Xero Limit
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Electronics | Audio | NAV | Infotainment
Old 05-19-2019, 08:48 AM   #1
JDMPR725
Drives: 1998 Acura Integra LS
Any good stereo systems for an 86?
I'm buying an 86 in several months but I'm going over my to-buy parts list and looking for an aftermarket stereo system to replace the OEM center console radio. I'd like to know any good alternatives you guys recommend or use in your cars.
I'm personally looking for a stereo system with a removable head to prevent thieves from stealing it (not a lot that comes with that feature, unfortunately). An Android OS with good CPU/RAM, maybe a micro sd feature, and with a rear-camera monitor feature.
JDMPR725 is offline   Reply With Quote
Old 05-19-2019, 10:49 AM   #2
DarkPira7e
Handin' out 1 Deags
DarkPira7e's Avatar
Drives: 13 Firestorm Red FRS
I'm adding a turbo since the stock sound system didn't have what I was looking for. UEL headers with a muffler delete is a good choice for pretty cheap. A couple companies make ITBs for this engine if you're a huge sound enthusiast. There are a lot of options
Old 05-19-2019, 02:02 PM   #3
soundman98
Registered Wire Licker
soundman98's Avatar
Drives: '14 brz limited
he did post in the correct section...
so 1/2 the responses you'll get are that audio in this car is an absolute waste of money. the other half will respond with their specific brand preferences as the greatest thing, and pricing will be all over the board. my post isn't going to be any different .
first, you need to come up with a rough cost where you want to be.
some of the guy's running android units are starting to hit the limitations-- they're all cheap crap, many won't run more than 1 app at a time. i don't believe any of them have removable screens. windows-based carpc's are a better option, but integration fell flat 10 years ago, and now nearly doesn't exist.
personally, i run a pioneer deh-80prs. it does everything i need for audio, looks cheap so no one touches it, but also has a removable faceplate and sd card slot if one were so inclined. it doesn't look the prettiest in the dash, and there's no big screen, but i'm happier that way..
my '14 brz limited "the return to normal" (or is it?)
led mods-10%(planning/designing/sitting on hands)audio mods-99%(done is never done)
hidplanet build log
why? (05-21-2019)
Old 05-19-2019, 02:24 PM   #4
JD001
JD001's Avatar
Drives: Subaru BRZ
Try the one used in the BRZ MY2012-15...
Old 05-19-2019, 02:47 PM   #5
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Look, the BIGGEST problem with the stock radio in the 86 is connectivity.
Think of it like a 1 din radio from 10 years ago, it just happens to have a big screen for a backup cam. It's THAT useless, AM/FM/BT/AUX don't count on anything more than that. Aha? HAHA! wonky unreliable connectivity, useless, and don't you start hoping we'll get a carplay/android auto update like lexus selling carplay software updates, this radio is just in the iM, 86 and C-HR, we're trash peasants. However, prior to purchase based on comments from the internet, I had assumed I'd have to chuck it in the trash on week 1 because "hurrrr! sound bad!".
Truth is, the sound quality is fine for a stock system, that's it, "fine". you don't have to assume it's unusable trash, and if you just want [sound] it's tolerable.
I'm still gonna chuck mine in the trash eventually, but it was tolerable enough that it's priority has fallen behind wheels/tires/wing/underbody aero.
Old 05-19-2019, 09:00 PM   #6
JDMPR725
I suppose you're right. There isn't much of what I would ideally find on what I'm looking for. The one you have does look nice and I have a similar pioneer model in my Integra but want to have that removable head feature most of all.
Old 05-20-2019, 02:16 AM   #7
soundman98
soundman98's Avatar
I had a pioneer appradio with 7" flip up screen for a while--$350 i believe, similar to the 80prs. Not a high end unit by any means, just had a fancy 7" touchscreen
It remains the one radio someone broke into my car for. So i actively avoid radio's with screens now. But then i also had a carpc for a while with a built-in 7" screen(custom built transflective layers, was around $700), and i never had problems the entire time that was installed...
hidplanet build log
Old 05-20-2019, 03:52 AM   #8
Alastor
Drives: Toyota gt86 my19
Hi
If you havent a problem with your money, you have a Pioneer avh-z9100dab. Is antifet.
Alastor is offline   Reply With Quote
Old 05-21-2019, 07:49 AM   #9
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
I have a Pioneer DEH-P01 from japan I'm tempted to install because the sound quality of the stock system really is that bad, and the navigation is even more useless. I mean the stock system is fine for listening to podcasts, but that's about it.
However you should really go to https://www.diymobileaudio.com/forum/, as they are the kings of car audio and I am sure there are plenty of reasonably priced options that have what you are looking for that they will know about.
why? is offline   Reply With Quote
aftermarket, android, audio system, music, toyota 86
2013 BRZ Nav Stereo For 2016 BRZ Starlink Stereo cjrodriguez Audio/Visual, Electronics, Infotainment, NAV 11 02-27-2016 07:33 AM
Stock FRS stereo on Toyota 86 - Wiring problem position lights turn on/off the stereo dssence Electronics | Audio | NAV | Infotainment 0 01-27-2015 07:43 PM
Pulley systems, what are they good for and worth the money? K-NoMs Engine, Exhaust, Transmission 44 09-06-2014 02:01 AM
Any good stereo installers in NY area that have worked on the frs? mikeg7827 NY / NJ / CT / PA 18 09-09-2013 10:07 PM
Good Reputable Reasonably priced stereo installer on Long Island? mikeg7827 NY / NJ / CT / PA 1 11-25-2012 04:52 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
