Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Forced Induction
Old 07-06-2013, 10:46 AM   #43
welllam
Drives: STi
Regarding the installation of the vortech kit, I felt your pain.
Pain 1: the freaking windshield reservoir. After installing everything, I poured the windshield cleaning fluid back (luckily not after putting together the bumper), and found the leak. After trying 4-5 times flipping the rubber seal around, pushing it to the max or pulling it, and it still leaked. In the end I used sealant to get the job then. Then I filled it up again, and later found out the neck was also leaking..... I needed to do the same thing again and sealed everything up.
Pain 2: Tube C (the MAF sensor tube)
Interestingly, my tube B has very good clearance. Not all kit alike? Tube C was knocking the frame and the headlight all the time. I think the ECU was detecting the knocking of tube C to the frame as knock, and I saw some knock correction at some very random and low rev place. So I needed to undo the bumper and headlight to adjust the tube C. Also, according to the instruction, the headlight power clip putting aside move was for FRS only, but it was apparently needed for BRZ. After numerous trial the tube still touched the frame so I made some adjustment by using another hose clamps at tube C and zip tied it to a hole next to the coolant reservoir cap.
Pain 3: The bumper does not fit back well. There are big gaps around the edges of headlights.
Need to check why, might be the intercooler was not adjusted correct, but does yours fit perfectly?
In the end it took me 20 work hrs and like 40 man hours to get it done. I think if there is second installation it can be down to 8-10 hours.
I believe the instruction was OK (of course it can be improved), because I am a noob and most of the things are understandable. For those that I do not understand, i will play the spot the difference game and try to match the location vs the pictures.
Oil cooler seems like a must, because today i was at the track and after 3 mins the oil temp went up to 125c. I was using 0w20 and this was one of the issue. 5w-40 should handle ok in short run like 5-6 mins, but for longer run oil cooler is a must. Your set up seems workable, however I concern I have will be the 3 layers of radiator. After each layer there should be a big drop in terms of receiving cool air... How is your setup performing?
welllam is offline   Reply With Quote
Old 07-06-2013, 01:24 PM   #44
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
I installed mine with basic hand tools and in my aunts driveway (I was on vacation). it took me 12-13 hours. it's a pain in the ass but it can be done and at the cost of a sore back for the next 3 days.
would I pay someone if I had to do it again......I honestly donno. I think if I had a lift and a second set of hands, I would install it again. nothing is overly hard (if you can solder). it's just a lot of little things.
the instructions are a good guideline but they need some refining. if you have common sense, you'll make it through the install.
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
The Following User Says Thank You to draggin_az For This Useful Post:
Joeprelude (11-23-2014)
Old 07-06-2013, 05:11 PM   #45
DJCarbine
Thupercharged
DJCarbine's Avatar
I've seen a lot of instructions for aftermarket parts, and they usually are just guidelines.
Thats if you even get instructions....
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
draggin_az (07-06-2013)
Old 07-06-2013, 06:03 PM   #46
chate
Pharmasaurus Magnificus
chate's Avatar
Thank you sir, you've done a great service to the community
2013 FRS 6MT (Delivered 5/12/12 - 1st86!)
AEM CAI / Magnaflow Catback / OFT / OFH / e85
2015 Nissan GTR
chate is offline   Reply With Quote
Old 07-06-2013, 06:48 PM   #47
skatery1989
Drives: BRZ Limited
You guys should have tried installing it with the first set of instruction.
skatery1989 is offline   Reply With Quote
Old 07-07-2013, 12:41 AM   #48
Dezoris
Dezoris's Avatar
So far all my temps are solid IAT is virtually indentical before and after oil cooler. I have low RPM knock detection, did yours go away after you fixed your pipes?
Mine leaks from the top tube (washer fluid if you fill it passed the metal filler neck.
Yeah you can get through it for sure, shocked you did it like you did, how bad was your back?
Old 07-07-2013, 12:43 AM   #49
Dezoris
Dezoris's Avatar
Thanks a bunch
I had the second and 3rd revisions how bad were the first?
I dont get that at all. I would never design a product sell it without documentation.
Old 07-07-2013, 01:47 AM   #50
regal
If they hired a technical writer would it have increased sales? They are probably still in the red with these. I doubt many have been sold. With the ecutek/tuning requirements it is an expensive piece not affordable to many.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 07-07-2013, 01:52 AM   #51
Pete
Pete's Avatar
Drives: 2013 Asphalt FR-S
@Dezoris That was an EPIC review man great job! I am sorry you had so many bad experiences with the kit, I am now very glad I had mine installed by a technician at Phastek. I am a novice mechanic if I am being generous, and I felt a lot more comfortable leaving something so important to a pro.
Thanks for the hard work, the video looks and sounds great.
__________________________________________________ _________
Vortech S/C, Perrin Tune, Borla UEL Header, Perrin headerback, Enkei RPF1 17x9 +45, Michelin PSS @ 245.
Pete is offline   Reply With Quote
Old 07-07-2013, 02:29 AM   #52
Dezoris
Dezoris's Avatar
They could easily contract that out to someone for new documentation, and review.
I don't think it would increase sales but help prevent losing sales in this case.
Yeah that was smart and Phastek already had experience too. It probably made the process more fun too.
I actually spent a lot of time on in car audio, the driving part and dynos used three mics placed at different areas of the car to capture the sound as accurately as possible.
Thanks!
Old 07-07-2013, 07:45 PM   #53
draggin_az
draggin_az's Avatar
I was on leave visiting family in Indiana non of which has a garage. Like I said, no part of the install was overly hard. A second set of hands would have been nice when bolting up the intercooler but its not impossible to do it all by yourself.
My back felt like busted ass and was sore for the next 3 days. You really dont realize how low our cars are until you're bent over the engine bay for a long period of time.
277hp 93 octane
370hp on E-85
Old 07-07-2013, 08:04 PM   #54
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Cmon Pete! Be a man. :p
F1point4 is offline   Reply With Quote
Old 07-08-2013, 12:23 AM   #55
Dezoris
Dezoris's Avatar
I have some interesting tuner info to post tomorrow comparing different base tunes from the 3 large tuners.
The Following User Says Thank You to Dezoris For This Useful Post:
guarapo (07-08-2013)
Old 07-08-2013, 12:38 AM   #56
spdfreak
spdfreak's Avatar
Drives: GBS BRZ Limited
Very impressive review/documentary. Thanks for putting it all together!
I'm in your area, hope to see you around.
spdfreak is offline   Reply With Quote
Search this Thread:
Advanced Search
brz vortech supercharger install? Sniper2606 Forced Induction 16 05-07-2013 03:31 PM
*PHASTEK* Perrin Tuned Vortech Supercharger Install Thread (3 Vehicles, 3 Kits) PhastekSport Forced Induction 425 04-26-2013 10:06 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
