Member's Car Journals Car journals by our members. |
02-11-2018, 04:38 PM | #15 |
Drives: 2013 WRB BRZ Limited
Added since the last post:
Invidia Q300 catback Motiv front pipe (straight pipe) OFT Stage 1 flash -B |
02-12-2018, 05:06 PM | #16 |
Added the Perrin Inlet / K&N Filter. Had to trim a bunch off the inlet because it was going to rub on the belt.
-B |
02-24-2018, 04:40 PM | #17 |
Added the 22mm Front Perrin Sway bar and set to soft for now.
It makes the car feel much more solid. and Turning is slightly heavier. -B |
06-04-2018, 10:56 PM | #18 |
Added some Koni Adjustables and Ferodo DS2500 Pads for autocross! I have a double header in 3 weeks.
-B |
07-08-2018, 08:32 PM | #19 |
I finished my entire planned build this week.
OEM STi Side Skirts Bayson Rear Spats OEM Rear Diffuser Bayson Front lip STi Black rear badge Red TS Pinstriping -B |
The Following User Says Thank You to HeresMyMind For This Useful Post: | JeremyR (07-09-2018) |
07-09-2018, 02:28 AM | #20 |
Drives: 2015 BRZ Limited
pics?!
07-22-2018, 11:21 AM | #22 |
Got the car on the dyno to see how all the mods are running!
it made 188whp / 153wtrq -B |
09-25-2018, 09:14 PM | #23 |
I made the big leap!
I added: Tomei UEL Header Motiv Over Pipe (Ceramic Coated) Motiv High Flow Cat Front Pipe (got rid of Motiv Straight Pipe) SuperTek Hard Inlet (got rid of Perrin silicone inlet) OFT V2 with Stage 2+ 4.0x Flash -B |
09-26-2018, 01:55 AM | #24 |
Where'd ya get the intake? I thought they were discontinued
Any plans to dyno it again to see how much you've gained?
09-29-2018, 11:33 AM | #25 |
Stage 2+ Dyno Results!
10-08-2018, 10:01 AM | #26 |
Added a JDM STi badge to the front grill!
-B |
10-18-2018, 08:04 AM | #27 |
Installed Eibach Pro-Line lowering springs and winter wheels/tires. and Tom's Clear tails.
-B |
10-19-2018, 04:05 PM | #28 |
Dyno results look great man! No sign of the dip anywhere
Similar Threads | ||||
Car failed inspection; told I need to "build up the drive cycle"? | irocz0r | Issues | Warranty | Recalls / TSB | 11 | 06-22-2017 08:25 PM |
TWINCHARGED (Supercharged & Turbocharged) Widebody "WTF-86" 86/FRS *MASSIVE* build :D | WTF | Member's Car Journals | 224 | 08-18-2016 09:39 PM |
Meet "Cloud" Errol's FR-S Build Thread | RainEG | Member's Car Journals | 12 | 08-01-2014 05:18 PM |
BRZ "Limited" STX build | xDanger_208x | Member's Car Journals | 48 | 04-21-2014 11:38 PM |
