exhaust, Transmission | 3 | 07-24-2016 02:15 PM |
Grinding noise when AC on | Mikeez | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 07-11-2016 01:25 AM |
Ticking/Clicking noise when accelerating? | Pineapple | Issues | Warranty | Recalls / TSB | 3 | 08-28-2014 03:29 PM |
Grinding noise? | frs10 | Issues | Warranty | Recalls / TSB | 7 | 09-20-2013 10:57 AM |
accelerating from a dead stop | jarviz | Scion FR-S / Toyota 86 GT86 General Forum | 78 | 07-26-2012 02:11 PM |
