Old 03-19-2013, 02:52 PM   #15
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Originally Posted by JoeBoxer View Post
I'll take you up on that one just need a few weeks
Can do man!
JDLAutoDesign is offline   Reply With Quote
Old 03-19-2013, 03:03 PM   #16
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
raw....now this is neat
Huehuecoyotl is offline   Reply With Quote
Old 03-19-2013, 03:12 PM   #17
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Would there be anything to worry about with regards to the radiant heat given off by the can to the battery? Overheating the battery in the heat of summer on a track day could be bad.
My current catch can (closed loop Moroso, fed by the rear PCV) gets pretty hot after some spirited driving.
Old 03-19-2013, 03:24 PM   #18
JDLAutoDesign
Drives: 13 FRS
We have ran similar setups on Evos with lots of track time and no "overheating" of the battery whatsoever
The Following User Says Thank You to JDLAutoDesign For This Useful Post:
ATL BRZ (03-19-2013)
Old 03-19-2013, 03:34 PM   #19
JDLAutoDesign
Drives: 13 FRS
Closer pic
JPxM0Dz (03-19-2013)
Old 03-19-2013, 03:41 PM   #20
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by 2forme View Post
LOL, I originally thought it was the head unit. But I swapped it in my other car for two weeks and it didn't kill the battery. I think I just got a bad one. It's been finicky from the start.
Hmm, I haven't tried nylon washers. I'll give that a go.
CCA? pfft, who needs CCA when it's below freezing outside... oh wait....
I've started a 2.0L engine with a lawn tractor battery in -20 deg C.
The Following User Says Thank You to Calum For This Useful Post:
2forme (03-19-2013)
Old 03-19-2013, 03:44 PM   #21
Huehuecoyotl
can you show a cutaway or illustration of the catch mechanism? is it media? vortex based? what are you doing inside that will allow solids to drop in the air stream? I like the drain to sump function myself for my FI setup, I'd consider the VTA if I was NA-I think, right?.... can you offer your opinion or guidance for the FI crowd? thats alot of volume, btw
Old 03-19-2013, 04:03 PM   #22
JDLAutoDesign
Drives: 13 FRS
The can has a 3 internal baffles similar to the baffles you would find inside a OEM valve cover. One at the inlet ports one at near the middle and one at the upper portion of the can. They are staggered to catch oil yet allow the PCV gasses to flow freely. We have ran both VTA and Recalculated on tubro'd cars. We prefer the VTA as there is no chance of getting any oil back into the intake tract. Too much volume isnt a bad thing. Some high hp cars produce a lot of blow by on high boost.
This is a can we built for a local car. The car makes over 1300hp and filling up the previous smaller can. That has a -10 and -20 fittings/lines for reference
Old 03-19-2013, 04:19 PM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I love it. I would definitely swap out my D3PE can for this one and a lightweight battery. Let me know when it is ready for purchase. I think I would like it in raw aluminum. I'm still loving your overpipe and frontpipe.
The Following User Says Thank You to King Tut For This Useful Post:
JDLAutoDesign (03-19-2013)
Old 03-19-2013, 05:13 PM   #24
JDLAutoDesign
Drives: 13 FRS
Will update for sure
Old 03-19-2013, 07:37 PM   #25
Pete
Pete's Avatar
Drives: 22 BRZ
Great idea, I just entered the market for a catch can. What is the weight target for the production piece?
Pete is offline   Reply With Quote
Old 03-19-2013, 07:40 PM   #26
OrbitalEllipses
Drives: Attitude
But did you do it everyday for 3 months all without keeping the battery on a tender?
Old 03-19-2013, 07:44 PM   #27
jonbatz01
jonbatz01's Avatar
Drives: ZD8
With the Battery being on the other side for JDM versions, will this be a simple flip to fit?
EOJ | PERTH | ZD8
jonbatz01 is offline   Reply With Quote
Old 03-19-2013, 07:46 PM   #28
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
I've ran mine for well over 3 month. The only issue i've had is when the car was getting the AEM setup and it was on the dyno for quite a while in the "key on" position. I've also ran one in my Evo for years and never any problems. I do know others have had different experiences depending on climate, etc..
Jesse@JDLAutodesign is offline   Reply With Quote
MAW lightweight battery kit. Turn in Concepts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 08-24-2016 06:57 PM
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" GuerillaRacing Wheels and Tires 116 01-20-2015 06:32 PM
≥≥≥ WEIGHT LOSS PROGRAM ≤≤≤ Lightweight battery kit. New Years Resolution Complete!!! FT-86 SpeedFactory Brakes, Suspension, Chassis 52 05-26-2013 11:19 PM
Awesome idea, lightweight battery/catch can combo JoeBoxer Engine, Exhaust, Transmission 21 12-31-2012 06:11 PM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 09:05 PM
