Old 05-05-2014, 02:44 AM   #29
Poodles
Drives: 2015 Series.Blue
I know that you want to allow the oil to get above boiling (212F) to boil off any water.
Most important thing in this thread. It's completely normal for water to get in the oil from the combustion process (as is fuel), and getting up to proper temps removes it through the PCV system. Running too cool would cause a buildup of these contaminates leading to eventual damage (water doesn't lubricate as anyone who has had fun time with someone in a shower can attest to )
The Following 4 Users Say Thank You to Poodles For This Useful Post:
Gords_zenith (05-05-2014), kavanagh (05-05-2014), stugray (05-19-2015), wparsons (05-19-2015)
Old 05-05-2014, 01:10 PM   #30
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
I think I'd rather just run an oil cooler rather than play around with oil viscosity which deviates from the listed spec for the engine.
^GT5 Replay Photo Mode^
Old 05-19-2015, 02:27 PM   #31
sickmint79
Drives: bmw
interested in thoughts and comments on my post in the forester oil cooler thread - http://www.ft86club.com/forums/showp...&postcount=474
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
Old 05-21-2015, 01:19 PM   #32
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
I added the oem oil cooler but i am still na. Ive noticed that average running temps are basiclly the same with or with out it, but on track once you lay off heavy throttle the oil cools very fast back to 210 ish
IG-Joey_Soul
Old 05-21-2015, 02:11 PM   #33
DarkSunrise
DarkSunrise's Avatar
Interesting to hear that the average temps are basically the same with/without the OEM cooler, but that temps drop down to 210 off throttle.
If you want a comparison to a Perrin external oil cooler (NA setup), here is a data log from my last track day:
http://datazap.me/u/darksunrise/data...og=0&data=1-10
Oil temps stabilize around 230 F (about 8 min in), with short peaks of 235 F. Coolant temps stabilize around 200 F.
One thing I don't like about the Perrin setup though is it seems to increase IATs by 10F or more, probably because of how close the oil lines come to the stock airbox.
2022 BRZ Build
2013 FR-S Build
Old 05-21-2015, 04:20 PM   #34
sw20kosh
Drives: 2013 Black FR-S
Stock radiator (as flimsy as it looks) actually doesn't need replacing. Tested extensively on track my multiple people at 300+ whp FI even.
If you allow your oil to cook (past 250 F) then the coolant will start coming up too regardless of radiator. Keep the oil at a good temperature and the stock radiator works fine.
Old 05-22-2015, 01:12 PM   #35
Grip Ronin
The Mechanic
Grip Ronin's Avatar
ya on highway cruising its like 205 210 but on track ive hit 245 with the cooler while pushing but its not just off throttle just when you drop rpm and do a cool off lap. Ill log it next track day and post it on datazap as well.. i didnt go external because of the low oil pressure issues with this engine
IG-Joey_Soul
Old 05-22-2015, 01:25 PM   #36
sickmint79
Drives: bmw
i got much warmer and even my oem radiator seemed to perform just fine. more info in the forester oil cooler thread here.
Old 05-31-2016, 03:22 PM   #37
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Just had my first track day and monitored my oil temps very carefully throughout the day with the oft. At first i was afraid of going over 245 but when asking aeound some people were backing off when they reached about 250 degrees f. Anyways it was a hot day, 100degrees, and when i was going down the straight at thunderhill i noticed about 258 to 260 degrees oil temps.. thats when i started taking it easy.. forgot to mwntion im running royal purples 5w30.
Anyways i guess this is more of a statement then a question and just wanted to share that even na i was hitting crazy high oil temps granted that i dont have an oil cooler.
Instagram: trevor.parque
Engine oil standard operating temperature brillo Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 04-22-2015 01:12 AM
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
How to tell Engine's Operating Temp? tez2013 Tracking / Autocross / HPDE / Drifting 9 06-03-2013 01:33 AM
Engine oil temp now available in Torque App Yruyur Engine, Exhaust, Transmission 8 02-03-2013 10:52 PM
